POV-Ray : Newsgroups : povray.unofficial.patches : dificulty getting super-patch running Server Time
2 Nov 2024 17:17:14 EDT (-0400)
  dificulty getting super-patch running (Message 1 to 10 of 12)
Subject: dificulty getting super-patch running
Date: 7 Jul 1999 17:45:23
Message: <3783CBD3.5BE8F6FE@yahoo.com>
I'm getting an error when trying to get super-patch working... i'm not
sure why... i'm not much of a programer but i would love to get this
working
the error is:
Editor DLL initialisation failed [LoadLibrary failed, code is 00000485]
is this just something i missed?
Oh, and the linux version i can't get to work either, it's saying:
/povray: error in loading shared libraries
: undefined symbol: __bzero
i think that one is because i'm missing a file, or a file is corupt, can
anyone help me here either? (i would rather get linux version working,
but either would be good)
Thanks before hand
   the Loial Raven
P.S. Have fun eh :)
Subject: Re: dificulty getting super-patch running
Date: 7 Jul 1999 17:48:55
Message: <3783CCA7.B4F683EA@yahoo.com>
Now i feel stupid... windows one was in the text file, i just didn't read it
right the first time... does anyone have a spair brain that they wouldn't
mind sending me?
> working
> the error is:
> Thanks before hand
>    the Loial Raven
> P.S. Have fun eh :)
Date: 7 Jul 1999 18:04:35
Message: <3783cef3@news.povray.org>
The superpatch Linux binary distribution does assume that you have
already correctly installed libpng.so and libz.so.  If you have not,
you will probably get an error.  On the other hand, you'd get the
same error with the official distribution, too.
What version of Linux are you using?  Specifically, which distro and
version number, which kernel version, and which C library?  The
binaries on my website were built with OpenLinux 2.2 on glibc2.  I
don't know what kernel I'm running offhand.  I did notice that
either povray or x-povray is built wrong, due to stupidity on my part,
so you may find that the other one works.  For now, the best fix for
that problem is to download the source and build your own if you need
the one that's broken (whichever one it is.)
Date: 7 Jul 1999 22:27:50
Message: <37840E05.77434D46@yahoo.com>
I'm on a Debian linux, 2.2.3
uh... glibc2... hmm... i'm not all that good with linux yet... still
learning...
i did grab the source, but couldn't get them to compile... if you like, i
can explain more...
Date: 7 Jul 1999 22:32:48
Message: <37840d92.83923182@news.povray.org>
On Wed, 07 Jul 1999 19:33:42 -0700, "Loial Raven (Stuart MeerKat)"
>learning...
>can explain more...
Just to be sure, you did install the official POV source first, then
the superpatch source on top of it, right?
If so, and if you still can't get it to build, tell me what errors
you're getting so we can see about working around them.
Date: 8 Jul 1999 07:21:33
Message: <37848968.D61BDE7C@numerik.uni-kiel.de>
Ooohpss, I want that brain, please.
Ron, I can't find superpatch anywhere. I just found the fix-file on the
news server, twyst is down...
The homepage of yours is http://www2.fwi.com/~parkerr/ , right?
or do you have another one?
Axel
Date: 8 Jul 1999 09:30:49
Message: <3784a809@news.povray.org>
It is, but the superpatch isn't linked from there.  I've been slow
about getting a real webpage up around it.
Try http://www2.fwi.com/~parkerr/superpatch
Date: 8 Jul 1999 16:16:57
Message: <3785035b.881453@news.povray.org>
>>learning...
>>can explain more...
I am having trouble with POV on Debian, too.  FYI, I have Debian 2.1
("slink"), the current stable release.  2.2 ("potato") is the current
unstable release.  As to libraries present, my version has libc6 (and
libc5 in another directory), glibc2, libpng.so.0, libpng.so.0.96,
libpng.so.2, libpng.so.2.1.0, libz.so.1, and libz.so.1.1.3.  They are
in /usr/lib.  None of the binaries for either 3.1g or Superpatch work
for me.  I haven't yet been able to compile them either, although that
may well be general Linux newbieness.  As to the errors the binaries
give me:
3.1g as root:
s-povray: segmentation fault
x-povray: segmentation fault
3.1g as regular user:
s-povray: error in loading shared libraries: undefined symbol: __bzero
x-povray segmentation fault
Superpatch as root:
__register_frame_info
x-povray: error in loading shared libraries: undefined symbol:
Superatch as regular user:
__deregister_frame_info
Jerry Anning
clem "at" dhol "dot" com
Date: 9 Jul 1999 03:28:15
Message: <3785A43E.A6CACA5C@numerik.uni-kiel.de>
<.. check for errors in previous post :-)..>
I have a few tips on this:
Check which libraries are actually loaded with ldd. Do this for both
root and user.
The difference could stem from LD_PRELOAD. This is, if I remember right,
not evaluated for root.
If ld.so includes the wrong libraries, do a LD_PRELOAD of your own.
There may be a chance to get that done for root as well. But I have a
fog 1 there.
Axel
PS: I'l give that spare brain over to Ron. But I will patch it with some
'linking-module' first.
Date: 9 Jul 1999 20:59:13
Message: <37869C3A.6BE4585B@yahoo.com>
Hey, i got x-povray version to compile, it took reinstalling with using
unzip -a <file>... that made those anoying ^M's disapear hehehe... well, it
also took some playing with the makefile... but for some reason, it won't
compile the svga based one, which i rather use... it keeps on saying that it
needs a bunch of X stuff, so i think things aren't fully set up in the
makefile... if anyone knows about where the problem is now, the help would
be most apreciated :)
Oh, and also, both the windows version and the linux version don't have the
spline's working, am i missing something? or is it disabled...?
    the Loial Raven
> working
> the error is:
> Thanks before hand
>    the Loial Raven
> P.S. Have fun eh :)
