POV-Ray : Newsgroups : povray.unofficial.patches : SuperPatch / triangle mesh Server Time
12 Jul 2026 23:25:36 EDT (-0400)
  SuperPatch / triangle mesh (Message 1 to 5 of 5)
Subject: SuperPatch / triangle mesh
Date: 30 Jun 1999 19:42:03
Message: <377AAB06.3A55@geocities.com>
in SuperPatch version of parse.c, in the function
Parse_Mesh(), there is the line
	number_of_vertices=0;
then in parsing of 'plain' (non-smooth) triangles,
nothing is done to number_of_vertices.
Looking down at the smooth_triangle mesh code,
number_of_vertices is set for smooth_triangles
by calling
	Mesh_Hash_Vertex(&number_of_vertices,
			&max_vertices,
			&Vertices, P1);
but Mesh_Hash_Vertex(&number_of_vertices,...) is
not called for plain triangles.
But then later there is:
	Object->Data->Vertices =
          (SNGL_VECT
*)POV_MALLOC(number_of_vertices*sizeof(SNGL_VECT), 	    "triangle mesh
data");
and POV-Ray stops for trying to malloc zero bytes.
Now, what I did, and it is working, is just stick in some
			&max_vertices,
			&Vertices, P1);
Comments / condemnations ??
Subject: Re: SuperPatch / triangle mesh
Date: 30 Jun 1999 20:59:46
Message: <377bbd32.201831516@news.povray.org>
On Wed, 30 Jun 1999 19:40:55 -0400, edna dornblazer
>			&max_vertices,
>			&Vertices, P1);
Um... Nathan?  Any comments?  I was just going to look at that, to
tell you the truth, but I hadn't gotten around to it.
Date: 30 Jun 1999 23:53:12
Message: <377AE532.8D6AC393@Kopp.com>
Parse_Mesh() in UVPov does have Mesh_Hash_Vertex() calls for both smooth
and flat triangles.  Must have gotten deleted during the merge. After the
call to Init_Mesh_Triangle() for both smooth & flat triangles, you should
have:
        Triangles[number_of_triangles].P1 =
Mesh_Hash_Vertex(&number_of_vertices, &max_vertices, &Vertices, P1);
        Triangles[number_of_triangles].P2 =
Mesh_Hash_Vertex(&number_of_vertices, &max_vertices, &Vertices, P2);
        Triangles[number_of_triangles].P3 =
Mesh_Hash_Vertex(&number_of_vertices, &max_vertices, &Vertices, P3);
(One humble request, Ron: could you use spaces instead of tabs to indent?
My tab sizes must be different than yours and the code indentation looks
very messy on my system.  No big deal, but if you happen to have time, I'd
appreciate it.)
-Nathan
> >                       &max_vertices,
> >                       &Vertices, P1);
Date: 1 Jul 1999 02:38:35
Message: <377b0ceb@news.povray.org>
I've been having similar problems with a wide range of triangle meshes, from
a variety of programs and pov code.
Poser and organica files seem to be immune.
Mick
edna dornblazer <hac### [at] geocitiescom> wrote in message
news:377### [at] geocitiescom...
> by calling
> &max_vertices,
> &Vertices, P1);
>           (SNGL_VECT
> data");
> &max_vertices,
> &Vertices, P1);
Date: 6 Jul 1999 02:36:34
Message: <3781a3f2@news.povray.org>
Mick Hazelgrove wrote in message <377b0ceb@news.povray.org>...
from
I seem to have this problem with an XWing model I'm currently using, as well
as Gilles's maketree macro (the leaves)
Is there a fixed version out/ coming out soon. I don't have the source (or a
compiler)
Gail
* gsh### [at] monotixcoza              * ERROR: COFFEE.COM not found  *
* http://www.rucus.ru.ac.za/~gail/ * Insert cup and press any key *
   My Software never has bugs, It just develops random features
