POV-Ray : Newsgroups : povray.unofficial.patches : UVPOV 5.2a parser bug Server Time
18 Apr 2026 18:04:34 EDT (-0400)
  UVPOV 5.2a parser bug (Message 1 to 10 of 10)
Subject: UVPOV 5.2a parser bug
Date: 14 Jun 1999 10:09:45
Message: <37650b3a.4662718@news.povray.org>
Please see the attached code. Take special note on line 62. If you
remove it or comment it, the parser gives an error. I have no idea
why, but it seems like a parser bug.
Peter Popov
ICQ: 15002700
Download 'glass.pov.txt' (5 KB)
Subject: Re: UVPOV 5.2a parser bug
Date: 14 Jun 1999 22:40:21
Message: <3765BC5E.4F93231D@Kopp.com>
Darn.  I thought I fixed that.  That's what I get for playing with the parser
without knowing what I'm doing.  I'll work on it and get back to you soon.
-Nathan
> Peter Popov
> ICQ: 15002700
Date: 14 Jun 1999 23:13:39
Message: <3765C42B.228BED5A@Kopp.com>
Ok.  I think I fixed it now.  I'm going to wait to upload the new version,
though.  If other people run into problems, I'll upload this fix, but I
want to check it out more first, since I'm not sure exactly how this part
of the parser works yet.
-Nathan
> Peter Popov
> ICQ: 15002700
Date: 15 Jun 1999 11:26:09
Message: <37667091@news.povray.org>
In article <37650b3a.4662718@news.povray.org> , pet### [at] usanet (Peter
> Peter Popov
> ICQ: 15002700
>#declare T_Wood34 =
>texture { T_Wood32 }
>texture  {
>    pigment {
>        onion
>        turbulence 0.2125
>        colour_map {
>            [0.225 colour rgbt <1.000000, 0.53333, 0.11767, 0.4875>]
>            [0.350 colour rgbt <0.662750, 0.28617, 0.00001, 0.7250>]
>            [0.500 colour rgbt <1.000100, 0.53333, 0.11765, 0.5745>]
>            [0.625 colour rgbt <0.662775, 0.28627, 0.00005, 0.6875>]
>            [0.750 colour rgbt <1.000200, 0.53333, 0.11755, 0.5275>]
>            [0.875 colour rgbt <0.662755, 0.28629, 0.00001, 0.3795>]
>            [1.000 colour rgbt <1.000000, 0.53333, 0.11665, 0.6165>]
>        scale <0.225, 0.20, 1.15>
Interesting, I didn't know that this was (ever) supposed to work at all (I
didn't miss the note of that exception the POV-Ray Docs, did I?). I
would say the parser is right...
    Thorsten
e-mail: Tho### [at] csicom
Date: 15 Jun 1999 20:53:38
Message: <3766F4D6.DFC19439@Kopp.com>
That's how you do layered textures.  And this parser keeps looking harder
and harder to fix.  :-(  ...and it looked so easy at first.
-Nathan
>     Thorsten
Date: 16 Jun 1999 10:34:47
Message: <3767b607@news.povray.org>
In article <3766F4D6.DFC19439@Kopp.com> , Nathan Kopp <Nat### [at] Koppcom>
Yes, layered textures _inside_ object declarations, but if I read this right
#declare T_Wood34 =
texture  { ... }
should (or will) only declare
#declare T_Wood34 =
and I suppose that the parser complains about the second texture { ... } if
the #if .. #end isn't there.  I would suggest to declare each of the
textures and then use each of them in the object which still gives a layered
texture.
    Thorsten
Date: 16 Jun 1999 10:42:17
Message: <3767B4E3.56E63F34@pacbell.net>
> #declare T_Wood34 =
> texture  { ... }
> #declare T_Wood34 =
> texture.
>     Thorsten
  Dating back at least as far as Pov v2.2 it has been valid to declare
textures as previously illustrated i.e.
#declare T1 =
texture { ... }
texture { ... }
object { thing texture { T1 }}
  I have designed and used so many layered textures this way I can verify it's
legitimacy.
Ken Tyler
mailto://tylereng@pacbell.net
Date: 16 Jun 1999 10:57:13
Message: <3767bb49@news.povray.org>
>#declare T_Wood34 =
>texture  { ... }
>#declare T_Wood34 =
From the documentation, the section on layered textures:
    Layered textures may be declared. For example
    #declare Layered_Examp =
      texture {T1}
      texture {T2}
      texture {T3}
In fact, there are places you can't use a layered texture directly
but you may use a declared one.  From the same page in the docs:
    If you wish to use a layered texture in a block pattern, such as
    checker, hexagon, or brick, or in a material_map, you must declare
    it first and then reference it inside a single texture statement.
And here's the code from the parser, from parse.c in the function
Parse_RValue.  The interior EXPECT loop takes care of any remaining
texture definitions after the first one, linking them to form a
layered texture.
    CASE (TEXTURE_TOKEN)
      Parse_Begin ();
      Local_Texture = Parse_Texture ();
      Parse_End ();
      Temp_Texture=NULL;
      Link_Textures(&Temp_Texture, Local_Texture);
      Ok_To_Declare = FALSE;
      EXPECT
	  Parse_Begin ();
	  Parse_End ();
	END_CASE
	OTHERWISE
	  UNGET
	  EXIT
	END_CASE
      END_EXPECT
      *NumberPtr    = TEXTURE_ID_TOKEN;
      Test_Redefine(Previous,NumberPtr,*DataPtr);
      *DataPtr      = (void *)Temp_Texture;
      Ok_To_Declare = TRUE;
      EXIT
    END_CASE
Date: 16 Jun 1999 14:31:13
Message: <3767ed71@news.povray.org>
In article <3767bb49@news.povray.org> , par### [at] fwicom (Ron Parker) wrote:
>       texture {T1}
>       texture {T2}
>       texture {T3}
Aha, so I really missed that :-)   Well, I don't use layered textures very
often...
> layered texture.
Makes sense.  Thank you for the clarification.
      Thorsten
Date: 16 Jun 1999 20:52:28
Message: <37684605.A8803C7E@Kopp.com>
I'm uploading the new patch now.  Hopefully this one will really fix the
bugs.  I put back the original #declare code, so all #declares should
have no problem.  No guarantees with my new parser stuff (the $ and %
shortcuts) though.
-Nathan
