POV-Ray : Newsgroups : povray.unofficial.patches : Q: Photon Patch - Other Features Server Time
18 Apr 2026 19:58:06 EDT (-0400)
  Q: Photon Patch - Other Features (Message 1 to 5 of 5)
Subject: Q: Photon Patch - Other Features
Date: 28 Mar 1999 06:34:56
Message: <36FE12D1.E2B5C1FA@pacbell.net>
I don't get it !
1.) image_pattern ?
  There is a new pattern type included with the Photon Patch of Pov-Ray
called "image_pattern". What is the purpose of this addition. I looked
at the example given at Nathan's patch site and read the description
but I am not following the reason for it's existence and when it is
appropriate to use it. I had no problem recreating the example image
shown at the site with existing texture and pigment procedures.
2.) U_V Mapping
Concerning the u_v mapping function in the patch. I tried using it with
a mesh based model and had less than successful results. Could someone
explain a little more on the process involved in it's implementation
and usage. I understand well how it works with bicubic patches as that
is well documented and I have read the posts here on the topic. As applied
to a large mesh object on the other hand all I am getting is a solid
colored pigment effect rather than the image hugging the mesh object
as expected. Anyone ?
  And thank you for your continued support !
Ken Tyler
mailto://tylereng@pacbell.net
Subject: Re: Q: Photon Patch - Other Features
Date: 28 Mar 1999 21:34:37
Message: <36FEF77B.B00DB9AF@rsp.com.au>
ken said
> 2.) U_V Mapping
 The "supported" primatives for uv mapping have inherent uv spaces. The thing
with triangles is that you have to describe this space yourself. You could do
this by macro'ing an object from triangles that describes the uv space as it
creates the object or use another piece of software to do it. A straight mesh
that just contains triangle info doesn't have any inherent uv space. To get
uv mapping to work, each triangle in your mesh must have a uv space defined
for it as per the bottom of Nathan's uv mapping pov page.
(http://nathan.kopp.com/uv.htm)
Other highend modellers facilitate uv manipulation when texturing meshes
(like texturing in 3d studio or something and then saving to .3ds format)
then would then have to use a converter that would convert triangle info
aswel as triangle uv coords. ...(doesn't the latest ver of 3ds2pov do this??)
benp
Date: 30 Mar 1999 23:58:29
Message: <3701AADA.866700AA@Kopp.com>
3ds2pov does convert 3ds files with textures and uv coordinates intact.
-Nathan
Date: 31 Mar 1999 00:03:57
Message: <3701AC22.7035BF46@Kopp.com>
Ken wrote:
> I don't get it !
> 1.) image_pattern ?
This was made for Thomas Baier for use with 3DS to POV conversions.  Let's
say you have two textures, and you want to use a black and white image
to fade between the two textures.  Now lets say all you have to work with
is material_map.  That would be a lot of work.  If you only wanted to use
two textures (no fading between), that would be easy, but since material_map
uses indices and single textures, fading would be very difficult and you'd
have a lot of "average{ texture_map { [0.5 t1] [0.4 t2] }}" statements.
You could put it in a while loop, but that would still be a lot of extra
work.
Now, on the other hand, if you have image_pattern, you can use texture_map
instead of material_map, and just use the image as your image_pattern.
Simple.  Fast.  Saves memory (no need for 256 textures for those 256
shades of grey).
-Nathan
Date: 9 Apr 1999 06:35:38
Message: <370DC8B5.4F28C825@pacbell.net>
Nathan,
  If you get a chance stop by the images group and look at the
 post titled Patent Pending. The reason is explained there and
 is related to the "other" features of the patch.
 Thank you,
 Ken Tyler
