POV-Ray : Newsgroups : povray.unofficial.patches : Linux link for MegaPOV 0.6a Server Time
16 Mar 2026 16:38:15 EDT (-0400)
  Linux link for MegaPOV 0.6a (Message 11 to 19 of 19)
Subject: Re: Linux link for MegaPOV 0.6a
Date: 8 Jun 2001 16:32:16
Message: <20010608.153326.1529195746.19812@erwin.largegeek.com>
In article <slr### [at] zero-ppslocaldomain>, "Steve"
<ste### [at] zeroppsuklinuxnet> wrote:
> On Thu, 07 Jun 2001 18:09:10 -0500, David wrote:
>>I downloaded the archive listed, but there was no make file,
>>configuration script, or anythign, just the source.  Is there another
>>copy floating around somewhere that is packaged better? Thanks
> Untar:
<snip>
> $ ls -lh xmegapov
> -rwxr-xr-x    1 root     root         1.1M Jun  8 14:33 xmegapov $
> And there's the executable.
Thanks, guess they need to have a note somewhere saying the makefile is
not in the default directory.  I got it to work, thanks again!
David
smuchrusher <at> ameritech <dot> net
ICQ#: 118347772
Uptime:  2:50pm  up 5 days, 34 min,  1 user,  load average: 5.36, 5.83, 5.99
Date: 8 Jun 2001 19:05:33
Message: <slrn9i2e83.vdt.steve@zero-pps.localdomain>
On Fri, 08 Jun 2001 15:33:26 -0500, David wrote:
>David
>ICQ#: 118347772
Yep seems to be working:-)
  9:43pm  up 126 days, 22:32,  2 users,  load average: 1.03, 1.09, 1.14
Date: 8 Jun 2001 22:06:32
Message: <8213it43e9h5atmhdbmhmpatkilc6vk9lo@4ax.com>
On Fri, 08 Jun 2001 21:26:13 +0200, Alessandro Coppo <a.c### [at] iolit>
wrote:
>Get POV3.1g sources, and copy the MegaPOV ones upon 3.1. Edit the
>Makefile, adding the files which where not present in the 3.1 build, and
>make the beast. Even without having seen POV sources before, I managed
>to have a wonderful 0.6a working on my Linux box in less than 2 hours.
Yeah, that's what I did, only automating it a bit. As I couldn't get
GCC output the list of dependencies, I diffed the ls of 3.1 and
megapov and then cut & sed it into something worth copying & pasting
into the makefile. Took me less than it took you in time but probably
twice as much in nerve.
Peter Popov ICQ : 15002700
Date: 9 Jun 2001 09:05:07
Message: <slrn9i4758.1al.steve@zero-pps.localdomain>
Strange, I didn't have any problems building it just the way it was.
I'm on RH 6.2 upgraded from 6.0.
  1:52pm  up 127 days, 14:42,  2 users,  load average: 1.01, 1.01, 1.00
Date: 9 Jun 2001 15:56:34
Message: <9sv4itcrtvp14e82752meaabjd48jaansc@4ax.com>
How?! The makefile provided doesn't include the files added in
MegaPOV.
Date: 9 Jun 2001 21:45:24
Message: <slrn9i5k7n.38u.steve@zero-pps.localdomain>
>MegaPOV.
From the makefile:
#*  Jun-99 : Modified by Mark Gordon to add make install, Linux
#*           optimization flags, -c flag to touch, platform-specific code
#*           all moved to the top.
#*  Nov-99 : More cleanup by Mark Gordon to fix install, SGI flags
#*  Dec-99 : Modified by Mark Gordon to accomodate megapatch, add all target,
#*           and bulletproof.
#*  Jan-00 : Modified by Mark Gordon to add mblur2 and postproc
Sounds like megapov stuff to me.
You are looking in the Unix direcory aren't you, (as in the example shell
commands that I posted for David)?
  2:42am  up 128 days,  3:31,  2 users,  load average: 1.02, 1.04, 1.01
Date: 12 Jun 2001 18:30:40
Message: <0v5dit462e9uop3vpj6dreiojiinhb3335@4ax.com>
On 9 Jun 2001 21:45:24 -0400, ste### [at] zeroppsuklinuxnet (Steve) wrote:
<snip>
Err, there ain't no Makefile in the source dir so yeah, I was looking
in the Unix directory.
Backtracking, I think we are talking of two different things, and it
is mostly my fault. I am talking of getting the MegaPOV 0.7 sources
from Nathan's site and extracting them over the official 3.1 sources,
and you are talking about...?
Date: 12 Jun 2001 21:43:33
Message: <slrn9idh8b.g9k.steve@zero-pps.localdomain>
><snip>
The link that I posted for David:
http://perso.enst.fr/~jberger/mpov/mpov.html
Hosted by "Jerome M Berger" I think.  Mega 0.7 for Linux.
  2:37am  up 131 days,  3:27,  2 users,  load average: 1.21, 1.10, 1.12
Date: 14 Jun 2001 15:41:42
Message: <01ehitscssdbgb578rg6qsir65tl43j1hp@4ax.com>
On 12 Jun 2001 21:43:33 -0400, ste### [at] zeroppsuklinuxnet (Steve)
So that's the one then. I knew someone had invented the wheel :)
