POV-Ray : Newsgroups : povray.unofficial.patches : uv_mapping bug? Server Time
2 Nov 2024 15:25:48 EDT (-0400)
  uv_mapping bug? (Message 1 to 5 of 5)
Subject: uv_mapping bug?
Date: 21 Aug 1999 14:09:06
Message: <1dwwklf.1g22tih19rk8nuN@dialup286.leuven.skynet.be>
Rendering a gradient with uv_mapping seems to have a bug when
using the gradient pattern: no mapping is done with gradient z ! With
gradient x and gradient y it renders fine. This is the case with the
sphere, lathe and box objects.
Rendering a bicubic_patch with uv_mapping has a problem with all
gradients. With gradient x the gradient goes in the z-direction. With
gradient y it goes in the x-direction and with gradient z no mapping is
done.
Rendering the scene below will show the problem. The top row shows
gradient x, gradient y and gradient z with the 'classic' gradient.
The bottom row shows the same gradients with uv_mapping.
//************** Scene with uv_mapping bug ? *************
// Change Obj_Switch for different objects
#declare Obj_Switch = 0; //0 =Sphere;  1= Lathe;  2= Bicubic_patch
#declare C_Map =
        color_map {
                [ 0.0 color rgb < 1.0, 1.0, 1.0 > ]
                [ 0.3 color rgb < 1.0, 1.0, 1.0 > ]
                [ 0.3 color rgb < 1.0, 0.0, 0.0 > ]
                [ 0.6 color rgb < 1.0, 0.0, 0.0 > ]
                [ 0.6 color rgb < 0.211505, 0.530358, 0.728481 > ]
                [ 1.0 color rgb < 0.211505, 0.530358, 0.728481 > ]
#if (Obj_Switch = 0)
        #declare Object = sphere  { < 0.0, 0.0, 0.0 >, 0.5 }
#if (Obj_Switch = 1)
        #declare Object =
                lathe  {
                        quadratic_spline
                        6,
                        <0.0, 0.000000 >,
                        <0.00000, 0.00645 >,
                        <0.86452, 0.09677 >,
                        <0.28387, 0.35484 >,
                        <0.24516, 0.48 >,
                        <0.00000, 1.00645 >
                        scale <0.7, 0.8, 0.7>
#if (Obj_Switch = 2)
        #declare Object =
                bicubic_patch  {
                        type 1 flatness 0.0 u_steps 4 v_steps 3
                        < -0.6, -1, 0.5 >,      < -0.33, 0.0, 0.5 >,
< 0.33 , 0.0, 0.5 >,    < 0.5, -1, 0.6 >,
                        < -0.5, 0.0, 0.33 >,    < -0.33, -0.2, 0.33 >,
< 0.33, -0.2, 0.33 >,   < 0.5, 0.0, 0.33 >,
                        < -0.5, 0.0, -0.33 >,   < -0.33, -0.2, -0.33 >,
< 0.33, -0.2, -0.33 >,  < 0.5, 0.0, -0.33 >,
                        < -0.6, -1, -0.5 >,     < -0.33, 0.0, -0.5 >,
< 0.33, 0.0, -0.5 >,    < 0.5, -1, -0.6 >
                        translate y*0.6
//Top row with classic gradient
object  {
        Object
        pigment { gradient x color_map { C_Map } scale 0.5 }
        translate <-1.3, 0.4, 0.6>
object  {
        Object
        pigment { gradient y color_map { C_Map } scale 0.5 }
        translate <0, 0.4, 0.6>
object  {
        Object
        pigment { gradient z color_map { C_Map } scale 0.5 }
        translate <1.3, 0.4, 0.6>
//Lower row with uv_mapping
object  {
        Object
        uv_mapping
        translate <-1.3, -0.6, 0>
object  {
        Object
        uv_mapping
        translate <0, -0.6, 0>
object  {
        Object
        uv_mapping
        translate <1.3, -0.6, 0>
        location < 0.0, 3, -5 >
        angle 40
        look_at < 0.0, 0.0, 0.0 >
light_source { <0, 50, -60> rgb 1.5 }
e-mail:sme### [at] skynetbe
http://users.skynet.be/smellenbergh
Subject: Re: uv_mapping bug?
Date: 21 Aug 1999 23:43:01
Message: <37BF725F.A4ECF606@Kopp.com>
It's not really a bug, just a mis-understanding.  You see, the UV-mapping
implemented here simply maps the X and Y of the texture to the U and V of
the object.  It takes a slice of the texture from the XY plane (Z=0) and
wraps that slice around the object.
Any slice of gradient z parallel to the XY plane will have a uniform color,
since the texture will only change in the z direction.
-Nathan
> done.
> #declare C_Map =
>         color_map {
> #end
>         #declare Object =
>                 lathe  {
>                         quadratic_spline
>                         6,
>                         <0.0, 0.000000 >,
>                         <0.24516, 0.48 >,
>                         <0.00000, 1.00645 >
> #end
>         #declare Object =
>                 bicubic_patch  {
>                         translate y*0.6
> #end
> object  {
>         Object
> object  {
>         Object
> object  {
>         Object
> object  {
>         Object
>         uv_mapping
> object  {
>         Object
>         uv_mapping
> object  {
>         Object
>         uv_mapping
> camera {
>         angle 40
Date: 22 Aug 1999 04:35:13
Message: <1dwxn1c.dzd38212wkyeoN@dialup45.leuven.skynet.be>
> -Nathan
Oh, I see: a mis-understanding indeed. But also a bit disappointed.
Couldn't you use a slice of the texture from the XZ plane and wrap that
around the object for gradient z (this is also true for the mandel
pattern).
Well that explains it for the sphere, lathe and box objects. But there
is still a problem with the bicubic_patch object. With gradient x the
gradient goes in the z-direction. With gradient y it goes in the
x-direction
Just render the scene below and you will see the problem.
//******** Scene with uv_mapping bug ? *************
#declare Obj_Switch = 2; //  2= Bicubic_patch
#declare C_Map =
         color_map {
         #declare Object =
                 bicubic_patch  {
                         < -0.6, -1, 0.5 >,      < -0.33, 0.0, 0.5 >,  <
                         translate y*0.6
 object  {
         Object
 object  {
         Object
 object  {
         Object
 object  {
         Object
         uv_mapping
 object  {
         Object
         uv_mapping
 object  {
         Object
         uv_mapping
         angle 40
Date: 22 Aug 1999 19:48:55
Message: <37C08CFE.EA92DB48@Kopp.com>
> pattern).
> x-direction
Guess I didn't clear up the misunderstanding completely.
With a bi-cubic patch, gradient x doesn't go in the 'z' direction, but
in the 'u' direction.  It just happens that in your scene, the surface
'u' direction is in the world 'z' direction.
The surface of an object is only 2 dimensional, whereas textures in POV
are 3 dimensional.  At some point, only one slice of the 3d texture can
be mapped to the 2d surface coordinates.
You can use the XZ plane of a texture if you want to: you simply have to
rotate the texture so that the XZ plane lies in the XY plane.
  rotate 90*x  // this should do the trick
-Nathan
Date: 24 Aug 1999 12:56:16
Message: <1dx1s7x.10gs3ef16q8esuN@dialup428.leuven.skynet.be>
> -Nathan
Thanks for the explanation. It finally makes sense.
Obviously not a bug :-) .
-smellenbergh
