POV-Ray : Newsgroups : povray.unix : Boost library requirements Server Time
23 Dec 2024 11:23:39 EST (-0500)
  Boost library requirements (Message 1 to 10 of 16)
Subject: Boost library requirements
Date: 22 Jan 2012 16:15:01
Message: <web.4f1c7b662279e06885de7b680@news.povray.org>
When I try to build the boost library, I get complaints about MPI, bzip2, and
python.  Specifically:
   ______________________________________________________________________
   warning: Graph library does not contain MPI-based parallel components.
   note: to enable them, add "using mpi ;" to your user-config.jam
       - iconv (libc)             : yes
       - icu                      : no
       - icu (lib64)              : no
       - ../config//has_gcc_visibility builds : yes
       - ../config//has_long_double_support builds : yes
   warning: skipping optional Message Passing Interface (MPI) library.
   note: to enable MPI support, add "using mpi ;" to user-config.jam.
   note: to suppress this message, pass "--without-mpi" to bjam.
   note: otherwise, you can safely ignore this message.
Plus 2 bzip2-related modules and 56 python-related modules that won't compile.
I'll keep trying to figure this stuff out (note: unless someone posts that I can
safely ignore these messages).  But first, I'm gonna watch the New England
Patriots beat the Baltimore Ravens.
Subject: Re: Boost library requirements
Date: 22 Jan 2012 16:51:33
Message: <4f1c84e5$1@news.povray.org>
>         - icu                      : no
>         - icu (lib64)              : no
well ... being as it says optional my 1st guess be that my /might/
squeak by but if it were me I'd want to resolve to before forging ahead.
As for the Pats beating the Ravens ... being as it was 13 - 10 at the
half I don't think it's going to be the cakewalk that some predicted ...
Brady seems off. The better game will be the night-cap ... Go 9ers!
Date: 22 Jan 2012 17:30:02
Message: <web.4f1c8cb59688c3d585de7b680@news.povray.org>
<offtopic>
Yeah, Brady's definitely off tonight. :-(
</offtopic>
Date: 22 Jan 2012 17:30:19
Message: <4f1c8dfb$1@news.povray.org>
Le 22/01/2012 22:11, Cousin Ricky nous fit lire :
>        - icu                      : no
>        - icu (lib64)              : no
Boost & Python ??? uh !
I thought Boost was about C++.
AFAIK, you do not need the graph library of boost for povray.
needed are hash, thread, weak_ptr, scoped_ptr, unordered_map, condition,
string algorithm, date & time, math fancies (common factor as well as
mersenne twister... and more)... but no graph.
Date: 22 Jan 2012 18:09:11
Message: <4f1c9717@news.povray.org>
> string algorithm, date&  time, math fancies (common factor as well as
hmmm ... I only managed to recall 4 from your list. What about the "and
more"? Would the work that's being done for the windows source build,
that was recently checked in be helpful in completing this list? I think
this comes under the heading of good to know information, and I'd be
willing to do the busy work
Date: 22 Jan 2012 18:30:40
Message: <4f1c9c20@news.povray.org>
Le 23/01/2012 00:09, Jim Holsenback nous fit lire :
I just did a quick (and very dirty) :
grep -r boost . |grep include |sed -e "s/^.*://g" |sort |sort -u
(and it has still many rubbishes) on the sources... I'm not sure to
identify all the primary components of boost (vs the subtilities of
smaller components; I'm not that familiar with their packaging)
Date: 22 Jan 2012 20:30:00
Message: <web.4f1cb7bd9688c3d585de7b680@news.povray.org>
I added "using mpi ;" to my user-config.jam.  I got back:
   ________________________________________________________________________
   MPI auto-detection failed: unknown wrapper compiler mpic++
   Please report this error to the Boost mailing list: http://www.boost.org
   You will need to manually configure MPI support.
I don't like getting messages like this. >:-(
Date: 23 Jan 2012 02:15:40
Message: <4f1d091c$1@news.povray.org>
AFAIK, you do not need MPI (optimisation of code by compiler applied to
sequential code to use parallelism when available and triggered by the
code itself). The parallelism of povray 3.7 is explicit, using threads.
Otherwise, you should install "Open MPI" to get with the installation of
mpic++ (which is a wrapper on your usual c++ compiler, so if your g++ is
out of date, that will be yet another story)
http://www.open-mpi.org/
Date: 23 Jan 2012 15:10:00
Message: <web.4f1dbd7c9688c3d585de7b680@news.povray.org>
I went ahead with the POV installation and got back:
   [snip]
   checking for g++ version... 4.6
   checking for ranlib... ranlib
   Libraries
   checking whether to link with cygwin DLL... no
   checking whether to enable static linking... no
   checking for the pthreads library -lpthreads... no
   checking whether pthreads work without any flags... no
   checking whether pthreads work with -Kthread... no
   checking whether pthreads work with -kthread... no
   checking for the pthreads library -llthread... no
   checking whether pthreads work with -pthread... yes
   checking for joinable pthread attribute... PTHREAD_CREATE_JOINABLE
   checking if more special flags are required for pthreads... no
   checking for boostlib >= 1.37... yes
   checking whether the Boost::Thread library is available... yes
   checking for exit in -lboost_thread... yes
   checking whether the boost thread library is usable... no
   configure: error: in `/home/ricky/povray/povray-3.7.0.RC3':
   configure: error: cannot link with the boost thread library
   See `config.log' for more details.
No complaints about MPI, Bzip2, or Python in the config.log file.  Whatever the
problem is, it appears to be in the Boost installation, or lack thereof.
Tried that, got the same message from Boost installation.
Date: 23 Jan 2012 15:40:01
Message: <web.4f1dc48d9688c3d585de7b680@news.povray.org>
Additional information from config.log:
_____________________________________________________________________________
configure:7645: checking whether the boost thread library is usable
configure:7665: g++ -o conftest  -pthread  -pthread -I/usr/local/include
-L/usr/local/lib conftest.cpp -lboost_thread  -pthread  >&5
configure:7665: $? = 0
configure:7665: ./conftest
../conftest: error while loading shared libraries: libboost_thread.so.1.48.0:
cannot open shared object file: No such file or directory
configure:7665: $? = 127
configure: program exited with status 127
configure: failed program was:
| /* confdefs.h */
| #define PACKAGE_NAME "POV-Ray"
| #define PACKAGE_TARNAME "povray"
| #define PACKAGE_VERSION "3.7.0.RC3"
| #define PACKAGE_STRING "POV-Ray 3.7.0.RC3"
| #define PACKAGE_BUGREPORT "REDACTED"
| #define PACKAGE_URL ""
| #define VERSION_BASE "3.7"
| #define DISTRIBUTION_MESSAGE_2 " Richard Callwood III <REDACTED>"
| #define PACKAGE "povray"
| #define VERSION "3.7.0.RC3"
| #define STDC_HEADERS 1
| #define HAVE_SYS_TYPES_H 1
| #define HAVE_SYS_STAT_H 1
| #define HAVE_STDLIB_H 1
| #define HAVE_STRING_H 1
| #define HAVE_MEMORY_H 1
| #define HAVE_STRINGS_H 1
| #define HAVE_INTTYPES_H 1
| #define HAVE_STDINT_H 1
| #define HAVE_UNISTD_H 1
| #define BUILD_ARCH "i686-pc-linux-gnu"
| #define COMPILER_VENDOR "gnu"
| #define COMPILER_VERSION "g++ 4.6"
| #define COMPILER_VER " (g++ 4.6 @ i686-pc-linux-gnu)"
| #define HAVE_PTHREAD 1
| #define HAVE_BOOST /**/
| #define HAVE_BOOST_THREAD /**/
| /* end confdefs.h.  */
| #include <boost/thread/thread.hpp>
| int
| main ()
| boost::defer_lock_t(); return 0;
|   return 0;
configure:7670: result: no
configure:7672: error: in `/home/ricky/povray/povray-3.7.0.RC3':
configure:7675: error: cannot link with the boost thread library
From the bash terminal session:
________________________________________________________________________________
linux-g9n0:/usr/local/boost_1_48_0 # find /usr -name 'libboost_thread*' -print
/usr/local/boost_1_48_0/stage/lib/libboost_thread.a
/usr/local/boost_1_48_0/stage/lib/libboost_thread.so
/usr/local/boost_1_48_0/stage/lib/libboost_thread.so.1.48.0
/usr/local/boost_1_48_0/bin.v2/libs/thread/build/gcc-4.6/release/link-static/threading-multi/libboost_thread.a
/usr/local/boost_1_48_0/bin.v2/libs/thread/build/gcc-4.6/release/threading-multi/libboost_thread.so.1.48.0
/usr/local/lib/libboost_thread.a
/usr/local/lib/libboost_thread.so
/usr/local/lib/libboost_thread.so.1.48.0
/usr/lib/libboost_thread.so.1.46.1
