POV-Ray : Newsgroups : povray.unix : Need Help With Running POV-Ray Through PHP Server Time
28 Mar 2026 22:27:34 EDT (-0400)
  Need Help With Running POV-Ray Through PHP (Message 1 to 10 of 15)
Subject: Need Help With Running POV-Ray Through PHP
Date: 10 Mar 2011 11:10:00
Message: <web.4d78f406f7eba3343530d40@news.povray.org>
I'm working on a project that involves writing input from a text box to a POV
file, running POV-Ray (version 3.6.1) through a UNIX shell via a website and
outputting the resulting PNG file. Here is the code I have so far:
<?php
//Code for writing to a file
$input = $_POST['input'];
$file = "object.pov";
$save = fopen($file, 'w');
fwrite($save, $input);
fclose($save);
//Code for executing a shell command
system("povray object.pov");
<form method="post" action="write_test.php">
<textarea name="input" rows="10" cols="61">
</textarea>
<input type="submit" name="button" value="Write" />
</form>
<img src="object.png"/>
I've tried using shell_exec(), exec(), and system() to render a test file, but
it doesn't seem to work from the test PHP webpage I'm using. Oddly enough, it
works when I run the PHP script through the shell.
Also, when I tried running it through system() with a return value variable, I
got a return value of 1, which I think means there's an error.
I'm not sure if this detail is important, but in order to write to the POV file,
I had to change the file permission code to 666. I wouldn't think the file
permissions would be causing this problem, but maybe it actually is and I'm just
not realizing it.
So, is there something else I should be doing to get this to work? Is it even
possible to run POV-Ray through PHP?
Subject: Re: Need Help With Running POV-Ray Through PHP
Date: 10 Mar 2011 13:43:08
Message: <4d791bbc@news.povray.org>
> file, but it doesn't seem to work from the test PHP webpage I'm
> using. Oddly enough, it works when I run the PHP script through the
> shell.
   I've used it with shell_exec(), but IIRC, I had to call povray with
the full path (/usr/local/bin/povray in my case).
Jaime Vives Piqueres
http://www.ignorancia.org
Date: 10 Mar 2011 13:54:47
Message: <4d791e77@news.povray.org>
Le 10/03/2011 17:06, Jess nous fit lire :
> not realizing it.
Do you own the webserver ?
Does the webserver run in a chroot ?
Are you aware that php get a property "max_execution_time" which would
limit the time available...
can you provide the phpinfo() ? (or check it yourself)
For instance, with safe_mode on, only binary in safe_mode_exec_dir would
get allowed.
Is povray inside the php-path ? (or would you provide the full path
instead ? (hint: if chroot, beware to use the right value!)
Have you turn off the display of povray (trying to open a X11 display is
a bad idea when launched from script)
What about instead of dynamic rendition, have a render farm:
 * The web page create the file.pov in a directory (automatic naming).
 * a demon scan the directory and run povray for the new file (moving
the file from "./to_render" to "./in_progress".
 * when the image is finished in "./in_progress", both the pov & image
are moved to "./done"
 * the submission page returned a page with refresh and the img src=link
to "./done/" image... when ready, it appears.
You might also want some automatic clean up...
Date: 10 Mar 2011 16:30:00
Message: <web.4d7941ad594502e220f89e740@news.povray.org>
> > shell.
>    Regards,
> La Persistencia de la Ignorancia
I tried using shell_exec('usr/bin/povray object.pov'), but it still doesn't
work.
Thanks for the suggestion, though.
Date: 11 Mar 2011 01:25:01
Message: <web.4d79bf17594502e23530d40@news.povray.org>
> get allowed.
I don't know if the web server is running on chroot, but I did find that the
server's PHP installation has a max_execution_time of 30 and safe mode is off.
POV-Ray isn't in the PHP path, but running it from the file path
(/usr/bin/povray) didn't help.
Date: 11 Mar 2011 05:56:10
Message: <4d79ffca$1@news.povray.org>
> that the server's PHP installation has a max_execution_time of 30 and
> safe mode is off.
   Did you try Jerome advice to turn off the display? ...I assumed you
were turning it off already, but now I don't see the -d switch on your
system call.
   Additionally, you can write the streams to a file to try to spot the
problem (see output options on the docs).
Date: 11 Mar 2011 16:00:00
Message: <web.4d7a8cc5594502e23530d40@news.povray.org>
> system call.
I didn't try turning off the display until today, but that also didn't work.
Date: 11 Mar 2011 16:35:22
Message: <4d7a959a$1@news.povray.org>
Le 11/03/2011 21:57, Jess nous fit lire :
How does "povray --benchmark" perform from your webserver/php ?
(and directly from command line ?)
Date: 12 Mar 2011 02:00:05
Message: <web.4d7b196f594502e27a0819aa0@news.povray.org>
The benchmark render took 22 minutes to complete from the command line, but
didn't work at all from PHP (running it with system still gives me a return
value of 1, which I found out is a generic error code).
Date: 12 Mar 2011 05:06:50
Message: <4d7b45ba$1@news.povray.org>
Le 12/03/2011 07:57, Jess nous fit lire :
Ok, time to switch povray for a hello_world program then.
(i.e. write & compile a hello_world program, and get it called from
shell then php/webserver.
 1. Does it work the same ? (does it fail the same way ?)
 2. second level debugging: add more printf in the the hello program to
display:
 * all the arguments/parameter (including argv[0]),
 * process id ( getpid() )
 * user id (both real & effective : getuid(), geteuid() )
 * current directory ( getcwd() or get_current_dir_name() )
 * perform some i/o operation on the disk (like opendir("/tmp"), and
display all entries ? compare with actual content of /tmp)
Something like that:
#include <sys/types.h>
#include <dirent.h>
int main(int argc,char**argv)
	int ii;
	DIR* tmpdir;
	struct dirent *entry;
	printf("Hello, world\n");
	for(ii=0;ii<argc;ii++)
		printf("arg %d : \"%s\"\n",ii,argv[ii]);
	printf("This is pid %d\n",getpid());
	printf("Run as user %d (effective %d)\n",getuid(),geteuid());
printf("The current directory is : %s\n",get_current_dir_name());
	tmpdir=opendir("/tmp");
	printf("Opendir /tmp returned: %p\n",tmpdir);
	if (tmpdir)
		do
			entry = readdir(tmpdir);
			if (entry)
				printf("Filename %s\n",entry->d_name);
		} while (entry);
		ii=closedir(tmpdir);
		printf("Closedir returned %d\n",ii);
	return 0;
