![](/i/fill.gif) |
"zounds!" <nomail@nomail> wrote:
> Hi,
> I just installed povray-3.6 on Fedora Core 2 and everything works fine
> except that when i installed it none of the links it put in my kde menu
> had icons. I tried removing it with kmenueditor then reinstalling povray
> but now it wont put anything in my menu at all:( I guess its not that big
> a deal but if anyone could stear me towards the solution to this problem
> that would be great.
> Thanks.
to set up the KDE-Entries, you must run the install-script with the
KDE-parameter:
../install kde
If it fails, run
../install kde 2&>error2.txt
../install kde 1&>error1.txt
Then please post the content of error1.txt and error2.txt
Concerning the icons:
the Icons might be incompatible with your theme or KDE-Version.
The installer tries to copy them to
/home/user/.kde/share/icons
You can change/add Icons in kmenuedit, if there are not set up correctly.
Greets, Mark
Greets, Mark
![](/i/fill.gif) |
![](/i/fill.gif) |
This Mail-system corrupts the mails a little bit, it sets too many dots
It should be like this (without the ">"):
> KDE-parameter:
> ./install kde
> If it fails, run
![](/i/fill.gif) |
