...made just for fun :)
Ten compilations of povray. Two scenes.
Test files:
benchmark.pov (from tarball)
http://www.irtc.org/ftp/pub/stills/2003-10-31/forget.zip
(using default benchmark.ini file for both)
System :
Fedora Core 5
Linux shodan 2.6.17.11 #1 Mon Sep 4 19:44:27 CEST 2006 i686 i686 i386 GNU/Linux
1GB RAM
povray started with 'nice -n -15'
Processor :
vendor_id : GenuineIntel
cpu family : 15
model : 2
model name : Intel(R) Pentium(R) 4 CPU 1.80GHz
stepping : 4
cpu MHz : 2259.249
cache size : 512 KB
cpuid level : 2
bogomips : 4522.53
Compilers:
0-8: gcc version 4.1.1 20060525 (Red Hat 4.1.1-1)
9: icpc (ICC) 9.1 20060816
Options:
0: guessed by autoconf
1: -O3 -march=i386
2: -O3 -march=i686
3: -O3 -march=pentium4
4: -O3 -march=pentium4 -msse2
5: -O3 -march=pentium4 -msse2 -mfpmath=sse
6: -O3 -march=pentium4 -msse2 -mfpmath=sse,387
7: -O3 -march=pentium4 -msse2 -mfpmath=sse,387 -malign-double
8: -O3 -march=pentium4 -msse2 -mfpmath=sse -malign-double \
-minline-all-stringops -ffast-math -fomit-frame-pointer \
-funroll-loops -fexpensive-optimizations -foptimize-sibling-calls
9: -O3 -axN -no-prec-div -march=pentium4 -mcpu=pentium4 -msse2 \
-mtune=pentium4 -funroll-loops -fomit-frame-pointer -static
[benchmark.pov]
Results - povray stats:
0: 56/484 (photon/render time)
1: --/---
2: 57/497
3: 54/494
4: 54/493
5: 55/489
6: 60/517
7: 60/511
8: 54/459
9: 45/402
Results - system stats:
0: 534.69 (user time)
1: ---.--
2: 550.68
3: 544.73
4: 542.62
5: 540.86
6: 574.55
7: 567.52
8: 508.61
9: 439.43
[forget.pov]
0: 1546 (render time)
1: ----
2: 1576
3: 1607
4: 1607
5: 1575
6: 1643
7: 1628
8: 1489
9: 1357
0: 1531.61 (user time)
1: ----.--
2: 1566.20
3: 1593.16
4: 1592.38
5: 1561.18
6: 1628.48
7: 1613.31
8: 1462.09
9: 1332.42
Well... I think, next week I'll check changes between this all images :>
Slawek
\__ \__ \_______________________________________________________________
/___/___/ Slawomir Szczyrba steev/AT/hot\dot\pl
> ....made just for fun :)
... or for speed!
(If only I had the time to write the article summarizing the bench results
for the *hundreds* of binaries I have prepared so far...)
FWIW these are basically the compilers that are used to prepare the x86_64
and x86 versions of the Linux 3.7.0.beta.15, respectively :-)
- NC
According to my own tests some of those options actually slow down
POV-Ray instead of speeding it up. Adding a new optimization option does
not always mean that the binary will be faster.
My own experiments show that this combination gives the fastest binary,
at least in a pentium4:
-O3 -march=pentium4 -ffast-math -mfpmath=sse -msse2 -funroll-loops
-ftsp-ordering
Houston, we got a Warp...
> -ftsp-ordering
Well, my compiler doesn't know this option :)
[steev]/tmp# gcc -ftsp-ordering hello.c
cc1: error: unrecognized command line option "-ftsp-ordering"
[steev]/tmp# icc -ftsp-ordering hello.c
icc: Command line warning: ignoring unknown option '-ftsp-ordering'
________
That's because it's been removed in the latest gcc series (IIRC 3.4.x inclusive).
- NC
inclusive).
It doesn't matter anyways. It only gave a very minimal speedup.
Speed... kills... ;)
Well, '-unroll-loops' kills. Images. :)
'Benchmark' results + images + differences between images...
< http://shodan.selfip.net/~steev/pov/ >
________
_/ __/ __/
If I understand your results correctly, the left image is that produced
by the binary compiled with the specified options, the middle image is the
difference-image with a reference (presumably calculated with the official
binary for Linux?) and the right image is the inverted difference. Correct?
From you results it seems that it's actually -ffast-math that changes the
result of the top-left corner (your last test shows that -funroll-loops does
produce a correct image). But what is really strange is your second result:
a distorted image is also produced with -march=i686 ??? Hard to believe...
In any case, on an Intel Pentium 4 or higher processor, it is clear again
that one should use ICC to compile POV from sources.
- NC
S?awomir Szczyrba wrote:
> BOFH excuse 72: S?awomir Szczyrba did it
It is perfectly expected that there are slight difference. The huge
difference is precision bug in your math library though. It should not occur
with a standard(s) conforming library.
Thorsten
I think the base image is wrong.
I just tried benchmark.pov in my system, with povray compiled with
and it rendered correctly.
There must be something odd with either your version of gcc or your
system libraries or something.
