![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Ho,
with ditor has both higlights -and- tab-completition?
Like win32 editor, I type lighTAB and I get light_group,
camTAB gives camera, and so on.
Perhaps a way to do it in vim?
http://www.raf256.com/3d/
Computer Graphics
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
vim has keyword completion
^n and ^p complete a token by matching against tokens in the file
after/before the one you're currently typing.
^x^v might be more useful: it completes by picking a word from a
dictionary file; the location of the dictionary is user-definable and
could be set to a file containing a list of SDL keywords.
^n/^p completion can be redefined using the 'complete' option to look in
a particular dictionary file: you could have your SDL
syntax-highlighting script modified to do just that.
Actually, it would be rather nice if it would do it automatically using
the keywords defined in the syntax file. Ah well.
see :help ins-completion for more details.
Daniel
A church is more than just timber and stone .oO( surreal.istic.org )
And freedom is a dark road when you're walking it alone -Paul Simon,
But the future is now, and it's time to take a stand 'A Church
So the lost bells of freedom can ring out in my land. is Burning'
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
QTPov Editor has many functionnalities, including syntax highlightning
and keyword completion .. (if you want to use it, dont forget to
download the ressources package and take a look at the help files
incuded in it)
Thierry
> Ho,
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> Ho,
Heard of Qtpov, heard of Vim... Switch to emacs now... I think this is
working in the standard pov-mode (maybe not with the bindings you want,
bu reassigning a binding is not such a great work, is it?). If not, you
juste found a great reason to do some lisp-hacking :-)
Other Great feature for povmode in emacs :
* auto indenting
* paren matching
* squeleton definition
By the way, I use emacs for both my linux boxes and for my windows
computer... Feel free to ask
Bruce
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
"Bruce" <flo### [at] nospam free fr> wrote in message
news:41aefabc@news.povray.org...
> > Ho,
> * auto indenting
> * paren matching
> Bruce
Love emacs for pov editing. Never found out how to do keyword completion for
any mode though. As for lisp hacking, bleh!
So, how would one do keyword completion in emacs?
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
By default i think it is linked to the <ALT>-<TAB> key combination but
since this is usually caught by the system for other purposes you should
choose something different - by adding something like:
(define-key pov-mode-map "\M-\r" 'pov-complete-word)
to your ~/.emacs or ~/.xemacs/init.el or whatever init file you use.
The above line makes the <ALT>-<RETURN> combination do the completition.
Note emacs pov-mode completition is much more powerful than in WinPOV
since it is context sensitive (it only completes keywords that are
allowed in the current context).
Last updated 23 Sep. 2004 _____./\/^>_*_<^\/\.______
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
"Christoph Hormann" <chr### [at] gmx de> wrote in message
news:copma4$ch2$1@chho.imagico.de...
for
> Christoph
Thanks, i'll try this tonight.
I was wondering yesterday about if it would be possible to dynamically
create lists of words that it emacs can complete. For instance if I #define
myBigObject = union {...} could emacs somehow pick up "myBigObject" as an
available keyword for completion.
surely impossible without any lisp knowledge.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
If emacs has tags support (which it surely must) then you can do it
without any LISP: you just write a program (like ctags) which looks at
the file and works out what the definitions are.
I know vim has support for this: ^X^] does completion by tag, if you
have it turned on. Even without tags, vim will complete based on past
words in the document when you press ^p; emacs probably has a similar
feature, though I wouldn't know about that :->
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
This may not work in your .emacs, as pov-mode is not started when emacs
is launched. You should probably do it as a lambda function on the right
hook
(pov-mode-hook (quote (lambda nil
(define-key pov-mode-map [(control c) (control i)] (quote
pov-complete-word)))))
No work to be done : there's a function caled dabbrev which
automatically completes with the word which have previously been typed
in your buffer
(global-set-key [(f8)] 'dabbrev-completion)
For more information and knowing the difference between dabbrev-expand
and dabbrev-completion (not exactly the same behaviour), use C-h a
dabbrev [return]
(C-h => help, a => regexp search)
Note : this is bundled in my xemacs installation, but I think I had to
install it on fsf emacs. Some google(ing will probably tell you where
you can find it
Emacs has so many packages that almost everuthing is possible without
any lisp hacking (except for configuration purposes, but can we REALLY
name it hacking?)
Enjoy and have fun!
Bruce
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
news:41bac592$1@news.povray.org...
> hook
#define
an
> in your buffer
> dabbrev [return]
> you can find it
> name it hacking?)
> Enjoy and have fun!
> Bruce
pretty neat. thanks for the info.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
