POV-Ray : Newsgroups : povray.unix : Compile for given CPU Server Time
7 Apr 2026 13:21:24 EDT (-0400)
  Compile for given CPU (Message 1 to 10 of 10)
Subject: Compile for given CPU
Date: 15 Jun 2004 12:30:33
Message: <Xns9509BBE4C7718raf256com@203.29.75.35>
how can I recompile PovRay for optimal speed on my machine?
I'm using an athlon (2.6 GHz).
Can I pass some heavy-optimize options to compiler etc?
http://www.raf256.com/3d/
Computer Graphics
Subject: Re: Compile for given CPU
Date: 15 Jun 2004 13:08:00
Message: <40cf2cf0@news.povray.org>
"Rafal 'Raf256' Maj" <spa### [at] raf256com> wrote in message
news:Xns9509BBE4C7718raf256com@203.29.75.35...
> Hi,
> Rafal Maj 'Raf256', home page - http://www.raf256.com/me/
> Computer Graphics
to start, you could try (assuming gcc):
-O3 -DCPU=athlon -march=athlon
for more info, check the man or info pages for gcc. they have an
"optimization" section. check out "-finline-functions" and "-funroll-loops"
maybe more.
Date: 15 Jun 2004 13:09:21
Message: <40cf2d41$1@news.povray.org>
> Hi,
ah, see here too:
http://news.povray.org/povray.unix/message/%3C3d4c3ca2%40news.povray.org%3E/#%3C3d4c3ca2%40news.povray.org%3E
Date: 15 Jun 2004 13:47:09
Message: <40cf361d@news.povray.org>
Assuming gcc-3.4.0:
> -O3
        Correct,
> -DCPU=athlon
        not useful at all for the povray-3.50c Unix source,
> -march=athlon
        probably "-march=athlon-xp -mtune=athlon-xp" could be
more suited, and also maybe "-msse" and, as reported elsewhere,
"-mfpmath=sse,387" (but use this one with care).
        not useful since automatically turned on by -O3,
> "-funroll-loops"
        do _not_ use this one, as it will most likely make the
code slower,
> maybe more.
        eventually "-malign-double" "-minline-all-stringops" but there is
no evidence yet that they would actually improve efficiency.
        - NC
Date: 15 Jun 2004 14:01:37
Message: <40cf3981@news.povray.org>
>> maybe more.
        I was told recently that using profiling-guided optimization could
also somewhat increase performance on Athlon's.  To do so, you have to
compile an intermediate binary using "-fprofile-arcs", then run a
(representative) set of povray scenes, and recompile again this time
with "-fbranch-probabilities" instead of the option above.
        Personnaly I had some oddities doing so with gcc-3.4.0 on the
current POV-Ray 3.6 sources, and the speedup was also negligible.
        - NC
PS: you'd better not use "-ffast-math" which might be a problem with
e.g. radiosity (untested though).
Date: 15 Jun 2004 15:35:02
Message: <canj0j$fua$1@chho.imagico.de>
Nicolas Calimet wrote:
>>>maybe more.
With gcc 3.4.0 you can use profiling based optimizations with
-fprofile-generate and -fprofile-use.
Last updated 01 May. 2004 _____./\/^>_*_<^\/\.______
Date: 15 Jun 2004 17:19:35
Message: <40cf67e7@news.povray.org>
You have the 3.6 sources??
About profiling, the gcc team say that using profiling may speed up the gcc
compiler by about 7% (the profiled compiled compiler is 7% faster :-)
Personally I never got any conclusive evidence that profiled binaries work
faster, but probably it depends on the apllication and on the relevance of
gathered data in the intermediate phase.
Anyway, here are my optimize flags for gcc:
-O3 -fno-exceptions -fno-rtti -fno-check-new -fomit-frame-pointer
(does -O3 implies any of them?)
-funroll-loops (if this slows down depends on the available cache)
-march=pentium4 -mfpmath=sse -msse -msse2 -mmmx
-ffast-math -fno-math-errno -funsafe-math-optimizations -fno-trapping-math
(may be unsafe, certainly not IEEE fp compatibles)
-foptimize-sibling-calls -malign-double -minline-all-stringops
All in all, I am not sure I get better results with any combination of them
than with the plain old -O3 alone.
Using the Intel C Compiler (icc free linux version for non-commercial use)
does not gain anything. using 'icc -O3 -Ob2 -mcpu=pentiumpro -xK
-march=pentiumiii -tpp6 -unroll -ipo -pch -fno-rtti -align' I obtain the
same rendering times as with the gcc binary...
My opinion is that -O3 is the safe bet, more options may gain 3% speed but
to what purpose? 8 or 8.5 seconds is the same for a short rendering, and 72
hours is the same with 73 hours for a long rendering.
But between -O2/-O and -O3 there are important speed differences.
Replay-to address is fake. Please replace it
with mferecat (at) numericable (dot) fr.
Date: 17 Jun 2004 07:21:23
Message: <40d17eb3$1@news.povray.org>
	Ah, that's probably why I had glitches using the other flags.
	Thanks, I'll try these out.
	- NC
Date: 17 Jun 2004 19:18:44
Message: <40d226d4$1@news.povray.org>
>>Hi,
>>Computer Graphics
> maybe more.
Look into the environment variable CFLAGS. I set it to -arch=pentium4
-mcpu=pentium4 -O3. I compile most of my software and it really goes
faster with optimization.
Shalom
Date: 20 Jun 2004 05:04:53
Message: <40d55335@news.povray.org>
In article <40cf67e7@news.povray.org> , mf <nos### [at] nossppaammorg>  wrote:
Did you ever take a look at your binary version of 3.6; in particular the
author message output? - it is usually that those who prepare a platforms'
distribution have access to the source code... ;-)
    Thorsten
e-mail: tho### [at] trfde
