POV-Ray : Newsgroups : povray.unix : Compiling POV-Ray 3.7, second attempt Server Time
15 Jul 2025 22:40:39 EDT (-0400)
  Compiling POV-Ray 3.7, second attempt (Message 1 to 10 of 26)
Subject: Compiling POV-Ray 3.7, second attempt
Date: 3 Jul 2015 19:20:19
Message: <559718b3$1@news.povray.org>
Hi(gh)!
After replacing my entire previous Linux installation by Debian 7.8
"wheezy", I once more tried to compile POV-Ray 3.7... now, all
additional packages recommended in unix/README.md were installed without
any errors. When I started the prebuild.sh script, all worked well -
except for one final error message:
config.status: error: cannot find input file: `Makefile.in'
I thought that make was not installed yet, so I did this and afterward
typed "make" (like read under "Generating configure and building the
code" in README.md) - but this also just resulted in an error message:
make: *** Keine Targets angegeben und keine »make«-Steuerdatei gefunden.
  Schluss.
(which is in English:
make: *** No targets stated and no »make« directive file found. Ending.)
How do I get rid of the config.status error?
See you in Khyberspace!
Yadgar
Subject: Re: Compiling POV-Ray 3.7, second attempt
Date: 3 Jul 2015 23:59:55
Message: <55975a3b$1@news.povray.org>
Am 04.07.2015 um 01:20 schrieb "Jörg \"Yadgar\" Bleimann":
> Hi(gh)!
Quite obviously, all worked /not/ well. You might want to double-check
the output messages - I guess they do report /some/ error or warning. At
any rate you don't seem to be reporting the exact symptoms, as
"config.status" doesn't come into play until the "./configure" step.
What version of POV-Ray 3.7 are you trying to build?
3.7.0 stable release, for instance, is known to not configure properly
with new versions of automake, causing secondary error messages similar
to the one you're reporting.
Date: 4 Jul 2015 06:50:41
Message: <5597ba81$1@news.povray.org>
Hash: SHA256
>> Hi(gh)!
>> 7.8 "wheezy", I once more tried to compile POV-Ray 3.7... now,
>> all additional packages recommended in unix/README.md were
>> installed without any errors. When I started the prebuild.sh
>> script, all worked well - except for one final error message:
> double-check the output messages - I guess they do report /some/
> error or warning. At any rate you don't seem to be reporting the
> exact symptoms, as "config.status" doesn't come into play until the
> "./configure" step.
> properly with new versions of automake, causing secondary error
> messages similar to the one you're reporting.
Well spotted. To build 3.7.0 stable, which is likely due to the
message about "Makefile.in", a workaround on modern system is:
1. in unix directory: ./prebuild.sh
2. in root directory: automake --add-missing
3. in unix directory: ./prebuild.sh
then continue as usual.
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v2
iJwEAQEIAAYFAlWXuoAACgkQhKAm8mTpkW3VCwP/SNTKj7MUPnJCg7nf22MUW8dv
Q2Gqdh5eXCgFTWJ36HbpfnJVxMCnN80dwv7e7rCIpwMtlHiNYsFAvuqUbbx6NPfF
QtqeJIKsyAQvbWrbdSHJKJ3K65F0AYFCche9XGN1+fLloONXHJyTX7bMypv2Ztkm
x/ojaMbJvJsdSXTu2P4=
=MQ2E
-----END PGP SIGNATURE-----
Date: 4 Jul 2015 18:14:26
Message: <55985ac2@news.povray.org>
Hi(gh)!
O.k., here is the output of prebuild.sh:
root@debian:/media/Raytracing/povray-3.7-stable/unix# ./prebuild.sh
Detected autoconf 2.69
Detected automake 1.11.6
Create ../AUTHORS
Create ../ChangeLog
Create ../configure.ac
Create ../COPYING
Create ../NEWS
Create ../README
Create ../VERSION
Create ../povray.1
Create ../povray.conf
Create ../scripts/
Create ../ini/
Create ../include/
Create ../scenes/
Create ../INSTALL
Create ../icons/file_inc_classic_16.png
Create ../icons/file_inc_crystal_16.png
Create ../icons/file_inc_slick_64.png
Create ../icons/file_inc_slick_32.png
Create ../icons/file_pov_classic_64.png
Create ../icons/file_inc_crystal_64.png
Create ../icons/file_inc_classic_48.png
Create ../icons/file_pov_classic_16.png
Create ../icons/file_inc_slick_16.png
Create ../icons/file_pov_crystal_64.png
Create ../icons/povray_16.png
Create ../icons/file_inc_classic_32.png
Create ../icons/povray_48.png
Create ../icons/file_inc_classic_64.png
Create ../icons/file_pov_classic_48.png
Create ../icons/file_pov_slick_48.png
Create ../icons/file_pov_crystal_16.png
Create ../icons/povray_32.png
Create ../icons/file_pov_slick_32.png
Create ../icons/file_inc_slick_48.png
Create ../icons/file_pov_crystal_32.png
Create ../icons/file_inc_crystal_48.png
Create ../icons/file_pov_slick_64.png
Create ../icons/file_inc_crystal_32.png
Create ../icons/file_pov_crystal_48.png
Create ../icons/file_pov_slick_16.png
Create ../icons/povray_64.png
Create ../icons/file_pov_classic_32.png
Create ../doc/html
Create ./Makefile.am
Create ../kde_install.sh
Create ../povray.ini.in
Create ../Makefile.am
Create ../bootstrap
Create ../source/Makefile.am
Create ../vfe/Makefile.am
Run ../bootstrap
+ rm -f config.log config.status
+ aclocal -I .
configure.ac:302: warning: AC_LANG_CONFTEST: no AC_LANG_SOURCE call
detected in body
../../lib/autoconf/lang.m4:193: AC_LANG_CONFTEST is expanded from...
../../lib/autoconf/general.m4:2590: _AC_COMPILE_IFELSE is expanded from...
../../lib/autoconf/general.m4:2606: AC_COMPILE_IFELSE is expanded from...
../../lib/m4sugar/m4sh.m4:639: AS_IF is expanded from...
../../lib/autoconf/general.m4:2031: AC_CACHE_VAL is expanded from...
../../lib/autoconf/general.m4:2052: AC_CACHE_CHECK is expanded from...
unix/config/ax_boost_thread.m4:32: AX_BOOST_THREAD is expanded from...
configure.ac:302: the top level
+ autoheader --warnings=all
detected in body
+ automake --warnings=all
detected in body
+ autoconf --warnings=all
configure.ac:295: warning: The macro `AC_LANG_SAVE' is obsolete.
configure.ac:295: You should run autoupdate.
../../lib/autoconf/lang.m4:125: AC_LANG_SAVE is expanded from...
unix/config/acx_pthread.m4:78: ACX_PTHREAD is expanded from...
configure.ac:295: the top level
configure.ac:295: warning: The macro `AC_LANG_C' is obsolete.
../../lib/autoconf/c.m4:72: AC_LANG_C is expanded from...
configure.ac:295: warning: The macro `AC_TRY_LINK' is obsolete.
../../lib/autoconf/general.m4:2687: AC_TRY_LINK is expanded from...
configure.ac:295: warning: The macro `AC_LANG_RESTORE' is obsolete.
../../lib/autoconf/lang.m4:134: AC_LANG_RESTORE is expanded from...
detected in body
+ cat ./configure
+ sed -e s,configure.gnu  --help=recursive,& --srcdir=$ac_srcdir,g -e
s,\(cd \)\($ac_\)\(pop\)*\(dir\),\1"\2\3\4",g -e
s,$am_aux_dir/missing,\\"$am_aux_dir\\"/missing,g
+ mv -f ./configure.tmp ./configure
+ chmod +x ./configure
+ rm -f -r ./autom4te.cache
3.7.0 stable, as documented here:
https://github.com/POV-Ray/povray/tree/3.7-stable
Yadgar
Date: 4 Jul 2015 18:17:23
Message: <55985b73$1@news.povray.org>
Hi(gh)!
Does not work with me... I got:
automake: `configure.ac' or `configure.in' is required
Perhaps my system is not modern enough...
Yadgar
Date: 4 Jul 2015 20:30:46
Message: <55987ab6@news.povray.org>
Am 05.07.2015 um 00:14 schrieb "Jörg \"Yadgar\" Bleimann":
> detected in body
That's pretty unusual AFAIK, and might be related to the problems.
Date: 7 Jul 2015 13:07:19
Message: <559c0747$1@news.povray.org>
Hi(gh)!
>> detected in body
And now? I have no clue about all that... will I ever be able to compile
POV-Ray 3.7 on my own?
Yadgar
Date: 7 Jul 2015 21:41:22
Message: <559c7fc2$1@news.povray.org>
Am 07.07.2015 um 19:07 schrieb "Jörg \"Yadgar\" Bleimann":
> Hi(gh)!
>>> detected in body
Don't know - my Linux expertise ends here. I'm a Windows jockey after
all, and I have no Debian installation at my disposal to dig deeper into
the issue.
Date: 8 Jul 2015 02:09:30
Message: <559cbe9a$1@news.povray.org>
Le 05/07/2015 00:17, "Jörg \"Yadgar\" Bleimann" a écrit :
> Hi(gh)!
you ran it as a sequence, right ?
And when stating "root" directory, I meant the root of the source tree
of povray ( so, it's the "." of "./unix", not the "/" )
Date: 8 Jul 2015 06:54:55
Message: <559d017f$1@news.povray.org>
Hi(gh)!
O.k., second try...
Now it generally worked, but with automake, I got one warning:
detected in body
Yadgar
