POV-Ray : Newsgroups : povray.unix : Problem while trying to install libjpeg8-dev Server Time
15 Jul 2025 22:40:41 EDT (-0400)
  Problem while trying to install libjpeg8-dev (Message 1 to 5 of 5)
Subject: Problem while trying to install libjpeg8-dev
Date: 25 Jun 2015 19:23:20
Message: <558c8d68$1@news.povray.org>
Hi(gh)!
Now I embarked on the long, long journey to GeoPOV, my binary mesh patch
project aimed at creating slices of planetary surfaces from image files
or even ASCII elevation data without generating gigabytes of ASCII code
overhead (see also thread on povray.general)... first station will be
compiling the current stable POV-Ray 3.7 distribution from GitHub under
Linux.
unix/README.md recommends to have (among others) libjpeg8-dev
pre-installed before starting the prebuild.sh script. When I tried this:
apt-get install libjpeg8-dev
I got the following error message (translated from German):
Die folgenden Pakete haben unerfüllte Abhängigkeiten:
  libjpeg8-dev : Hängt ab von: libjpeg8 (= 8b-1) aber 8d-1+deb7u1 soll
installiert werden
The following packages have unsolved dependences_
   libjpeg8-dev : Depends on: libjpeg8 (= 8b-1) but 8d-1+deb7u1 shall be
installed
How can I fix this?
See you in Khyberspace!
Yadgar
Subject: Re: Problem while trying to install libjpeg8-dev
Date: 25 Jun 2015 21:39:56
Message: <558cad6c$1@news.povray.org>
Am 26.06.2015 um 01:23 schrieb Jörg 'Yadgar' Bleimann:
> Hi(gh)!
> Linux.
> installiert werden
> installed
The corresponding English message would actually be:
The following packages have unmet dependencies:
  libjpeg8-dev : Depends: libjpeg8 (= 8b-1) but 8d-1+deb7u1 is to be
installed
As far as I understand, this means that libjpeg8 version 8b-1 is
currently installed on your system, but the most recent libjpeg8-dev
version is 8d-1+deb7u1; apt-get is complaining that they don't fit together.
You need to either specifically install the libjpeg8-dev matching your
installed libjpeg8, which (as far as I understand) the following command
should do:
   apt-get install libjpeg8-dev=8b-1
or you need to upgrade libjpeg8 to the most recent version:
   apt-get upgrade libjpeg8
Date: 25 Jun 2015 22:30:29
Message: <558cb945$1@news.povray.org>
> should do:
Neither worked - when tryintg to install libjpeg-dev=8b-1 or
libjpeg8-dev, I get the same error message again, when I try to upgrad
libjpeg8, apt-get says it is already the latest version... instead I got
a lengthy list of now disused packages which may be removed by using
apt-get autoremove - which I did afterwards. But even after this, your
suggestions did not work, messages were like before.
Yadgar
Date: 27 Jun 2015 15:10:12
Message: <web.558ef3e26c9fc1a8854728760@news.povray.org>
Hi
seems you try install libjpeg8-dev from wheezy repo but have squeeze installed
https://packages.debian.org/search?keywords=libjpeg8
Date: 29 Jun 2015 19:19:17
Message: <5591d275$1@news.povray.org>
Hi(gh)!
On 27.06.2015 21:05, eticre wrote:
> Hi
I tried replacing "squeeze" by "wheezy" in my first repository list
entry, and, yes, it worked! Thank you very much!
Yadgar
