POV-Ray : Newsgroups : povray.unix : Re: 3.7rc6 on Raspberry PI, with/without openexr image artifacts Server Time
23 Dec 2024 08:24:42 EST (-0500)
  Re: 3.7rc6 on Raspberry PI, with/without openexr image artifacts (Message 1 to 6 of 6)
Subject: Re: 3.7rc6 on Raspberry PI, with/without openexr image artifacts
Date: 12 Dec 2012 18:24:38
Message: <50c91236$1@news.povray.org>
Am 12.12.2012 22:03, schrieb clipka:
> Am 12.12.2012 20:56, schrieb clipka:
>> Am 12.12.2012 20:30, schrieb clipka:
>>> I swear I'm gonna find out what's going on here...
>> Apparently there's something fishy happening with the phong highlighting.
> Further investigations suggest that the Pi isn't happy with denormalized
> values, at least not in single precision.
> I'll try to throw together some simple C test program, and if that
> confirms my observations I'll file it as a bug to the Pi people.
Apparently the problems are related to the -ffast-math compiler option;
I'll try whether turning that off will help.
Date: 13 Dec 2012 02:52:37
Message: <50c98945@news.povray.org>
Am 13.12.2012 00:24, schrieb clipka:
Well, no, not really. No success, except that now the color of the
artifacts is inverted.
Download 'biscuit.png' (164 KB)
Preview of image 'biscuit.png'
Date: 13 Dec 2012 08:48:44
Message: <50c9dcbc$1@news.povray.org>
Am 13.12.2012 08:52, schrieb clipka:
Turning off /all/ optimizations does give the expected results. I don't
consider this an option though, so I guess we'll have to wait for
feedback from the raspbian team.
Date: 31 Mar 2013 21:57:18
Message: <5158e97e$1@news.povray.org>
Am 13.12.2012 14:48, schrieb clipka:
I've received feedback at last: The problem /may/ be solved with
gcc-4.7; I'm currently recompiling POV-Ray on my Pi.
Raspbian Wheezy's standard gcc package is still at 4.6, so I had to
manually install the gcc-4.7 and g++-4.7 packages, and force the
./configure script to actually use gcc-4.7 via the "CXX=gcc-4.7" option.
We shall see in a couple of hours whether that actually solves the issue.
Date: 1 Aug 2013 12:30:01
Message: <web.51fa8cef9e469a3bed558d7b0@news.povray.org>
I haven't tried 3.7 but 3.6.1 on the RPi using the 4.7 versions of the compiler
seem to work fine.
Date: 1 Aug 2013 14:34:34
Message: <51faaa3a$1@news.povray.org>
Am 01.08.2013 18:29, schrieb Craig Lindley:
> seem to work fine.
I wouldn't trust it; regarding the 3.7 issues, gcc 4.7 did somewhat
change the symptoms, but apparently not the underlying problem.
There's something seriously fishy going on (or at least was, last time I
tried) when the Pi tries to do single-precision vector computations with
very small (near-zero) numbers involved, and in some inexplicable way it
is very, /very/ sensitive to the structure of the program that does
these computations. Stuff like, say, you boil down the error to a small
program running some very simple computations in a loop 10 times,
triggering the bug on the 5th iteration; you reduce the loop count to 8
times, and suddenly the error does /not/ occur anymore, or manifests in
an entirely different manner. You "unroll" the loop into a sequence of
identical computations, and the program's behaviour changes yet again.
You use a different compiler, and the error goes away, but only in that
small boiled-down program, while still manifesting in the big program
that you're actually trying to get fixed.
So more likely than not it is just pure chance if the bug doesn't
manifest in 3.6.1. compiled with gcc 4.7 - and it may actually be still
lurking in some dark, rarely used corner.
