I use the Unix version on MacOS. I recently got a new Intel Mac and it
occurred to me that Povray might run faster if I recompile it, rather
than running a PPC version under emulation. But make failed:
$ make
make all-recursive
Making all in libraries
Making all in png
make[3]: *** No rule to make target `all'. Stop.
make[2]: *** [all-recursive] Error 1
make[1]: *** [all-recursive] Error 1
make: *** [all] Error 2
Clues?
Anton Sherwood *\\* http://bendwavy.org/
> $ make
> make all-recursive
> Making all in png
> Clues?
Which version of povray are you trying to compile ? (3.7RC3 or 3.6.2, or
even older ?)
My classical usage of the recent tar-balls (3.7):
1. extract the tar
2. go into the first level directory
3. ./configure COMPILED_BY="Anton Sherwood <...>"
(I also add --disable-io-restrictions , but that's personal)
4. make -j 12
5. sudo make install
(assuming the file ./unix/povray has been created by step 4)
Instead of 5, you can also try "./unix/povray --benchmark" if you have
installed at least once (so that the include files are at the right place)
Software is like dirt - it costs time and money to change it and move it
around.
Just because you can't see it, it doesn't weigh anything,
and you can't drill a hole in it and stick a rivet into it doesn't mean
it's free.
>> ... But make failed:
r
> even older ?)
3.6.1 is what I downloaded.
> 1. extract the tar
> 3. ./configure COMPILED_BY="Anton Sherwood<...>"
... did that ...
> 4. make -j 12
I used plain "make", but -j 12 did not change the result.
Anton Sherwood *\\* www.bendwavy.org
>> even older ?)
>> 1. extract the tar
> ... did that ...
>> 4. make -j 12
It looks like png is provided in libraries/png for 3.6, and is the 1.2
version of the library.
You might try to compile it by itself first:
* in libraries/png, execute ./configure
* then make
Either it works, or you have now a smaller issue to solve for your
system and libpng.
around.
it's free.
> * then make
Thanks. I did that (success); and then the same in libraries/jpeg
(success); and then the same in libraries/tiff (hideous failure).
Anton Sherwood *\\* www.bendwavy.org *\\* www.zazzle.com/tamfang
