POV-Ray : Newsgroups : povray.unix : Problem with QTPov Editor Server Time
10 Jun 2026 14:44:17 EDT (-0400)
  Problem with QTPov Editor (Message 1 to 1 of 1)
Subject: Problem with QTPov Editor
Date: 10 Sep 2005 02:23:10
Message: <43227bce@news.povray.org>
Hello to all,
when I tried to edit a *.pov file with QTPov editor 0.9.9,
the editor simply closed without warning on my attempt to insert a new line.
So I cannot use the editor in a sensible way.
Is this a known problem, or does anybody know a solution?
Thank you
Martin
Subject: Re: Problem with QTPov Editor
Date: 12 Sep 2005 05:43:28
Message: <43254dc0$1@news.povray.org>
Hash: SHA1
Martin Oswald wrote:
> Hello to all,
Are you aware that 1.0 is out ?
I had no problem editing a pov file with qtpoveditor 1.0, but I did not
test extensively either.
Eifersucht ist die Leidenschaft, die mit Eifer sucht, was Leiden schafft.
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.0 (MingW32)
Comment: Using GnuPG with Thunderbird - http://enigmail.mozdev.org
iD8DBQFDJU3As/YJ43cSjHIRAseCAKDHs6ISXaqq3fsyXSlYrDBy9nMcwwCfXb3J
MmQBrYySwyAWJzwdjgT38Q8=
=gpU9
-----END PGP SIGNATURE-----
Date: 12 Sep 2005 17:55:26
Message: <4325f94e$1@news.povray.org>
> Hello to all,
line.
> Thank you
> Martin
Really strange ! Never seen such a thing...
could you send me a copy of the file tou are trying to edit ?
Thierry
QTPE's author
Date: 14 Sep 2005 00:59:18
Message: <4327ae26$1@news.povray.org>
Bonjour Thierry,
la langue francaise) si je continue en anglais :-)
The problem I described does not depend on a certain file, I tried a few
different ones. But I can give you some hints:
It occurred with *.pov and *.inc files, but not with *.ini files. The
program even closed when I tried to insert a line in the README file. The
README file also shows syntax highlighting when opened, but the *.ini files
don't; so could the problem depend on syntax highlighting?
My Linux version is SuSE 9.1, QTPov's version that I found and downloaded
some days ago is 0.9.9. Is it possible that my Linux is too old?
Best regards
Martin
