chalk it up to whatever you want (new compiler?, cleaned code?, ...?) but
the official 3.6 binary shaved 19 minutes off of benchmark.pov using the
benchmark.ini settings, compared to the official 3.5 binary with the same
official benchmark.pov/benchmark.ini. i never benchmarked pov before, so i
thought i'd do it before I installed 3.6.
computer info:
AMD Duron 800MHz running Slackware 9.1
X was running, as was Enlightenment, as would be my normal situation while
using povray.
on my slowish laptop, these were the results (handtyped, forgive any changes
in formatting):
3.6:
Parse Time: 0 hours 0 minutes 4 seconds
Photon Time: 0 hours 1 minutes 54 seconds
Render Time: 1 hours 30 minutes 34 seconds
Total Time: 1 hours 32 minutes 32 seconds
3.5:
Time for Parse: 0 hours 0 minutes 7 seconds
Time for Photon: 0 hours 2 minutes 3 seconds
Time for Trace: 1 hours 49 minutes 34 seconds
Total Time: 1 hours 51 minutes 44 seconds
please refrain from making jokes about my slow computer :) Regardless of
what caused the improvement i'm glad to see it.
-r
In article <40ca2d06@news.povray.org> , "Ross" <rli### [at] everestkc net>
This was mentioned bfeore: You *cannot* compare the 3.5 and the 3.6
becnhmark results due to anti-aliasing changes in POV-Ray 3.6!
Thorsten
Thorsten Froehlich
e-mail: mac### [at] povray org
I am a member of the POV-Ray Team.
For this speed difference the changes in photons are probably more
important.
Last updated 01 May. 2004 _____./\/^>_*_<^\/\.______
> Thorsten
> Thorsten Froehlich
Where was mentionned changes in AA with pov 3.6, I didn't saw them in
"Changes between pov 3.5 & 3.6" on the povray download page !
I'm prbably too idiot to see them... can you explain the changes and why
this AA 'trace' quicker ?
I hardly use AA nowadays. I use focal blur instead! And photons are MUCH
faster :D
"Thorsten Froehlich" <tho### [at] trf de> wrote in message
news:40caa57d$1@news.povray.org...
but
same
i
> Thorsten
I can compare the time it used to take for me to render a scene to the time
it takes now to render a scene. i'm not trying to dig too deeply, i'm just
saying I experience a rather noticeable speed gain.
what the hell are benchmarks for if not to compare and old something to a
new something?
"Ross" <rli### [at] everestkc net> wrote in message
news:40cdacbb$1@news.povray.org...
time
> new something?
bah. it's early.
ignore my grumbling, thorsten.
In article <40cdacbb$1@news.povray.org> , "Ross" <rli### [at] everestkc net>
> new something?
You are supposed to use the benchmark to compare computer systems, not to
compare POV-Ray with itself! :-)
Thorsten
e-mail: tho### [at] trf de
Comparing the newer version of POV-Ray with the older version is feasible.
If both give approximately the same image but the newer version does so
noticeably faster, that's something positive to notice.
The newer version being faster than the older version *is* something
to brag about.
In this case the speedup is mainly due to photons, isn't it? It's
interesting to see in practice how much they have been improved... :)
<1,1,3>hollow}text{ttf"timrom""Warp".1,0translate<-1,-.1,2>}// - Warp -
>>new something?
> Thorsten
this reminds me of my pure maths teacher at school
if you have something like
prove sin^3 (x) + 3 cos^2 (x) = 5sin(x)cos(x)
i used reduce lhs to 1 and then reduce rhs to 1 or some other term
and then i'd have to write lhs derivation followed by the rhs derivation
in reverse to make him happy
the system and scene source are constant, therefore running to me at
least, povray 3.5 versus povray 3.6 with i assume same arguments, is a
valid performance indication
unless someone can explain and convince me differently ?
stephen
