![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Hi all,
I got 3.6 tarball from povray site and it seems it's the final release
and I saw someone succeed to compile it under solaris 8 ("Sparc Solaris
8 with GCC 2.95.3 (g++2 2.95.3 @ sparc-sun-solaris2.8" in INSTALL file).
Well, unfortunaly, I got the same errors as with test tarball about X
definition.
g++ -DHAVE_CONFIG_H -DPOVLIBDIR=\"/usr/local/share/povray-3.6\"
-DPOVCONFDIR=\"/usr/local/etc/povray/3.6\"
-DPOVCONFDIR_BACKWARD=\"/usr/local/etc\" -I. -I. -I.. -I.. -I../source
-I../source/base -I../source/frontend -I../source -I../libraries/zlib
-I../libraries/png -I../libraries/tiff/libtiff
-I../libraries/tiff/libtiff -I/usr/openwin/include -pipe
-Wno-multichar -O3 -c -o xwin.o `test -f 'xwin.cpp' || echo './'`xwin.cpp
In file included from xwin.cpp:122:
/usr/openwin/include/X11/Xlib.h:2099: ISO C++ forbids declaration of
`XSetTransientForHint' with no type
/usr/openwin/include/X11/Xlib.h:2107: ISO C++ forbids declaration of
`XActivateScreenSaver' with no type
Does it mean I have to recompile it using the old GCC 2.95 ? (the
optimiser it worst than current one).
Or does it mean I have to remove X support ?
Thanks for your help.
Lolo
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
For some unknown reason gcc 3.x produces a binary which crashes on
rendering. gcc 2.x produces a working binary.
I don't get that error. Can you tell me the version of the OS and gcc
you are using?
gcc 3.x does not produce faster binaries in a sparc-solaris system
than gcc 2.x (seemingly their optimization efforts have been put into
the PC side alone).
Just try compiling with gcc 2.
It works ok here.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
destroyedlolo wrote:
> Hi all,
> definition.
You are using a stone age version of the X libs just like you already
saw with the beta - you should not assume POV-Ray somehow magically
updating your X libraries.
Update your system or compile without X display.
Last updated 06 Jul. 2004 _____./\/^>_*_<^\/\.______
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Hum, perhasp another optimizer problem :-(
> you are using?
Solaris 8 (10/00) and GCC 3.0.1 from Solaris freeware depot.
I'm planing to upgrade to GCC 3.4.1 but I want to check if it's stable
before.
> the PC side alone).
Hum, when I made some benchmarks (and found that my Ultra5@270 is
definitevely not a race horse :-( ), some people on Solaris french
newsgroup said there is a big gap b/w GCC 2 and GCC 3 on UltraSparc.
achitecture.
I got the same reply on NetBSD/Sparc mailing list on the same subject.
If I succed to build both, I will make another benchmarks to see if
there is an improvement or not.
> It works ok here.
Even when you try w/ GCC 3 ?
Thanks
Laurent
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> achitecture.
Then they must be using some other gcc 3.x than I'm using, because
here it does not produce faster binaries.
> > It works ok here.
Would I know it crashes if it had failed compiling?
N(11117333955)N(4254934330)N(3900569407)N(7382340)N(3358)N(970)}// - Warp -
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Warp wrote:
Hi Warp,
I have miss something : sorry for my misunderstanding :-(
You said in a previous post
So it sounds for me that "someone" succeed to compile it using GCC 3 but
the resulting executable crashes ... Am I right ?
On my machine, I can't compile using GCC 3 (even w/ GCC 3.4.1 that I
just installed due to header problem) so my question is actualy "how do
someone succeed to compile w/ GCC 3 ?"
I appologies again if I miss something.
Laurent
PS: I had no problem at all w/ povray3.5c w/ GCC 3, binary I'm using now.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
