POV-Ray : Newsgroups : povray.unix : POVRAY include bug ??? Server Time
21 Apr 2025 18:20:39 EDT (-0400)
  POVRAY include bug ??? (Message 1 to 6 of 6)
Subject: POVRAY include bug ???
Date: 1 May 2003 14:36:28
Message: <3eb1692c@news.povray.org>
Bob R has reported a problem when rendering the balcony scene in the
advanced directory using pyvon.
I found out that I had the same problem when using pyvon.
The command that Pyvon launches on my computer is the one that follows.
"/home/fabien/mlpov/82/povray-3.50c/src/povray
Input_File_Name="/home/fabien/mlpov/povray-3.50c/scenes/advanced/balcony/balcony.pov"
  -l/home/fabien/mlpov/povray-3.50c/scenes/advanced/balcony +v +p
-l/mnt/win_c/temp -f +a0.1 +am2
-l/home/fabien/mlpov/povray-3.50c/include +GF${HOME}/err.txt +q9"
When I use a console, cd to the balcony directory, starts povray to
raytrace the balcony scene, it works.
BUT, when I use a console, remain in my home directory (ie /home/fabien)
and render the balcony scene, I get the same error as when I use pyvon.
Below is a copy of my console. On the first line, the command line that
starts pov and the messages that POV outputs.
> [fabien@localhost fabien]$ /home/fabien/mlpov/82/povray-3.50c/src/povray
+i/home/fabien/mlpov/povray-3.50c/scenes/advanced/balcony/balcony.pov  +v +p -f +dgt
> Persistence of Vision(tm) Ray Tracer Version 3.5 Unix (.Linux.gcc)
>   This is an unofficial version (mlpov 0.82) compiled by:
>    Mael (mae### [at] hotmailcom)
>    The POV-Ray Team(tm) is not responsible for supporting this version.
> Copyright 1991-2002 POV-Ray Team(tm)
> Parsing Options
>   Input file: /home/fabien/mlpov/povray-3.50c/scenes/advanced/balcony/balcony.pov
(compatible to version 3.5)
>   Remove bounds........On  Split unions........Off
>   Library paths: /usr/local/share/povray-3.5
>     /usr/local/share/povray-3.5/include
> Output Options
>   Image resolution 320 by 240 (rows 1 to 240, columns 1 to 320).
> Warning:   Rendering to screen only. No file output.
>   Graphic display......On  (type: G, palette: T, gamma:  2.2)
>   Mosaic preview......Off
>   CPU usage histogram.Off
>   Continued trace.....Off  Allow interruption..Off  Pause when done......On
>   Verbose messages.....On
> Tracing Options
>   Quality:  9
>   Bounding boxes.......On  Bounding threshold: 3
>   Light Buffer.........On  Vista Buffer.........On  Draw Vista Buffer...Off
>   Antialiasing........Off
> Animation Options
>   Clock value....   0.000  (Animation off)
> Redirecting Options
>   All Streams to console.........Off
>   Debug Stream to console.........On
>   Fatal Stream to console.........On
>   Render Stream to console........On
>   Statistics Stream to console....On
>   Warning Stream to console.......On
> Parsing........................................................................
> ...........................................File:
/usr/local/share/povray-3.5/include/shapes.inc  Line: 464
> Warning:
> Round_Box() macro called with z-size < Radius,
> results may not be as expected
> .File: /usr/local/share/povray-3.5/include/glass_old.inc  Line: 17
> Warning:
> Due to changes in version 3.1, you must add interior {I_Glass} to all objects
calling glass_old.inc textures and finishes...
> ...File: /home/fabien/mlpov/povray-3.50c/scenes/advanced/balcony/table_stuff.inc
Line: 99
> union {
>   object {
>     Glass
>  <----ERROR
> Parse Error: Expected 'object', undeclared identifier 'Glass' found instead
My include files are correctly quoted in my .povrayrc as shown above
NOTE :
There is a glass.inc in /usr/local/share/povray-3.5/include AND in the
balcony directory.
Could this be the problem ?
Something else : I did the same test as root : There is no
writing-reading problems.
Could some of you try the same : Starts a raytrace of balcony.pov from
your home directory or anywhere else but the balcony directory and tell
me if it works.
Thanks
Fabien H
Subject: Re: POVRAY include bug ???
Date: 1 May 2003 19:49:20
Message: <slrnbb3cdp.77q.steve@zeropps.org.uk>
I have a simplified command line here which gives similar results:
[sjlen:sjlen]$ povray -i/usr/local/lib/povray-3.5/scenes/advanced/balcony/balcony.pov
Parsing......File: /usr/local/lib/povray-3.5/scenes/advanced/balcony/balcony.pov
Line: 158
Error: Could not find file 'sky.inc'
File: /usr/local/lib/povray-3.5/scenes/advanced/balcony/balcony.pov  Line: 158
#include "sky.inc"
 <----ERROR
Parse Error: Cannot open include file sky.inc.
Warning: Check that the file is in a directory specifed with a +L switch
or 'Library_Path=' .INI item. Standard include files are in the
include directory or folder. Please read your documentation carefully.
################################  End of POV output #####################
In the directory /usr/local/lib/povray-3.5/scenes/advanced/balcony/ I have
the following files:
[sjlen:balcony]$ ls
balcony.pov   chair.inc  glass.inc  table.inc        table_stuff.inc  water.inc
building.inc  cloth.inc  sky.inc    table_cloth.inc  terrain.inc
If I cd to the balcony directory it renders fine.
sphere{z*5,1pigment{rgb.5}finish{reflection.3specular.5}}box{<-50,-3,-50>
<50,-2,50>pigment{checker/*\__\\__/  * \_\\__*/scale 2}finish{ambient.7}}
light_source/*__\\__\\__\\__\\__\(    ~ )\__\\__\\__\\__\\*/{<2,5,1>*4,1}
/*\\__\\__\\__\\__\\__\\__\\__\\__\~  -/__\\__\\__\\__\\__\\*//* Steve */
Date: 2 May 2003 00:37:05
Message: <3eb1f5f1$1@news.povray.org>
[snip part of output dump]
>> ...File:
>> Line: 99
>> union {
>>   object {
>>     Glass
>>  <----ERROR
>> instead
> NOTE :
> balcony directory.
> me if it works.
I get the same behavior as you do:
$ povray -l/usr/share/povray-3.5/scenes/advanced/balcony
-i/usr/share/povray-3.5/scenes/advanced/balcony/balcony.pov
has the Glass object error in table_stuff.inc. It looks like the library
parameter is being referenced at the first level of including because it
does correctly find table_stuff.inc (as well as sky.inc) in the balcony
directory. Both of those are includes in the balcony.pov scene file. But
the passed library path doesn't seem to carry into the included files.
In this case balcony.pov includes table_stuff.inc, so far so good. But
table_stuff.inc includes glass.inc and this is where it is breaking
down. So the includes of includes are not being looked for in the
library path parameter or the order of looking changed. At least that's
the behavior I'm seeing here. I have no idea why though.
I wonder if it works for include files that have includes that do not
name clash with the existing standard includes. It looks like it works
correctly in such cases. The balcony.pov scene includes table_cloth.inc
before including table_stuff.inc. table_cloth.inc includes cloth.inc and
  POV-Ray doesn't choke on that include. So maybe the order of includes
gets shuffled at some point or is search differently? Puzzling stuff!
-Roz
Date: 2 May 2003 02:02:01
Message: <3eb209d9@news.povray.org>
Roz wrote in message <3eb1f5f1$1@news.povray.org>...
the
><snip>
>> NOTE :
the
>> balcony directory.
from
tell
>> me if it works.
library
it
balcony
But
files.
But
that's
works
table_cloth.inc
and
includes
>-Roz
I re-named the local "glass.inc", and "balcony.pov" renders OK using
Pyvon.
It may be a POVray(Linux) problem.
I've been trying out Kdevelop/Qt. I put together a little program[1]
with a dialog that runs POV. No "cd" to any directory, simply calls
povray with a path/filename, and it can't find "sky.inc" when I try
"/usr/..../povray-3.5/.../balcony.pov". On renders that do work, it
puts the *.png in the directory where the executable is run from(that
doesn't seem right, even with my weak little program).
Over a month in Linux, and I can't figure out CWD (Current Working
Directory). <G>
[1] - two days reading, 20 minutes work!! <G> I can't believe it even
works!
Bob R
POVrookie
MinGW (GNU compiler): http://www.mingw.com/
Dev-C++ IDE: http://www.bloodshed.net/
V IDE & V GUI: http://www.objectcentral.com/
POVray: http://www.povray.org/
Good C++ book: http://www.mindview.net/Books
alt.comp.lang.learn.c-c++: ftp://snurse-l.org/pub/acllc-c++/faq
Date: 2 May 2003 19:02:42
Message: <3eb2f912@news.povray.org>
> the
>><snip>
>>>NOTE :
> the
>>>balcony directory.
> from
> tell
>>>me if it works.
> library
> it
> balcony
> But
> files.
> But
> that's
> works
> table_cloth.inc
> and
> includes
>>-Roz
> Pyvon.
That's why I had to add the path to the current working directory
as in
-l/path/to/the/location/of/the/pov/file
> Directory). <G>
> works!
> Bob R
> POVrookie
Date: 2 May 2003 19:02:53
Message: <3eb2f91d@news.povray.org>
>> /home/fabien) and render the balcony scene, I get the same error as
>> when I use pyvon.
>> that starts pov and the messages that POV outputs.
>>> ...File:
>>> Line: 99
>>> union {
>>>   object {
>>>     Glass
>>>  <----ERROR
>>> instead
>> NOTE :
>> balcony directory.
>> tell me if it works.
> -Roz
I guess, that's something we will have to ask to the advanced users group.
I think you have to look at the code to know how the include files
behave when they are deeply nested and what happens when the same name
is used more than one time.
I renamed glass.inc to verres.inc and changed the files accordingly and
it works.
So in this case, I am glad to know that pyvon is not the culprit.
Fabien H
