POV-Ray : Newsgroups : povray.unix : Cygwin Server Time
26 Dec 2024 15:03:52 EST (-0500)
  Cygwin (Message 1 to 6 of 6)
Subject: Cygwin
Date: 19 Nov 2002 22:44:11
Message: <3ddb050b$1@news.povray.org>
Has anyone managed to compile Povray with Cygwin? When I try it it
complains about missing X headers. Using --without-x makes no
difference.
Ross Smith ...................... Pharos Systems, Auckland, New Zealand
"I write science fiction and fantasy for a living. The science fiction
is labelled 'Technical proposal', and the fantasy is labelled 'Budget
estimate'." -- Jordin Kare
Subject: Re: Cygwin
Date: 20 Nov 2002 10:49:45
Message: <BA015E5A.717D%fidel.viegas@artrecognition.co.uk>
in article 3ddb050b$1@news.povray.org, Ross Smith at ros### [at] pharosconz
wrote on 20/11/02 3:46 am:
> difference.
Have a look here http://www-public.tu-bs.de:8080/~y0013390/
All the best
Fidel.
Subject: Re: Cygwin
Date: 20 Nov 2002 21:30:08
Message: <3ddc4530$1@news.povray.org>
"Fidel viegas" <fid### [at] artrecognitioncouk> wrote in message
news:BA015E5A.717D%fid### [at] artrecognitioncouk...
> > difference.
That only covers Mingw, not Cygwin.
Subject: Re: Cygwin
Date: 21 Nov 2002 10:40:32
Message: <BA02ADB0.722C%fidel.viegas@artrecognition.co.uk>
in article 3ddc4530$1@news.povray.org, Ross Smith at ros### [at] pharosconz
wrote on 21/11/02 2:32 am:
>>> difference.
Sorry, I didn't really try it. I had version 3.1g.
All the best
Fidel.
Subject: Re: Cygwin
Date: 22 Nov 2002 15:24:52
Message: <3dde9294$1@news.povray.org>
> difference.
It appears that the config for without X doesn't work,
the quick way to get things to work are to
hack the makefile to remove the reference to
povxlib.o from the povray_OBJECTS section
and povxlib.c from povray_SOURCES
then add
#define X_DISPLAY_MISSING 1
to conf.h
which will give you a pure command line version.
That works for compiling the unix version on a Mac,
should work for cygwin too.
the other alternatives are to install a copy of xfree for cygwin :-)
or fix the configure script.
Dave
Subject: Re: Cygwin
Date: 24 Nov 2002 18:09:26
Message: <3de15c26$1@news.povray.org>
"David Burnett" <var### [at] ntlworldcom> wrote in message
news:3dde9294$1@news.povray.org...
> > difference.
> then add
> to conf.h
Thanks!
