POV-Ray : Newsgroups : povray.tools.poser : New feature request Poseray 3.13 beta Server Time
9 May 2025 21:27:21 EDT (-0400)
  New feature request Poseray 3.13 beta (Message 11 to 15 of 15)
Subject: Re: New feature request Poseray 3.13 beta
Date: 4 May 2011 03:44:11
Message: <4dc103cb@news.povray.org>
On 1/22/2011 9:36 AM, Thomas de Groot wrote:
> Something which is becoming increasingly important is an undo switch,
> especially for the Groups/Lines section, but may be also for the
> Groups/Subdivision section.
> Thomas
New undo feature in the latest beta of PoseRay.
http://mysite.verizon.net/sfg0000/
later,
FlyerX
Date: 4 May 2011 07:18:24
Message: <4dc13600$1@news.povray.org>
Am 04.05.2011 09:44, schrieb FlyerX:
FWIW:
PoseRay is still crashing whith any contemporary ATI graphics card and
model geometry above approx. 15 MB!
After getting frustrated about using Blender as converter (I really
loved PoseRay for that purpose!) I did some research and used the
VisualStudio debugging tools and finally found (at least a temporary)
workaround:
The access violation happens within the atioglxx.dll module and it seems
there is a function call with an uninitialized pointer. NVidia and *old*
ATI drivers are obviously more forgiving about this issue but
contemporary ATI drivers are not. As this is not a driver bug it is not
to be expected that any future update of the ATI OpenGL graphics drivers
will fix the problem.
But if it happens that you own a ATI card (and its installation CD) from
2004 (anything newer will not work) you can do the following:
Search the installation CD for the file atioglxx.dl_   (<- note the
underscore).
Copy this file into the PoseRay installation directory.
Run a console window and navigate to the PoseRay installation directory.
(e.g. "cd C:\CGI\PoseRay"). If you are using Vista or 7 and PoseRay is
installed within the "Program Files" folder you will need also
administrator rights.
Enter "expand atioglxx.dl_ atioglxx.dll".
PoseRay should work again. This will in no way mess up your graphics
driver/OpenGL installation as *only* PoseRay is effected.
Note that any catalyst drivers from the ATI update side (going back to
2008) are still too *new* and will not work.
Well, just in case you have no old driver cd available, you may want to
send me a mail...
-Ive
Date: 4 May 2011 14:20:41
Message: <4dc198f9@news.povray.org>
> FWIW:
> workaround:
> underscore).
> send me a mail...
> -Ive
Thanks for the workaround. To this day I have not been able to find the
origin of the bug. I used an OpenGL debugger and all the calls were
correct. Most likely it is a bug (or maybe an outdated function) in
PoseRay but without the ATI drivers running there is no way to check
exactly what is happening. If there was a way of emulating an ATI card
as a layer over the Nvidia drivers, for programming/debugging purposes,
that would be great.
FlyerX
Date: 4 May 2011 16:19:10
Message: <4dc1b4be$1@news.povray.org>
Am 04.05.2011 20:20, schrieb FlyerX:
Yeah, I understand your problem very well. While stepping through
hundrets of lines of assembler code I did suspect the calls
glTexImage2D and/or glGetTexImage to be the critical parts but it might
very well be the case that some initialization before did already fail.
Sorry, this is all I can tell as I'm just an OpenGL n00b ;)
While I did play around with the debugger (and accidentally did corrupt
the ATI drivers) I did also find out that in this case the
Windows-OpenGL-layer falls back to a GDI software emulation mode that
works (at least with an i7) not as bad as it sounds. Maybe a button
within PoseRay to force software emulation (if this is possible) would
be a cleaner workaround than moving dll's from the stone-age around?
-Ive
Date: 5 May 2011 17:27:56
Message: <4dc3165c$1@news.povray.org>
> -Ive
New beta available.
The software mode idea was a good one and I added a mode to PoseRay to
run in software mode. It is very slow but seems to work. It defaults to
OpenGL 1.1.
FlyerX
