POV-Ray : Newsgroups : povray.text.scene-files : Proximity Pattern and 3.5 Server Time
16 Apr 2026 13:48:44 EDT (-0400)
  Proximity Pattern and 3.5 (Message 4 to 13 of 13)
<<< Previous 3 Messages Goto Initial 10 Messages
Subject: Re: Proximity Pattern and 3.5
Date: 7 Feb 2002 15:32:59
Message: <Xns91AEDB8047B7Dseed7@povray.org>
wrote:
> plane{
>   -z 0
>   translate z*3
>   pigment{Proximity_Pattern(text{ttf"povlogo""P"9 0},.1,100)}
It crashes when Count gets bigger than 441:
pigment{Proximity_Pattern(text{ttf"povlogo""P"9 0},.1,442)}
Win2000 A1800+ 1.5GB POV 3.5-b10 intel.
Interesting pattern though.
Ingo
Date: 8 Feb 2002 04:25:28
Message: <ng576ucr2tsiu0u9cqoqlqgcgmehvoklnb@4ax.com>
On Thu, 07 Feb 2002 19:46:29 +0100, Christoph Hormann <chr### [at] gmxde>
wrote:
> Interesing,
Thanks
> but it looks more like a blur pattern to me, the proximity
> pattern uses intersection tests IIRC.
Yes, it uses intersection tests. But this intersection test returns distance.
Pattern showed averaged distance for defined number of tests. That's exactly
what my macro does. Here is example of MEGAPOV demo:
http://users.skynet.be/smellenbergh/demopictures/proxistarb.jpg. It's little
grainy but with larger number of samples it could look exactly like blur.
Things to add to my macro to support functionality of proximity pattern
1) additional select() to perform tests only inside/outside object
2) additional calculations to perform tests in direction of bounding box
Both looks easy to add.
ABX
Date: 8 Feb 2002 07:11:44
Message: <upf76ugdq6dlluklhiib1umos8qsk8k7hc@4ax.com>
Ok, I've made simple form of above.
New parameter Inside with yes/no value.
- no - leave inside of object empty
- yes - leave inside of object solid
To achive proximity pattern of both - inside and outside - it requires combination
of patterns with normal and inverted object.
Here is new version of macro:
#macro Proximity_Pattern(Object,Range,Count,Inside)
  #local P=function{pattern{object{Object}}};
  #local N=function{2*f_noise_generator(x,y,z,2)-1};
  #local Range=Range+0*x;
  #local X=abs(Range.x);
  #local Y=abs(Range.y);
  #local Z=abs(Range.z);
  #local Inside=(Inside?1:0);
  #local
B=function{pattern{object{box{min_extent(Object)-<X,Y,Z>max_extent(Object)+<X,Y,Z>}}}};
  #local C=max(int(Count)0);
  #local Proximity=function{
    (1/C)*(
    #while(C)
      P(
        x+X*N(x+C,y,z),
        y+Y*N(x,y+C,z),
        z+Z*N(x,y,z+C)
      #local C=C-1;
      #if(C)+#end
  function{select(B(x,y,z),0,0,select(P(x,y,z),0,Proximity(x,y,z),Inside))}
ABX
Date: 8 Feb 2002 20:23:20
Message: <chrishuff-7EBB20.20253808022002@netplex.aussie.org>
In article <slr### [at] fwicom>,
 Ron Parker <ron### [at] povrayorg> wrote:
> So does this, essentially.  It effectively returns an approximation of the
> fraction of the local region of space that's occupied by the object.  For
> a sufficiently small region or a sufficiently large object, that number is
> related to the distance to the surface of the object (though part of me
> thinks there should be a cube root involved somewhere...)
It is affected by proximity, but has no direct relation to it. The
geometry of the surface is more important than distance...a very thin
cylinder compared to a plane for example. And objects without insides
will be invisible to it, since they contain no volume. It's really
nothing like the proximity pattern, more of a blurred object pattern.
Hmm, I'm going to have to try using smooth noise instead of random
samples in the patch...I think it would eliminate a lot of granyness.
Date: 8 Feb 2002 20:36:03
Message: <chrishuff-FBDE99.20382208022002@netplex.aussie.org>
In article <ng576ucr2tsiu0u9cqoqlqgcgmehvoklnb@4ax.com>,
Actually, the most commonly used mode used the minimum distance, but it
did support the average distance.
> That's exactly what my macro does.
No, your macro returns the percentage of the surrounding space occupied
by the object, which is quite different though it gives a similar
effect. It is just a blurred object pattern...hmm. Your macro could be
modified to blur almost any pattern or function...just remove the
definition of P and pass it in as a parameter, replacing "Object".
BTW, why use "(1/C)*(...)" instead of just "(...)/C"? And
"max(int(Count)1)" should be "max(int(Count), 1)".
Date: 10 Feb 2002 15:31:25
Message: <3C66D808.B664D528@hotmail.com>
Have you tried to do that Christopher  ?
I too wondered about that. - And then I
tried it, but then I got different
results (with beta 9).
I haven't checked with any later betas,
so I have not filed a bug report yet.
Tor Olav
Date: 11 Feb 2002 03:47:45
Message: <411f6ukkqp1uplrl14b1sn582vk372o0hb@4ax.com>
On Fri, 08 Feb 2002 20:38:22 -0500, Christopher James Huff <chr### [at] maccom>
Yes, I know, but then speed optimization with boundary will not work.
Becouse C is index for loop and after loop it has value 0.
Afaik 1/C is optimized to one float at parse time so it not the problem for
parser.
It's result of shortest code contest :-)
ABX
Date: 11 Feb 2002 11:41:55
Message: <chrishuff-13C4F0.11413111022002@netplex.aussie.org>
In article <411f6ukkqp1uplrl14b1sn582vk372o0hb@4ax.com>,
Just use separate macros...the blur pattern functionality would be very
useful, but having specialized macros optimized for specific patterns is
still possible.
"(...)/Count" will still work. I don't think that max() call is
necessary, but you could also just save the value of C before the loop
in another variable.
> parser.
It just makes it less obvious that you are dividing the sum by the
number of samples.
Hmm, something that would probably slow it down too much to be useful,
as well as being more difficult to implement, but it would be
interesting if it was modified to take samples in a sphere instead of a
cube...
Date: 11 Feb 2002 11:43:45
Message: <chrishuff-C91CB4.11432411022002@netplex.aussie.org>
In article <3C66D808.B664D528@hotmail.com>,
As ABX pointed out, the value of C is modified by the loop, you would
have to save it in another variable or drop the error testing that
rejects values for count < 1.
Date: 11 Feb 2002 18:32:09
Message: <3C6853EF.DB0CD76D@online.no>
Yes, of course. Sorry.
I didn't notice that it also was the counting variable.
Tor Olav
