POV-Ray : Newsgroups : povray.text.scene-files : Newbies Animating sky_sphere colour_map linked to SunPos Server Time
15 Mar 2026 07:01:54 EDT (-0400)
  Newbies Animating sky_sphere colour_map linked to SunPos (Message 1 to 6 of 6)
Subject: Newbies Animating sky_sphere colour_map linked to SunPos
Date: 2 Oct 2003 12:15:54
Message: <oprwfbhgleeybzwd@news.povray.org>
I hope this is the right place to post this if not no offence is intended.
I model a lot of outdoor stuff and use the excellent SunPos macro to
calculate the position of the sun. I would like to animate this by
altering the sun's position, this of course I can do easily, however the
sky_sphere colour won't match the sun position( blue sky at sunset etc.)
Using the old adage of try and work it out yourself, I have written a
little macro that seems to solve this. Before I get too involved with it,
altering light colour and creating a much better sun, I would really like
to get some comments as to my script and the colours used.
All comments are appreciated.
Phil
Using M2, Opera's revolutionary e-mail client: http://www.opera.com/m2/
//code start
#version 3.5;
global_settings{assumed_gamma 1}
#include "sunpos.inc"
//just to initiate SunPos
#declare lightposition = SunPos(2003, 10, 2, 06, 00, 0, 51.4667, 0.00);
//RERUN SolarPostion but bring in by a factor of 100 to see Sphere
#declare newSolarPosition=vrotate(<0,0,10000000>,<-Al,Az,0>);
#macro SunColourMacro()
#switch (newSolarPosition.y)
#range(-3000000, -2500000)
#declare Skycolour =
colour_map{
[0 rgb <1,0,0>]
[0.15 rgb <1,0.5,0.1>]
[0.2 rgb <172,163,146>/255]
[0.4 rgb <0,0,0>]};
#break
#range(-2500000, -1500000)
colour_map{
[0 rgb <1,0,0>]
[0.3 rgb <1,0.5,0.1>]
[0.4 rgb <172,163,146>/255]
[0.6 rgb <0,0,0>]};
#break
#range(-1500000,-1000000)
colour_map{
[0 rgb <1,0,0>]
[0.45 rgb <1,0.5,0.1>]
[0.6 rgb <172,163,146>/255]
[0.8 rgb <0,0,0>]};
#break
#range(-1000000,1000000)
colour_map{
[0 rgb <1,0,0>]
[0.6 rgb <1,0.5,0.1>]
[0.8 rgb <0,0,1>]
[1 rgb <0,0,0>]};
#break
#range(1000000,3000000)
colour_map{
[0 rgb <1,0,0>]
[0.8 rgb <0,0,1>]
[1 rgb <0,0,0>]};
#break
#range(3000000,4500000)
colour_map{
[0 rgb <1,0,0>]
[0.4 rgb <1,0.5,0.1>]
[0.5 rgb <172,163,146>/255]
[1 rgb <0,0,1>]
[1 rgb <0,0,0>]};
#break
#range(4500000,9000000)
colour_map{
[0 rgb <1,0,0>]
[1 rgb <0,0,1>]
[1 rgb <0,0,0>]};
#break
//sky
#declare MySkySphere=
sky_sphere{
SunColourMacro()
pigment{
gradient y
colour_map{
Skycolour}
scale 2 translate -1}};
sky_sphere{MySkySphere}
//clouds
plane{<0,1,0>,1 texture{
pigment{bozo warp{turbulence 0.4 octaves 6  omega 0.7 lambda 2}
colour_map{
[0.0 rgb <0.95, 0.95, 0.95>]
[0.1 rgb <0.85, 0.85, 0.85>]
[0.5 rgbt <1, 1, 1, 1> ]
[1.0 rgbt <1, 1, 1, 1> ]}
rotate<10,20,0>
scale <0.3, 0.4, 0.3>*3 }
finish {ambient 1 diffuse 0}}
scale 1000}
#declare Suncolour = rgb<247/255,255/255,58/255>;
//adjust sphere to match apparent size
#declare MySphere= sphere{<0,0,0> 250000 pigment{colour Suncolour}
finish{ambient 1 diffuse 0}}
//Use rejigged SolarPosition
light_source {newSolarPosition rgb 1 looks_like {MySphere}}
camera{
location <0,10,-150>
look_at <0,10,10>
plane{y,0 texture {pigment{rgb <0.6,0.8,0.196078>*0.9} normal {bumps 0.5
scale 0.01} finish {ambient 0.45 diffuse 0.55}}}
//code end
Subject: Re: Newbies Animating sky_sphere colour_map linked to SunPos
Date: 2 Oct 2003 16:12:55
Message: <3f7c86c7@news.povray.org>
"Phil Cook" <phi### [at] deckingdealscouk> wrote in message
news:oprwfbhgleeybzwd@news.povray.org...
Looks like a great idea. If you add one more color_map following after the
last #break, and add #else before the color_map, it'll be valid for all
times not within the ranges given. That way you get the night sky at 3 a.m.
too, which is one of the times I tried.
Sky coloring is always difficult. Right away I thought the purple didn't
seem correct for the sunrise/sunset. Although, I think if a layer of thin
clouds or water droplets were present in the air this is the color that
might be seen. I'm just guessing, but perhaps a result of the very wide area
it covers it looks out of place. The bright blue above it looks wrong to me
too, too blue without other colors mixed in to offset it. Most times I think
of the real sky colors as muted in some sense, except perhaps the Sun itself
and intensely lit clouds. A bit of imaginative perception can enhance the
coloring. I see a lot of sunrises from my location on a NE facing hillside,
not as many sunsets, and yet I don't believe I could accurately reproduce it
from memory in POV-Ray.
Overall I'd say you have too much red mixed into the blue in those color
maps.
Anyway, I'd suggest the orange range be thinner, closer to the horizon.
Here's my attempt at adjusting all the sky colors. Use them if you wish to,
change them some more, whatever. It's only my interpretation of sky
coloring.
#declare Skycolour = // sunrise
colour_map{
[0 rgb <1,0.1,0.1>]
[0.5125 rgb <1.5,0.2,0.1>]
[0.55 rgb <1,0.8,0.2>]
[0.575 rgb <1,0.6,0.3>]
[0.6 rgb <0.9,0.6,0.6>]
[0.65 rgb <0.25,0.35,0.75>]
[0.725 rgb <0.1,0.2,0.8>]
[1 rgb <0.1,0.1,0.3>]}
#declare Skycolour = // sunset
colour_map{
[0 rgb <1,0.1,0.1>]
[0.5125 rgb <0.9,0.2,0.2>]
[0.55 rgb <0.95,0.75,0.4>]
[0.6 rgb <0.8,0.6,0.5>]
[0.65 rgb <0.2,0.5,0.7>]
[0.725 rgb <0.1,0.4,0.8>]
[1 rgb <0.1,0.2,0.3>]}
#declare Skycolour = // early morning/late afternoon
colour_map{
[0 rgb <1,0,0>]
[0.5 rgb <0.65,0.6,0.9>]
[0.525 rgb <0.35,0.6,0.9>]
[0.6 rgb <0.3,0.55,0.8>]
[0.8 rgb <0.1,0.3,0.9>]
[1 rgb <0.2,0.3,0.7>]}
#declare Skycolour = // midmorning/afternoon
colour_map{
[0 rgb <1,0,0>]
[0.5 rgb <0.6,0.7,0.8>]
[0.525 rgb <0.35,0.55,0.9>]
[0.575 rgb <0.25,0.45,0.8>]
[0.7 rgb <0.2,0.3,1>]
[1 rgb <0.1,0.4,0.7>]}
#declare Skycolour = // noon
colour_map{
[0 rgb <1,0,0>]
[0.5 rgb <0.75,0.75,0.7>]
[0.55 rgb <0.3,0.7,0.9>]
[0.65 rgb <0.15,0.6,0.8>]
[0.8 rgb <0.2,0.4,0.9>]
#declare Skycolour = // night
colour_map{
[0 rgb <1,0,0>]
[0.5 rgb <0.05,0.075,0.075>]
[0.525 rgb <0.025,0.025,0.1>]
[1 rgb <0,0,0>]}
Oh, and semicolons aren't required for those declares.  :-)  I realize all
you asked for was an opinion but I love to try sky colors myself.
Bob H.
Date: 3 Oct 2003 05:49:31
Message: <oprwgn82byeybzwd@news.povray.org>
On Thu, 2 Oct 2003 15:12:45 -0500, Hughes, B. <omn### [at] charternet>
>> it,
>> like
> the
> a.m.
Hmmm yes I forgot to test it during winter, the values only ran down to -3
million. Writes out 100 times "I must remember to trap errors"
> area
> me
> think
> itself
> hillside,
> reproduce it
> maps.
Thanks, mixing colours is difficult. If I recall my physics correctly the
blue is due to atmospheric scattering when passing through all the atmos'
then as the sun sets the blue diminishes as green is added to make cyan
than the blue goes and the green is added to red to make yellow and then
finally the green goes to leave red. Taking the cyan out of the sunsets
does produce that magenta colour, but leaving it in seems to produce
either banding or unrealistic colours.
> to,
> coloring.
> colour_map{
> [0 rgb <1,0.1,0.1>]
> colour_map{
> [0 rgb <1,0.1,0.1>]
> colour_map{
> [0 rgb <1,0,0>]
> colour_map{
> [0 rgb <1,0,0>]
> colour_map{
> [0 rgb <1,0,0>]
> colour_map{
> [0 rgb <1,0,0>]
> [1 rgb <0,0,0>]}
Which means adding a conditional to check if time is over 12 to
differentiate between sunset and sunrise, easy enough. Nice colours, still
seem to get than annoying banding between blue and orange though.
I know, I know, I tend to stick them on out of habit :)
> I realize all
> Bob H.
I was inspired after driving home this week by all the beautiful sunsets.
I must admit I was suprised not to see anything about this on the net or
ng's it seemed rather obvious to me to try and tie SunPos and sky_sphere
together expecially for doing animations.
The next stage after messing with colours and #range's is some clouds with
depth to reflect the sun properly and of course the sun itself which I
can't seem to get right,ah well back to dabbling with media.
Phil
Date: 6 Oct 2003 12:06:52
Message: <oprwmppyimeybzwd@news.povray.org>
On Fri, 03 Oct 2003 10:49:40 +0100, Phil Cook <phi### [at] deckingdealscouk>
<snip me>
>> the
>> a.m.
> -3 million. Writes out 100 times "I must remember to trap errors"
>> thin
>> area
>> to me
>> think
>> itself
>> the
>> hillside,
>> reproduce it
>> maps.
> the blue is due to atmospheric scattering when passing through all the
> atmos' then as the sun sets the blue diminishes as green is added to
> make cyan than the blue goes and the green is added to red to make
> yellow and then finally the green goes to leave red. Taking the cyan out
> of the sunsets does produce that magenta colour, but leaving it in seems
> to produce either banding or unrealistic colours.
>> to,
>> coloring.
<snip code>
>> I realize all
>> Bob H.
> with depth to reflect the sun properly and of course the sun itself
> which I can't seem to get right,ah well back to dabbling with media.
> Phil
This may be a backwards step but simplfying the colours seemed to produce
interesting results:
//start code
#declare lightposition = SunPos(2003, 7, 7, 5, 30, 0, 51.4667, 0.00);
#range(-9000000, -1250000)
colour_map{
[0 rgb <0,0,0>]
[1 rgb <0,0,0>]}
#break
#range(-1250000, 0)
colour_map{
[0 rgb <1,0,0>]
[0.7 rgb <0,0,0>]}
#break
#range(0, 1250000)
colour_map{
[0.5 rgb <1,0.25,0>]
[0.55 rgb <1,0.5,0>]
[0.8 rgb <0,0,0>]}
#break
#range(1250000, 2500000)
colour_map{
[0.4 rgb <1,0.5,0>]
[0.55 rgb <1,1,0.5>]
[0.8 rgb <0.5,0.5,1>]}
#break
#range(2500000, 5000000)
colour_map{
[0 rgb <0.5,1,1>]
[1 rgb <0.5,0.5,1>]}
#break
#range(5000000, 9000000)
colour_map{
[0 rgb <0.5,0.5,1>]
[1 rgb <0,0.5,1>]}
#break
#else
colour_map{
[0 rgb <0.5,0.5,1>]
[1 rgb <0,0.5,1>]}
#break
//sky
sky_sphere{
SunColourMacro()
pigment{
gradient y
colour_map{
Skycolour}
//clouds
colour_map{
rotate<10,20,0>
scale 1000}
camera{
look_at <0,10,10>
//end code
This is set to summer times sunrise approx 4.00 I quite like the effect of
this, not happy around 5.30 yellow seems a bit wishy washy.
Remembered to error trap this time:) Wish I could use some sort of formula
to alter the colours rather than range jumps though perhaps later.
I think I'll work with these colours for the time being (unless anyone can
alter these for the better) and start work on a better sun and clouds,
anyone got any tips?
Phil
Date: 6 Oct 2003 19:12:52
Message: <3f81f6f4@news.povray.org>
Wish I had my camera with me when I went out to the store the day after I
last posted a reply here. The sunset was one of those beauts with plenty of
color. A very large blanket of clouds covered most of the sky and was only a
faint lavender color before the sun dropped below it, the air itself looking
lit by yellow sunlight, then it changed to purple with brilliant orange-reds
on the parts underneath. What made it interesting to me more than the colors
was how that single-layered cloud looked upside-down. It was as if it were
bubbling downward, with an appearance like cumulonimbus cloudtops jutting
out below and into the sunshine out of the ever-darker purple. Whole event
lasted maybe 10 minutes.
Anyway, yeah, if you could get clouds together with the background sky it'd
be a vast improvement.
In your pov script, which I tried again, I pointed the camera higher up
rather than straight ahead. Your sunrise/sunset times (4:30 and 19:30) has a
black sky overhead, fairly sharp boundry too. IRL it never does that, unless
perhaps while in a high altitude airplane.
Something to consider might be azimuth of sun position so that one side of
the sky has brighter colors than the opposite side. Just an additional
semi-transparent pigment layer overlaid the main sky color pigment could be
used for that. Looks like that could be added at the final skysphere using
the Az variable which Sunpos() macro returns.
Bob H.
Date: 7 Oct 2003 11:28:10
Message: <oprwoil5fueybzwd@news.povray.org>
On Mon, 6 Oct 2003 18:12:43 -0500, Hughes, B. <omn### [at] charternet>
> of
> only a
> looking
> orange-reds
> colors
> were
> event
I'm in the UK so weather here is completely predictable in being
completely unpredicatable:)
> it'd
As I said clouds and sun are the next step <sigh>
> has a
> unless
Hmm I could switch it for a dark blue
> of
> be
> using
> Bob H.
Yeah something I realised this morning when watching the sunrise,
colour_map runs right round the sphere so it's red or yellow opposite the
sun as well which is not IRL. I was considering using the Az variable to
tie into the colour_map settings or just tilt the map, but your way would
be better.
What do you think, using -Al and Az as direction with a red, orange,
yellow type texture, as the sun rises the texture sinks? That may allow
the sky_sphere to just shift from blues to blacks.
Hmmm I'll give it a try when I've some time, completely rewriting a
company website at the moment brains gone numb.
Phil
