POV-Ray : Newsgroups : povray.text.scene-files : L*C*h(uv) functions Server Time
29 Apr 2024 14:02:08 EDT (-0400)
  L*C*h(uv) functions (Message 7 to 16 of 26)
<<< Previous 6 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: L*C*h(uv) functions
Date: 21 Nov 2016 15:57:01
Message: <58335f9d$1@news.povray.org>
On 11/21/2016 3:29 PM, Mike Horvath wrote:
> On 11/21/2016 3:10 PM, Mike Horvath wrote:
>> On 11/21/2016 3:02 PM, Bald Eagle wrote:
>>> Mike Horvath <mik### [at] gmailcom> wrote:
>>>> Here are the L*C*h(uv) functions I created. How do I turn them into
>>>> pigments?
>>>> Mike
>>> http://www.povray.org/documentation/view/3.6.1/378/
>> I have three separate functions for R, G and B.
>> #declare convertLCH2RGB_R = function(L,C,H)
{correctRGB1(funcXYZ2RGBb1(funcLAB2XYZb1(funcLCH2LABa1(L,C,H),funcLCH2LABa2(L,C,H),funcLCH2LABa3(L,C,H)),funcLAB2XYZb2(funcLCH2LABa1(L,C,H),funcLCH2LABa2(L,C,H),funcLCH2LABa3(L,C,H)),funcLAB2XYZb3(funcLCH2LABa1(L,C,H),funcLCH2LABa2(L,C,H),funcLCH2LABa3(L,C,H))),funcXYZ2RGBb2(funcLAB2XYZb1(funcLCH2LABa1(L,C,H),funcLCH2LABa2(L,C,H),funcLCH2LABa3(L,C,H)),funcLAB2XYZb2(funcLCH2LABa1(L,C,H),funcLCH2LABa2(L,C,H),funcLCH2LABa3(L,C,H)),funcLAB2XYZb3(funcLCH2LABa1(L,C,H),funcLCH2LABa2(L,C,H),funcLCH2LABa3(L,C,H))),funcXYZ2RGBb3(funcLAB2XYZb1(funcLCH2LABa1(L,C,H),funcLCH2LABa2(L,C,H),funcLCH2LABa3(L,C,H)),funcLAB2XYZb2(funcLCH2LABa1(L,C,H),funcLCH2LABa2(L,C,H),funcLCH2LABa3(L,C,H)),funcLAB2XYZb3(funcLCH2LABa1(L,C,H),funcLCH2LABa2(L,C,H),funcLCH2LABa3(L,C,H))))}
>> #declare convertLCH2RGB_G = function(L,C,H)
{correctRGB2(funcXYZ2RGBb1(funcLAB2XYZb1(funcLCH2LABa1(L,C,H),funcLCH2LABa2(L,C,H),funcLCH2LABa3(L,C,H)),funcLAB2XYZb2(funcLCH2LABa1(L,C,H),funcLCH2LABa2(L,C,H),funcLCH2LABa3(L,C,H)),funcLAB2XYZb3(funcLCH2LABa1(L,C,H),funcLCH2LABa2(L,C,H),funcLCH2LABa3(L,C,H))),funcXYZ2RGBb2(funcLAB2XYZb1(funcLCH2LABa1(L,C,H),funcLCH2LABa2(L,C,H),funcLCH2LABa3(L,C,H)),funcLAB2XYZb2(funcLCH2LABa1(L,C,H),funcLCH2LABa2(L,C,H),funcLCH2LABa3(L,C,H)),funcLAB2XYZb3(funcLCH2LABa1(L,C,H),funcLCH2LABa2(L,C,H),funcLCH2LABa3(L,C,H))),funcXYZ2RGBb3(funcLAB2XYZb1(funcLCH2LABa1(L,C,H),funcLCH2LABa2(L,C,H),funcLCH2LABa3(L,C,H)),funcLAB2XYZb2(funcLCH2LABa1(L,C,H),funcLCH2LABa2(L,C,H),funcLCH2LABa3(L,C,H)),funcLAB2XYZb3(funcLCH2LABa1(L,C,H),funcLCH2LABa2(L,C,H),funcLCH2LABa3(L,C,H))))}
>> #declare convertLCH2RGB_B = function(L,C,H)
{correctRGB3(funcXYZ2RGBb1(funcLAB2XYZb1(funcLCH2LABa1(L,C,H),funcLCH2LABa2(L,C,H),funcLCH2LABa3(L,C,H)),funcLAB2XYZb2(funcLCH2LABa1(L,C,H),funcLCH2LABa2(L,C,H),funcLCH2LABa3(L,C,H)),funcLAB2XYZb3(funcLCH2LABa1(L,C,H),funcLCH2LABa2(L,C,H),funcLCH2LABa3(L,C,H))),funcXYZ2RGBb2(funcLAB2XYZb1(funcLCH2LABa1(L,C,H),funcLCH2LABa2(L,C,H),funcLCH2LABa3(L,C,H)),funcLAB2XYZb2(funcLCH2LABa1(L,C,H),funcLCH2LABa2(L,C,H),funcLCH2LABa3(L,C,H)),funcLAB2XYZb3(funcLCH2LABa1(L,C,H),funcLCH2LABa2(L,C,H),funcLCH2LABa3(L,C,H))),funcXYZ2RGBb3(funcLAB2XYZb1(funcLCH2LABa1(L,C,H),funcLCH2LABa2(L,C,H),funcLCH2LABa3(L,C,H)),funcLAB2XYZb2(funcLCH2LABa1(L,C,H),funcLCH2LABa2(L,C,H),funcLCH2LABa3(L,C,H)),funcLAB2XYZb3(funcLCH2LABa1(L,C,H),funcLCH2LABa2(L,C,H),funcLCH2LABa3(L,C,H))))}
>> Actually, I can create a pigment already. But I don't know how to use
>> the functions in a isosurface or a parametric to make the 3D object the
>> pigment gets applied to, if possible.
>> Mike
> Oops! You'll need to know these as well.
> #declare correctRGB1 = function(R,G,B) {min(max(R,0),1)}
> #declare correctRGB2 = function(R,G,B) {min(max(G,0),1)}
> #declare correctRGB3 = function(R,G,B) {min(max(B,0),1)}
That is wrong. The RGB values should *not* be corrected. In fact, if any
of R, G or B are outside the range of 0 to 1, then the coordinate/color
should be discarded. Sorry!
Mike
Date: 21 Nov 2016 16:23:44
Message: <583365e0$1@news.povray.org>
Am 21.11.2016 um 21:56 schrieb Mike Horvath:
>>> Mike
So if I understand you correctly, the shape you want is exactly the
volume for which R, G and B are all within the range from 0 to 1.
That sounds like a job for an isosurface to me.
Variant A: Create six isosurfaces, each representing one of the
boundaries (R<0, G<0, B<0, R>1, G>1, B>1), and intersect them.
Variant B: Refactor the functions from variant A, so that they have the
same threshold, combine them using max() or min() to achieve the
intersection effect, and turn that into a single isosurface.
Date: 21 Nov 2016 16:33:30
Message: <5833682a$1@news.povray.org>
>>>> Mike
Yes, exactly!
I don't know how to do either variant. :(
Mike
Date: 21 Nov 2016 16:49:44
Message: <58336bf8$1@news.povray.org>
>> same threshold,
How to cook a haggis:
First catch your Haggis then...
Don't ya just love it when someone says "Simply..." ;)
Regards
Date: 21 Nov 2016 18:50:38
Message: <5833884e$1@news.povray.org>
> Yes, exactly!
> Mike
Forgot to add that I want to use polar coordinates (if that makes a
difference).
Mike
Date: 21 Nov 2016 19:46:28
Message: <58339564$1@news.povray.org>
>>>> Mike
I am trying random things now.
isosurface
	function {max(convertLCH2RGB_R(x,y,z), 1)}
	contained_by
		box {-2,+2}
//	threshold FLOAT_VALUE
	accuracy	0.01
	max_gradient	5
//	[evaluate P0, P1, P2]
//	open
//	[max_trace INTEGER] | [all_intersections]
	pigment {rgb 1}
This takes a long time to render, but there's nothing visible happening.
Mike
Date: 21 Nov 2016 23:22:15
Message: <5833c7f7$1@news.povray.org>
I tried this as well.
parametric
	function { convertLCH2RGB_R(u,100,v) }
	function { convertLCH2RGB_G(u,100,v) }
	function { convertLCH2RGB_B(u,100,v) }
	<0,0>, <100,360>
	contained_by
		box {-2,+2}
	max_gradient	5
	accuracy	0.01
	precompute	10 x,y,z
	pigment {rgb 1}
The render is too slow. The pps is below 100 and still dropping.
Mike
Date: 22 Nov 2016 02:30:45
Message: <5833f425$1@news.povray.org>
Am 22.11.2016 um 01:46 schrieb Mike Horvath:
> isosurface
throw away the max() function, and take care of the polar-ish coordinate
system by replacing:
with:
    convertLCH2RGB_R(y*200-100,sqrt(x*x+z*z)*100,atan2(x/z)*pi/180)
(presuming you want L up and I got the math right)
>     contained_by
>         box {-2,+2}
... and use threshold 1. That should give you something visible.
>     accuracy    0.01
>     max_gradient    5
> //    open
>     pigment {rgb 1}
> Mike
Date: 22 Nov 2016 02:33:02
Message: <5833f4ae$1@news.povray.org>
>> isosurface
> with:
>>     contained_by
>>         box {-2,+2}
>>     accuracy    0.01
>>     max_gradient    5
>> //    open
>>     pigment {rgb 1}
>> Mike
THANK YOU!!
However atan2 requires two parameters and your math only has one.
Mike
Date: 22 Nov 2016 02:44:13
Message: <5833f74d@news.povray.org>
Am 22.11.2016 um 08:33 schrieb Mike Horvath:
> THANK YOU!!
Sorry, try atan2(x,z).
