POV-Ray : Newsgroups : povray.text.scene-files : power notation change in POV3.6? Server Time
16 Apr 2026 00:34:57 EDT (-0400)
  power notation change in POV3.6? (Message 1 to 10 of 12)
Subject: power notation change in POV3.6?
Date: 18 Sep 2006 07:43:39
Message: <450e866b@news.povray.org>
Okay, it's been ages since I tinkered with a file of mine but I fired it up
today. It'd been started in POV 3.1, then MegaPOV 0.7 and eventually POV3.5,
without any hassles. But in 3.6 it hits the declare to set the (primative)
acceleration control for an object's motion and I get a parse error.
#declare accel= (2*clock)^4*20.5;
#declare lift=  (2.0*clock)^(1/5);
#declare Powerup =  ((5.0*clock)^(1/10))/100;
It's moaning when it hits the ^4. Same again at every ^
Okay, so I could probably do it another way but I haven't slept in 2 days &
I'm not all that good with animation anyway. What am I missing here?
File: G:\working\povray\shuttle.pov  Line: 31
File Context (5 lines):
Parse Error: All #declares of float, vector, and color require semi-colon
';' at end if the language version is set to 3.5 or higher. Either add the
semi-colon or set the
language version to 3.1 or lower.
Total Scene Processing Times
  Parse Time:    0 hours  0 minutes  0 seconds (0 seconds)
  Photon Time:   0 hours  0 minutes  0 seconds (0 seconds)
  Render Time:   0 hours  0 minutes  1 seconds (1 seconds)
  Total Time:    0 hours  0 minutes  1 seconds (1 seconds)
CPU time used: kernel 0.13 seconds, user 0.06 seconds, total 0.19 seconds
POV-Ray finished
Subject: Re: power notation change in POV3.6?
Date: 18 Sep 2006 07:46:08
Message: <450e8700@news.povray.org>
Never mind, think I found it. Change ^ to e, right?
"Data Banks" <da_### [at] ihugcomau> wrote in message
news:450e866b@news.povray.org...
> up today. It'd been started in POV 3.1, then MegaPOV 0.7 and eventually
> POV3.5, without any hassles. But in 3.6 it hits the declare to set the
> (primative) acceleration control for an object's motion and I get a parse
> error.
> & I'm not all that good with animation anyway. What am I missing here?
> POV-Ray finished
Date: 18 Sep 2006 07:47:57
Message: <450e876d@news.povray.org>
news:450e8700@news.povray.org...
Well, that didn't work.
Ah,
exp(A) Exponential of A. Returns the value of e raised to the power A where
e is the base of the natural logarithm, i.e. the non-repeating value
approximately equal to 2.71828182846.
>> error.
Date: 18 Sep 2006 07:54:01
Message: <450e88d9@news.povray.org>
Fixed it :)
#declare accel= pow(2*clock,4)*20.5;
#declare lift=  pow(2.0*clock,(1/5));
#declare Powerup =  pow(5.0*clock,(1/10))/100;
Yes yes, I know, my code is messy
news:450e876d@news.povray.org...
> Ah,
> where e is the base of the natural logarithm, i.e. the non-repeating value
>>> parse error.
>>> days & I'm not all that good with animation anyway. What am I missing
>>> here?
Date: 18 Sep 2006 08:18:10
Message: <vPNYMGAGvoDFFwTD@econym.demon.co.uk>
Wasn't it Data Banks who wrote:
>Fixed it :)
It all seems to have come about due to a rather pedantic disagreement
about the order of precedence of the ^ operator. Rather than just pick a
precedence order and tell anyone who wanted a different order to just
live with it, the ^ operator got ditched.
a*b^c*d might mean different things depending on the order in which the
operators are applied, but with pow() you write a*pow(b^c)*d or
pow(a*b,c*d) and there's no ambiguity.
Mike Williams
Gentleman of Leisure
Date: 18 Sep 2006 08:25:00
Message: <web.450e8f0ec43a9bccc150d4c10@news.povray.org>
"Data Banks" <da_### [at] ihugcomau> wrote:
> Fixed it :)
Yes, you've got it now.  This was changed quite awhile ago for reasons that
esacape me at the moment.
-tgq
Date: 18 Sep 2006 09:12:29
Message: <450e9b3d@news.povray.org>
  No, that's not the problem. The exponentiation operator as unambiguously
a higher precedence than the multiplication operator and thus that
expression is (well, should be) evaluated as a*(b^c)*d.
  The problematic cases, however, are these two: -a^2 and a^b^c
  In other words, is the precedence of the exponentiation operator lower
or higher than the precedence of the unary minus in the base? And in the
second case: Should the exponentiation operator be interpreted from
left-to-right (as most other operators) or right-to-left?
  The general consensus globally (ie. outside the POV world) is that
the exponentiation operator should have higher precedence than the
unary minus of the base. In other words, the first expression should
be interpreted as "-(a^2)" and not as "(-a)^2".
  Note that a unary minus in the exponent should, naturally, have a
higher precedence so that expressions like "a^-2" will work.
  As for the second expression, the general consensus seems to be
that the exponentiation operator, unlike most other operators, should
be interpreted from right-to-left. In other words, the second expression
should be interpreted as "a^(b^c)". This is because it more intuitively
represents how exponentiation (ie. superscript) works in mathematics.
  The problem with POV-Ray is that it didn't follow either of these
consensuses and this caused some complaints. The pov-team didn't want
to get into a filosophical discussion about what is the correct way
to interpret the ^ operator so they just removed it and now pow() is
the only official way for exponentiation.
  Note that it's only a question of agreement. It's not a question of
technical difficulties. It is trivial to parse the ^ operator
unambiguously with the precedence rules conforming to the global
consensus (iow. it doesn't even require ugly hacks nor ugly exceptions
in the parsing code, as long as the parsing code is already clean).
Date: 21 Sep 2006 07:07:41
Message: <4512727d@news.povray.org>
And I'm afraid you've both lost me :(
Once upon a time I'd have been able to follow that discussion, but sadly not
lately
news:450e9b3d@news.povray.org...
>                                                          - Warp
Date: 21 Sep 2006 07:08:57
Message: <451272c9@news.povray.org>
"Trevor G Quayle" <Tin### [at] hotmailcom> wrote in message
news:web.450e8f0ec43a9bccc150d4c10@news.povray.org...
>> Fixed it :)
> that
> -tgq
I thought I'd post the question, but while I waited I decided I'd re-read
the manual (catch up on some of the changes since I started learning with
3.1) and found it. I'll get used to it but I did like the ^ version
personally
Date: 21 Sep 2006 08:22:02
Message: <K$dRACAZLoEFFwsu@econym.demon.co.uk>
Come to think of it, it might be possible to consider reintroducing ^
now.
I think the only reason for considering the non-standard precedence was
to make it easier to port scenes from Megapov 0.* which happened to use
an unusual precedence order. At the time, lots of people were converting
isosurface scenes from MegaPOV 0.* to the POV beta that as experimenting
with ^.
Now that MegaPOV 0.* has been superseded for quite a while by MegaPOV
1.*, which also doesn't have the ^ operator, it could be introduced with
standard precedence without upsetting anyone.
Mike Williams
