POV-Ray : Newsgroups : povray.text.scene-files : Needle [WIP] Server Time
16 May 2026 13:51:42 EDT (-0400)
  Needle [WIP] (Message 1 to 2 of 2)
Subject: Needle [WIP]
Date: 15 Mar 2002 15:04:15
Message: <3c9253bf@news.povray.org>
#version 3.5;
#include "finish.inc"
#include "rad_def.inc"
#include "metals.inc"
/* I'm having some serious problems getting the materials right,
particularly the clear plastic,
it's supposed to be whitish and kinda milky. Everthing
seen through it should be a little on the blury side as well. I'm trying to
do some 3S but not the slightest clue how. The current media settings don't
work at all and i've tried what seems like hundreds. Please help! ;) */
global_settings {
  assumed_gamma 1.0
  max_trace_level 5
  radiosity{
      media on
      pretrace_start 0.08
      pretrace_end   0.01
      count 1000
      nearest_count 20
      error_bound .4
      recursion_limit 1
      brightness 1.2
      low_error_factor 0.01
      minimum_reuse 0.0
      always_sample off
  location  <0.0, .06, -.1>
  direction 1.5*z
  look_at   <0.0, 0.0,  0.0>
sky_sphere {
  pigment { rgb <.8,.8,1>  }
light_source {
  0*x                 // light's position (translated below)
  color rgb 1.0       // light's color
  translate <-30, 25, -30>   // <x y z> position of light
plane {
  y, // <X Y Z> unit surface normal, vector points "away from surface"
  -.005 // distance from the origin in the direction of the surface normal
  pigment { rgb <.9,.9,1>  }
// ---------------------------------------- Needle
#declare syringe = object {
  union {
    // Clear Plastic
    difference {
      merge {
        //shaft
        cylinder {
          0*x,  .055*x,  .0025
        //tip
        cylinder {
          .055*x,  .065*x,  .001
        // bottom
        prism {
           bezier_spline
           -0.0019,
           0,
           24,
           // (--- the <u,v> points ---)
          <-.005,.0075>,<-.005,.0075>,<-.004,.0095>,<0,.0095>,
          <0,.0095>,<0.004,.0095>,<.005,.0075>,<.005,.0075>,
          <.005,.0075>,<.005,.0075>,<.005,-.0075>,<.005,-.0075>,
          <.005,-.0075>,<.005,-.0075>,<0.004,-.0095>,<0,-.0095>,
          <0,-.0095>,<-0.004,-.0095>,<-.005,-.0075>,<-.005,-.0075>,
          <-.005,-.0075>,<-.005,-.0075>,<-.005,-.0075>,<-.005,.0075>
          rotate <0,0,1>*90
         //Triad
         prism {
           bezier_spline
           -0.00025,
           0.00025,
           16,
           <.055,.0025>,<.055,.0025>,<.0625,.0025>,<.0625,.0025>
           <.0625,.0025>,<.0625,.0025>,<.0645,.002>,<.0645,.0009>
           <.0645,.0009>,<.0645,.0009>,<.055,.0009>,<.055,.0009>
           <.055,.0009>,<.055,.0009>,<.055,.0025>,<.055,.0025>
           rotate x*5
         //Triad
         prism {
           bezier_spline
           -0.00025,
           0.00025,
           16,
           rotate x*125
         //Triad
         prism {
           bezier_spline
           -0.00025,
           0.00025,
           16,
           rotate x*-115
      //chamber
      merge {
          //shaft
          cylinder {
            -0.003*x,  .054*x,  .0015
          //tip
          cylinder {
           .05*x,  .066*x,  .0005
      hollow on
      material {
          pigment {  rgbt <1,1,1,.9>  }
          finish {
            ambient 0
            specular 1
            roughness .3
        interior {
          media {
           #declare Color=<1,1,1>;
           #declare opacity=.3;
           #declare Diffuse=.8*opacity;
           scattering {1,10*Diffuse}
           absorption rgb <.25,.25,0>
           intervals 50
           samples 1,150
           method 3
           density {bumps
                scale .00005}
        ior 1.04
    //needle
    difference {
      cylinder {
        .054*x, .073*x, .0001
      union {
        cylinder {
          .053*x, .074*x, .00005
          box {
          <-.001, -.001, -.001>
          < .001,  .001,  .001>
          rotate z*75
          translate x*.073
          translate y*.001
       texture {T_Chrome_4C}
    //rubber needle holder
    cylinder {
      .064*x,  .065*x,  .000499
      pigment { color <.9,.9,1> }
      finish {Dull}
    //plunger
    union {
      cylinder {
        -.0075*x,  -.0085*x,  .005
      box {
        <-.008, -.00045, -.00145>
        < .047,  .00045,  .00145>
      box {
        <-.008, -.00145, -.00045>
        < .047,  .00145,  .00045>
      cylinder {
        .047*x,  .0478*x,  .00149
      cylinder {
        .0475*x,  .0485*x,  .0005
      pigment { color rgb <1,1,1> }
      finish  { Shiny
                ambient .5
    //rubber piece
    union {
      cylinder {
        .0482*x,  .0492*x,  .00149
      sor {
      10,
      <0.0012, 0.0491999>
      <0.001, .0492>
      <0.00149, 0.05045>
      <0.0012, 0.0517>
      <0.0012, 0.0517001>
      <0.0012, 0.0536>
      <0.0012, 0.0536001>
      <0.0013, 0.0538>
      <0.00149, 0.054>
      <0.00149, 0.054>
      rotate z*-90
    pigment { color Black }
      finish {Dull}
object {
  syringe
  translate x*-.03
  translate y*-.0012
  rotate z*-2.6
  rotate y*60
Subject: Re: Needle [WIP]
Date: 15 Mar 2002 17:13:30
Message: <3c92720a@news.povray.org>
Hi Corey,
I tried to improve the media and maybe you haven't tried this:
      material {
          pigment {  rgbf <1,1,1,.8>  }
          finish {
            ambient 0
            specular .7
            roughness .25
        interior {
          media {
           #declare Color=<1,.98,.96>;
           #declare opacity=36;
           #declare Diffuse=.6*opacity;
           scattering {1,10*Diffuse extinction
(1/(Diffuse+.0001))*opacity*1.75}
           absorption rgb (1-Color)*10*Diffuse
           intervals 14
           samples 1,150
           method 3
        //   density {bumps
        //        scale .00005}
        ior 1.04
.... I disabled radiosity in my tests... Well, I don't think the above looks
perfect but at least it renders more quick.. I'm not so experienced with
media.. Maybe someone else will help you too.
Hugo
