POV-Ray : Newsgroups : povray.text.scene-files : UniversalBeams and a MAcro Question Server Time
4 Oct 2024 18:46:48 EDT (-0400)
  UniversalBeams and a MAcro Question (Message 1 to 5 of 5)
Subject: UniversalBeams and a MAcro Question
Date: 3 Oct 2001 07:02:05
Message: <3bbaf02d@news.povray.org>
Hi, I have a macro here, that some folks might find handy.  It creates
Universal (or I beams) with the ablitiy to bore holes at regular
intervals.
I also have a question (I'm a regular newbi to POV-ray, and 3d in
general) about default values in macros.
Can I do this:
#macro MyMacro(A, B, C=0, D=1, E=2)
and have C, D and E default to the values if the user leave them out, eg
user calls
MyMacro(3,6,2)
And pov trates this as MyMacro(3,6,2,1,2)?
Any way here is the I beam macro...  It would be nice if people caould
point out ways to improve it as well. Thanks
// I Beam macro
#macro IBeam(Length, Hole, Step, W, H, T)
	// IBeam will be centered around <0,0,0>
	// While I call it an IBeam (or Universal Beam)
	// The W is on the x axis, H on the Y axis, Length on Z
	// H is the vertical bar of the I, W the top and bottom caps.
	// T is the thickness of the material.
	// Hole and stpe are used to place holes in the vertial bar.
	// Step is min wanted, might be bigger
	difference
		// First Box is size of beam
		box
			<-(H/2),-(W/2),-(Length/2)>,
			<(H/2),(W/2),(Length/2)>
		// Second box take hunk out of bottom
		box
			<-((H/2)-T),-W,-Length>,
			<((H/2)-T),-(T/2),Length>
		// Third box take a bit from the top
		box
			<-((H/2)-T),(T/2),-Length>,
			<((H/2)-T),W,Length>
		#if (Hole > 0)
			// Always one gap more than num holes
			#local NumHoles = int(Length/(Step+Hole))
			#local Gap = (Length - (Hole*NumHoles)) / NumHoles
			#local Start = Length/2
			#local Pos = (Gap/2) + (Hole/2)
			#while (Pos < Length)
			object
				sphere {<0,0,Start - Pos>, Hole/2}
			#local Pos=Pos+Hole+Gap
  Rob Brown-Bayliss
 ---======o======---
Subject: Re: UniversalBeams and a MAcro Question
Date: 3 Oct 2001 17:27:44
Message: <3bbb82d0@news.povray.org>
"Rob Brown-Bayliss" <on_### [at] clearnetnz> wrote in message
news:3bbaf02d@news.povray.org...
> Can I do this:
> user calls
> MyMacro(3,6,2)
No, can't be.  C=0 is meaningless.  A #declare would be needed but even that
is impossible to actually put into the macro declaration.  You can only add
those in the macro item area and still the person using the macro has to use
all parameters.
It would be a good thing I believe if macro could accept any number of them
instead and default to something when there aren't enough or too many.  Not
sure if that's been considered before but most likely has been thought about
over the past couple years.
You might use the following instead since spheres don't lend well to cutting
through varying thicknesses.
//object // commented out because isn't needed.
// sphere {<0,0,Start - Pos>, Hole/2}
cylinder {<0,-T/0.499,Start - Pos>,<0,T/0.499,Start - Pos>, Hole/2}
Also, it would be advisable to add your name (even if a nickname), date and
POV version just so people know those things.  Thanks for posting it.
Bob H.
Date: 3 Oct 2001 23:03:16
Message: <3bbbd174@news.povray.org>
> them instead and default to something when there aren't enough or too
> many.  Not sure if that's been considered before but most likely has
> been thought about over the past couple years.
Yes, I have seen it in a couple of other scripting languagfes (php and
python) and it's quite a neat tool.
> cutting through varying thicknesses.
> //object // commented out because isn't needed. //{
> // sphere {<0,0,Start - Pos>, Hole/2} cylinder {<0,-T/0.499,Start -
> Pos>,<0,T/0.499,Start - Pos>, Hole/2} //}
Yeah, I had thought about that, my thinking was that under normal use the
radius of the hole is going to be many times that of the thickness, and
the slight curve of the cut through the wall might make it look a bit
less perfect (as the real things are seldom perfect) when getting up
close.
Is it possible (I might try latter anyway) to make the cylinder a bit
rough then cut the hole with it?  I doubt that adding bumps would do it,
Or would it?
  Rob Brown-Bayliss
 ---======o======---
Date: 4 Oct 2001 03:13:49
Message: <3bbc0c2d@news.povray.org>
news:3bbbd174@news.povray.org...
> Or would it?
Not unless you either use a CSG union of slightly randomly offset and
rescaled cylinders acting as a single one, or use a isosurface cylindrical
(or spherical) shape having surface "noise".  And I couldn't be certain
isosurfaces would be perfect enough in CSG since I seldom try it myself.  I
only know they can be problematic sometimes.
So, if you were thinking of normal {bumps 1}, for instance, that means
nothing to surface locations.
Bob H.
Date: 8 Oct 2001 16:50:54
Message: <3BC211E1.25D0AF3C@hotmail.com>
> intervals.
My suggestions:
1. Add semicolons after declarations
   of your numerical local variables.
E.g.:
should be
#local Start = Length/2;
2. Remove unnecessary parentheses that
   does not add to the readability of
   your code. (POV knows how to handle
   the order of the mathematical
   operators.)
E.g.:
could be written as
#local Gap = (Length - Hole*NumHoles)/NumHoles;
3. Make the operators that are common
   to all the components of a vector
   operate on the whole vector instead
   of each component.
E.g.:
could be written as
-<H, W, Length>/2
4. Be consequent with your indentation rules.
E.g.:
object
could (or should) be written like this:
        object
5. Use cylinder to cut holes with instead of
   spheres (as Bob suggested).
6. Some more suggestions that I'll spare
   you for right now  ;)
Tor Olav
> // I Beam macro
>         difference
>                 box
>                 box
>                 box
>                 #if (Hole > 0)
>                         object
>                         #end
>                 #end
> #end
