POV-Ray : Newsgroups : povray.text.scene-files : Another Lightning macro Server Time
13 Jun 2026 03:17:07 EDT (-0400)
  Another Lightning macro (Message 1 to 10 of 21)
Subject: Another Lightning macro
Date: 30 Apr 2001 11:30:11
Message: <3aed8503$1@news.povray.org>
A new trend? The main problem with this macro is that changing one param.
has too great an effect on the behaviour of other params. Oh, and the bolt
is upside down.
// lightning macro w/ sample scene
#version unofficial MegaPov 0.6;
camera{location  <0.0, 0.5, -25.0> look_at   <0.0, 0.0,  0.0>}
//LArraySize = increase this if you get array error messages
//LSeed = random seed for bolt
//LWidth = width of bolt threads
//LHeight = height of whole bolt
//LSpread = spread of bolt
//LBranch = increase for more spikes
//LCutoff = start point for possible forks
//LSpike = increase for a more jagged bolt
#macro Make_Bolt(LArraySize, LSeed, LWidth, LHeight, LSpread, LBranch,
LCutoff, LSpike)
  #declare myArray = array[LArraySize]
  #declare checkCount = -1;
  #declare highCount = 0;
  #declare arrayCount = 0;
  #declare myArray[arrayCount] = <0,0,0>;
  #declare myRand = seed(LSeed);
  #declare Lightning_Bolt =
  merge{
    #while (checkCount < highCount)
      #declare checkCount = checkCount + 1;
      #declare segPosA = myArray[arrayCount];
      #declare arrayCount = arrayCount + 1;
      #declare xPlus = (rand(myRand)-0.5)*LSpread;
      #declare zPlus = (rand(myRand)-0.5)*LSpread;
      #while(segPosA.y < LHeight)
        #declare xShift = segPosA.x + ((rand(myRand)-0.5)*LSpike) + xPlus;
        #declare yShift = segPosA.y + (rand(myRand)/5);
        #declare zShift = segPosA.z + ((rand(myRand)-0.5)*LSpike) + zPlus;
        #if (yShift > LHeight)
          #declare yShift = LHeight;
        #declare segPosB = <xShift, yShift, zShift>;
        cylinder{segPosA, segPosB, LWidth}
        sphere{segPosB, LWidth + 0.0001}
        #declare segPosA = segPosB;
        #declare randNum = rand(myRand);
        #if (randNum < LBranch & segPosA.y > LCutoff)
          #declare highCount = highCount + 1;
          #declare myArray[highCount] = segPosA;
Make_Bolt(500, 7, 0.05, 6, 0.3, 0.065, 0.5, 0.5)
object{
  Lightning_Bolt
  pigment{rgbf 1}
  interior{media{emission rgb <40,40,50>} media{absorption rgb <50,50,40>}}
hollow on
  rotate x*180
  no_shadow
  translate y*6
"To stop children being afraid of the dark, try to fill their daylight hours
with as much terror as possible"
www.tomandlu.co.uk
Subject: Re: Another Lightning macro
Date: 2 May 2001 04:28:30
Message: <3aefc52e@news.povray.org>
At least you got it to make multiple branches - I'm still struggling to get
more than 3...  I'll take a deeper look into the code and see if I can
figure out how yours works.
BTW what are the file://... stuff? I got it to work without them...
It would be nice if you could have a thick main bolt with decreasingly
smaller branches :)
Nekar
"Tom Melly" <tom### [at] tomandlucouk> wrote in message
news:3aed8503$1@news.povray.org...
> is upside down.
> file://LArraySize = increase this if you get array error messages
> file://LSeed = random seed for bolt
> file://LWidth = width of bolt threads
> file://LHeight = height of whole bolt
> file://LSpread = spread of bolt
> file://LBranch = increase for more spikes
> file://LCutoff = start point for possible forks
> file://LSpike = increase for a more jagged bolt
Date: 2 May 2001 06:36:16
Message: <3aefe320@news.povray.org>
"Nekar Xenos" <j-p### [at] citywalkcoza> wrote in message
news:3aefc52e@news.povray.org...
get
Well, I don't know if it's applicable to your lightning macro model, but
here's a brief explanation of how I do the multiple branches (I have no idea
if this is a "standard" way of handling such things, or how efficient it
is). BTW, your lightning is looking very nice.
branch logic:
1. set counter of number of branches to 0 ("highCount")
2. set checkCount to -1 ( a kludge, it should really be 0, but we're just
about to increment it)
3. increment checkCount
4. create main branch out of joined-up cylinders
5. as each cylinder is added, use random function to decide whether to
create a fork
6. if yes, increment "highCount" and store start position for branch in
array using highCount as address (myArray[highCount] = segPosA)
7. carry on with main fork until "ground" reached
8. check if highCount > checkCount
9. if so, increment checkCount, and repeat steps 3 to 8 (this is the  #while
(checkCount < highCount) loop)
Hope that helps.
Ah, that's outlook adding "file:" to // if the // are followed immediately
by anything except a space. //like this. (and if you got the code to work
with the // I'm amazed.)
> smaller branches :)
Yep, it would ;)
Date: 2 May 2001 10:12:12
Message: <3af015bc@news.povray.org>
I've changed Tom Melly's version a bit and I think it's looking good.
Nekar
global_settings
  assumed_gamma 1.0
camera{location  <0, 0.5, -10.0> look_at   <2, 1.2,  0.0>}
sky_sphere
  pigment
    bozo
    color_map { [0.0 color rgb <0.1, 0.2, 0.3>] [1.0 color rgb <0.11, 0.3,
0.4>] }
 // scale <0.1, 0.01, 10>
  scale <0.1, 0.05, 100>
light_source
  0*x // light's position (translated below)
  color red 1.0  green 1.0  blue 1.0  // light's color
  translate <-30, 30, -30>
plane { y, -1 pigment { color rgb <0.7, 0.5, 0.3> }
normal{bumps
       scale 3 }
plane { y, 0  pigment {bozo
    color_map { [0.0 color rgbt <0,0,0,1>] [1.0 color rgbt <0.11, 0.3, 0.4,
0>] }
    scale 10
normal{bumps
        scale <1,1,10>}
    rotate x*180
    translate y*10
fog
 // fog_type 4
  distance 50
  color rgb 0
LCutoff, LSpike)
 // blob{ threshold 0.001 //
        merge{
     // cylinder{segPosA, segPosB, LWidth*2 + 0.0001 } //  pigment{rgbt
1}interior{media{emission<1,2,2>  }}hollow no_shadow}
      //  sphere{segPosB, LWidth + 0.0001}
        #declare LWidth = (LWidth*0.995)   ;
      #declare LWidth = (LWidth*0.9)   ;
Make_Bolt(500, 1110, 0.05, 6, 0.3, 0.01, 0.5, 0.2)
object{
  Lightning_Bolt
 pigment{rgbt 1}interior{media{emission<1,5,5>*3  }}hollow
// hollow on
  rotate x*180
  no_shadow
  translate y*6
Make_Bolt(500, 11, 0.03, 6, 0.3, 0.01, 0.5, 0.2)
object{
  Lightning_Bolt
// hollow on
  rotate x*180
  no_shadow
  translate y*6
Date: 2 May 2001 11:02:46
Message: <3af02196$1@news.povray.org>
news:3af015bc@news.povray.org...
Now, if only emitting media worked with radiosity....
Date: 2 May 2001 17:20:13
Message: <chrishuff-667E7B.16174602052001@news.povray.org>
In article <3af02196$1@news.povray.org>, "Tom Melly"
Use MegaPOV...it's required (well, used) for this macro anyway.
Christopher James Huff
Date: 3 May 2001 04:57:39
Message: <3af11d83@news.povray.org>
Replacing
merge{
with
blob{threshold 1
and adding
,1
into the cylinder statement makes it a lot faster.
I've also tried replacing  the cylinder with my own lightning and it worked well,
making it nicely scalable without any unnatural straight parts.
Nekar
"Tom Melly" <tom### [at] tomandlucouk> wrote in message news:3af02196$1@news.povray.org...
Date: 3 May 2001 05:09:14
Message: <3af1203a$1@news.povray.org>
"Chris Huff" <chr### [at] maccom> wrote in message
news:chrishuff-667E7B.16174602052001@news.povray.org...
Hmm, well I ran this with mp (obviously), but I can't get the lightening to
light up the scene, which would seem to indicate that emitting media doesn't
contribute to radiosity. Am I missing something?
Date: 3 May 2001 05:09:57
Message: <3af12065@news.povray.org>
news:3af11d83@news.povray.org...
> Replacing
> merge{
> with
> blob{threshold 1
> and adding
> ,1
worked well, making it nicely scalable without any unnatural straight parts.
Will you post your modified version (the one using your lightning)?
Date: 3 May 2001 05:34:28
Message: <3af12624@news.povray.org>
I was going to but I had that stiffy(3.5" disk unable to read stuff) problem
again. Can't wait till I get a CDRW so that I can bring files from home...
I'll try again tomorrow. But I think it would be better if I could
completely replace you branches with mine. That would be easy if you could
modify your version to have only straight arms without the 'jaggedness'.
Could you try that for me. I'm still rather 'new' to coding so it's not
always that easy for me to decipher what is what.
Thanks
Nekar
