POV-Ray : Newsgroups : povray.text.scene-files : Radiosity test file #2 Server Time
17 Dec 2025 20:23:41 EST (-0500)
  Radiosity test file #2 (Message 1 to 5 of 5)
Subject: Radiosity test file #2
Date: 7 Aug 2000 12:25:57
Message: <398EE231.F90E52DC@inapg.inra.fr>
// Radiosity test file #2
// Gilles Tran - august 2000
#version unofficial Megapov 0.5;
global_settings{
        ini_option "+QR"
        radiosity{recursion_limit 5 brightness 1.2 normal on}
camera
  location  <0.0, 6, -21.0>
  direction 1*z
  right     4/3*x
  look_at   <0, 1.0,  2>
#declare Bleu=rgb<55,105,201>/255;
#declare Jaune=rgb<243,199,107>/255;
sky_sphere{
  pigment{
        gradient y
        color_map{
                [0 White]
                [1 Bleu]
#declare PdV=<-1,0.5,-0.5>*1000 ;
light_source{PdV color Jaune fade_power 2 fade_distance 2000
area_light 100*x 100*z  5,5 jitter orient
#declare txt1=texture{
        pigment{crackle solid color_map{[0 color White*0.7][1 color
White*1.3]}}
        normal{agate 0.4}
        finish{ambient -0.3 diffuse 0.8 specular 0.1 roughness 0.1
metallic brilliance 1}
        scale 0.3
#declare rd=seed(3);
#declare dis=35;
union{
        #declare i=1;
        #while (i<100)
                #declare j=0.5-rand(rd);
                #declare k=0.5-rand(rd);
                #declare l=0.5-rand(rd);
                #declare m=0.5-rand(rd);
                #declare n=1+rand(rd);
                union{
                        sphere{0,1}
                        cylinder{0,y*15,0.5}
                        sphere{0,2 scale <1,0.1,1> translate y*6}
                        sphere{0,1.5 scale <1,0.2,1> translate y*15}
                        scale n*0.3
                        translate <j,0,k>*dis
                union{
                        cylinder{0,y*(k+0.5)*10,1}
                        torus{0.8,0.2  translate y*(k+0.5)*10}
                        superellipsoid{<0.2,0.2> scale 0.7 translate
y*(k+0.5)*10}
                        scale n*0.3
                        translate <l,0,m>*dis
                #declare i=i+1;
        texture{txt1}
box{<-100,-1,-200>,<100,0,50> texture{txt1}}
Subject: Re: Radiosity test file #2
Date: 7 Aug 2000 12:44:58
Message: <398ee788@news.povray.org>
Gilles Tran <tra### [at] inapginrafr> wrote:
:         radiosity{recursion_limit 5 brightness 1.2 normal on}
  Deducing from my own tests, using a brightness other than 1 gives usually
unrealistic (but perhaps artistic) results.
  Perhaps you should try playing with diffuse values instead (if I remember
correctly that's what tells the amount of light reflected from a surface in
megapov).
  Is there some way of specifying a general diffuse value, just like the
general ambient_light value in global_settings?
Date: 8 Aug 2000 05:09:00
Message: <398FCE2C.2C76A1BE@iname.com>
> megapov).
#default{
  finish { diffuse 0.7 }
	You can put anything texture-related in the default block
an it will be used unless you override it in the object's
texture.
		Jerome
Date: 8 Aug 2000 05:39:36
Message: <398fd558@news.povray.org>
Jerome M. Berger <ber### [at] inamecom> wrote:
: #default{
:   finish { diffuse 0.7 }
  Does it work if I specify a finish (which hasn't a diffuse) in the object?
Date: 11 Aug 2000 04:43:35
Message: <3993BCB7.764510C7@tapasmail.net>
> : #default{
	Yes, as long as you don't define a diffuse it should work.
