POV-Ray : Newsgroups : povray.programming : Primitive BOX, how to wrap a texture? Server Time
29 Aug 2025 06:40:28 EDT (-0400)
  Primitive BOX, how to wrap a texture? (Message 1 to 10 of 14)
Subject: Primitive BOX, how to wrap a texture?
Date: 12 Nov 2023 08:30:00
Message: <web.6550d2d966418b42d0d0a7c459126100@news.povray.org>
First of all, I apologize for the naivety of the question.
I am not able to get the surfaces of the BOX with the actual texture.
Example:
box{<0.5000,1.0000,0.2500>,<-3,-1.0000,-0.2500>
 texture {pigment {image_map
 {png "130PINK" map_type 1
 interpolate 2
 scale 1.30
 rotate<0,360.0000,0> translate<46.7000,-0.0900,14.0700>
Well, Map 0 fails on some faces, Map 1 and map 2 deform the texture.
How can I wrap a texture correctly?
I studied the UV Mapping, but I practically understood nothing.
How should I correct my example to get the same texture uniformly on all faces?
A huge thank you if anyone helps me.
BR
Giovanni
Subject: Re: Primitive BOX, how to wrap a texture?
Date: 12 Nov 2023 09:55:00
Message: <web.6550e5f979784ca8f22cdb33dabc9342@news.povray.org>
> Example:
>  interpolate 2
>  scale 1.30
> BR
> Giovanni
There is no 'box' mapping in POV. You could hand code the box out of clipped
planes, mapping each side by rotating map 'type 0' to face each side. There's
probably a macro that someone has written to do just that.
I wrote a macro that 'box maps' the Round_Box macro. It can simulate a square
edged box if you set the edge radius fillet very low.
Miller
//  make mapped box
//  diced Round_Box() into a 6 sided uv mapped Round Box
//  m.miller  05.21.23
#include "shapes.inc"
#include "shapes2.inc"
#macro make_mapped_box (w,h,d,f,mat,z_dir)
#declare _form = object{ Round_Box(<-w/2,0,0>,<w/2,h,d>, f , 1) }
union {
    // X  right
    difference {
         object { _form }
         plane { <1,0,0>, 0 translate <w/2-f/2,0,0> }
         plane { <1,0,0>, 0 rotate <0,-45,0> translate <w/2,0,0> }
         plane { <1,0,0>, 0 rotate <0,45,0> translate <w/2,0,d> }
         plane { <0,-1,0>, 0 rotate <0,0,45> translate <w/2,h,0> }
         plane { <0, 1,0>, 0 rotate <0,0,-45> translate <w/2,0,0> }
         material {mat rotate <0,-90,0> translate <0,0,0> }
         #if (z_dir)
            material {mat rotate <0,-90,0> rotate <90,0,0> translate <0,0,0> }
         rotate <0,0,0>
         translate <0,0,0>
    // X  left
    difference {
         object { _form }
         #if (z_dir)
         rotate <0,180,0>
         translate <0,0,d>
    // Y  top/bottom
    difference {
         object { _form }
         plane {<0,-1,0> 0 rotate <0,0,0> translate <0,f/2,0>}
         plane {<0,-1,0> 0 rotate <-45,0,0> translate <0,0,0>}
         plane {<0,-1,0> 0 rotate <45,0,0> translate <0,0,d>}
         plane {<0,-1,0> 0 rotate <0,0,-45> translate <w/2,0,0>}
         plane {<0,-1,0> 0 rotate <0,0,45> translate <-w/2,0,0>}
         material {mat rotate <-90,180,0> translate <-w/2,0,0> }
         rotate <0,0,0>
         translate <0,0,0>
    // Y  top/bottom
    difference {
         object { _form }
         rotate <0,0,180>
         translate <0,h,0>
    // Y  front
    difference {
         object { _form }
         plane { <0,0,-1>, 0 translate <0,0,f/2> }
         plane {<-1,0,0>,0 rotate <0,-45,0> translate <w/2,0,0>     }
         plane {<1,0,0>,0  rotate <0,45,0>  translate <-w/2,0,0>   }
         plane {<0,-1,0>,0   rotate <45,0,0>  translate <0,h,0> }
         plane {<0,1,0>,0   rotate  <-45,0,0>  translate <0,0,0> }
         material {mat rotate <0,0,0> translate <-w/2,0,0> }
         rotate <0,0,0>
         translate <0,0,0>
    // Y  back
    difference {
         object { _form }
         rotate <0,180,0>
         translate <0,0,d>
Usage example:
#declare _mat    =   M_wood;
#declare _z_dir  =   1;
#declare _fillet =   .2;
#declare _width  =   5;
#declare _height =   5;
#declare _depth  =   10;
object { make_mapped_box(_width, _height, _depth, _fillet, _mat, _z_dir)
translate <0,0,-_depth/2> rotate <0,30,0> translate <-10,0,0>}
Download 'box_mapped_uv.png' (703 KB)
Preview of image 'box_mapped_uv.png'
Date: 12 Nov 2023 10:20:00
Message: <web.6550ecb079784ca8d0d0a7c459126100@news.povray.org>
> > BR
> > Giovanni
> Miller
> //  make mapped box
> union {
>     // X  right
>     difference {
>          object { _form }
>          #if (z_dir)
>          #end
>          rotate <0,0,0>
>          translate <0,0,0>
>     // X  left
>     difference {
>          object { _form }
>          #if (z_dir)
>          #end
>          rotate <0,180,0>
>          translate <0,0,d>
>     // Y  top/bottom
>     difference {
>          object { _form }
>          rotate <0,0,0>
>          translate <0,0,0>
>     // Y  top/bottom
>     difference {
>          object { _form }
>          rotate <0,0,180>
>          translate <0,h,0>
>     // Y  front
>     difference {
>          object { _form }
>          rotate <0,0,0>
>          translate <0,0,0>
>     // Y  back
>     difference {
>          object { _form }
>          rotate <0,180,0>
>          translate <0,0,d>
> #end
> Usage example:
Thank you very much, now I am sure that it is not possible and therefore my
technique makes sense, very similar to yours, for which I thank you.
My parser for PovRay from AutoCAD, written in lisp, in fact, works like this
(polygons instead of planes):
(if (= "DKBCASE"  block)
 (progn
 (IniPovObj)
(write-line (strcat "union
{polygon{5,<-.5,0,.5><.5,0,.5><.5,0,-.5><-.5,0,-.5><-.5,0,.5>") fil) ;1 BOTTOM
(write-line (strcat " scale<"(rtos scX)","(rtos scZ)","(rtos scY)">") fil)
(setq need 0) (filler)
(if (= need 1)(write-line "}" fil))(if (= need 2)(write-line "}}" fil))(if (=
need 3)(write-line "}}}" fil)) ;endif
(write-line rotateXstring fil)(write-line closestring fil)
polygon{5,<-.5,1,-.5><-.5,1,.5><.5,1,.5><.5,1,-.5><-.5,1,-.5>") fil) ;2 TOP
(setq need 0) (filler) ............
NOTE the Sub filler essewntially chooses the image...
MANY THANKS!
G.
Date: 12 Nov 2023 10:25:00
Message: <web.6550ed8079784ca81f9dae3025979125@news.povray.org>
> Example:
>  interpolate 2
>  scale 1.30
> BR
> Giovanni
Check out:
https://wiki.povray.org/content/Reference:UV_Mapping
The key lines that you want to pay attention to are:
    uv_mapping
The uv_mapping statement needs to preceed everything else in the texture
definition for it to work.
Also, depending on how you want that box mapped, then yes, there is indeed a box
mapping, but you need to set up the texture specifically to do that, which might
not be a simple task.
- Bill
Date: 12 Nov 2023 10:55:00
Message: <web.6550f50179784ca8d0d0a7c459126100@news.povray.org>
> > Example:
> >  interpolate 2
> >  scale 1.30
> > BR
> > Giovanni
> Check out:
> texture {
>     uv_mapping
> - Bill
Thanks!
in fact I tried but I didn't understand how to implement UV mapping. We would
need at least one example on a cube, on which the texture is wrapped uniformly.
Then everything else, scaling, translating, rotating, re-proportioning on the
axes, is simple.
G
Date: 12 Nov 2023 11:30:00
Message: <web.6550fcf479784ca81f9dae3025979125@news.povray.org>
> Thanks!
No problem.  I've been at this for 10 years, and just recently got pretty
confused about the specifics.
https://news.povray.org/povray.general/thread/%3Cweb.641d4cf6eebe912c9b4924336e066e29%40news.povray.org%3E/
We would
Right.  So if you look at the diagram on the wiki, it will show you what needs
to be where, and the exact coordinates for all of the faces.  So you could
image-map some squares and render that with an orthographic camera to give you
an image-map suitable for further uv-mapping,
or
you could write some more complex code to just grab the filenames and make the
uv-mapping texture in memory and do everything in a 1-step render.  And I'd
really need to go look up and study the exact details of doing it that way.
> axes, is simple.
Yes.
- BW
Date: 12 Nov 2023 12:15:00
Message: <web.6551072a79784ca8f22cdb33dabc9342@news.povray.org>
> > > Example:
> > >  interpolate 2
> > >  scale 1.30
> > > BR
> > > Giovanni
> > Check out:
> > texture {
> >     uv_mapping
> > - Bill
> Thanks!
> axes, is simple.
> G
This is one simple way I've mapped boxes or flat surfaces at different angles.
Create the surface slightly larger than what's needed. Difference the surface
with plane or planes that match the angles needed. The planes would carry the
material and transferred the image_map or material to the differenced shape.
Each rotated plane can have its own material, so a 6-sided cube could have 6
materials.
Hope this help,
Mike.
Download 'box_differenced_planes.png' (482 KB)
Preview of image 'box_differenced_planes.png'
Date: 12 Nov 2023 12:55:00
Message: <web.6551112779784ca81f9dae3025979125@news.povray.org>
Also, I forgot to mention the cubic pattern, which might make things
substantially easier.
https://wiki.povray.org/content/Reference:Cubic_Pattern
Date: 12 Nov 2023 13:10:00
Message: <web.6551141d79784ca8f22cdb33dabc9342@news.povray.org>
What! ...cubic pattern.
Does it work with image maps? I'm guessing so, since it references textures.
Must try out. I have an architectural project that could benefit.
Thanks, Mike.
Date: 12 Nov 2023 13:55:00
Message: <web.65511f7879784ca81f9dae3025979125@news.povray.org>
> Thanks, Mike.
:D
I know, right?   POV-Ray has SO much stuff that it's difficult to even keep
track of it all, let alone document it, or implement it.
Maybe check out this thread for starters:
https://news.povray.org/povray.binaries.images/thread/%3C5a6748f8%241%40news.povray.org%3E/
- Bill
