POV-Ray : Newsgroups : povray.programming : Compiling Povray Server Time
10 Nov 2025 17:24:38 EST (-0500)
  Compiling Povray (Message 1 to 3 of 3)
Subject: Compiling Povray
Date: 15 Jun 2016 19:10:00
Message: <web.5761df7a646f836a3179dcc70@news.povray.org>
I'm trying for the first time to compile Povray 3.7. I have the package that is
available at github. I've figured how to modify configure.ac to reflect where
I've stored the paths to various files requires but now get these error messages
from autoconf.
error: possibly undefined macro: AM_INIT_AUTOMAKE
error: possibley undefined macro: AM_MAINTAINER_MODE
I have no idea how to start to fix this. Any suggestions?
Subject: Re: Compiling Povray
Date: 16 Jun 2016 09:10:06
Message: <5762a52e@news.povray.org>
Am 16.06.2016 um 01:06 schrieb Ken Shumway:
> from autoconf.
The configure.ac is _not_ intended to be modified directly.
If you pull the newest master branch, and look at the install
instructions in the Unix folder, you should find a note instructing you
to run
    cd unix
    ./prebuild.sh
    cd ..
before anything else. From there on, installation should be more or less
as you expect, i.e. the next steps should be to execute the
`./configure` script and then run `make`. (Note though that POV-Ray's
`./configure` needs a mandatory parameter, something like BUILT_BY or
COMPILED_BY, I keep forgetting its name; but `./configure` will tell you
if you invoke it without.)
The reason behind the `prebuild.sh` script is that POV-Ray is maintained
on GitHub as a platform-neutral project. Among other things this means
that we don't tolerate any platform-specific stuff whatsoever outside of
dedicated subdirectories (such as the `unix` and `vfe/unix`
directories). For platforms where this essentially breaks the build
process (as is the case on Unix), we provide a special script (namely
the `prebuild.sh` script in case of the Unix platform) that converts the
platform-neutral source package (where the platform-specific stuff is
safely tucked away) into a platform-specific one (where the
platform-specicif stuff may be all over the place, as required to build).
Date: 17 Jun 2016 17:50:00
Message: <web.57646fea82342ad63179dcc70@news.povray.org>
> > from autoconf.
> to run
>     cd unix
>     ./prebuild.sh
>     cd ..
Thank you for your time.  I'll try to do this as you suggested and ask more
questions if it doesn't work.
