POV-Ray : Newsgroups : povray.programming : Question Server Time
29 Aug 2025 11:14:44 EDT (-0400)
  Question (Message 1 to 5 of 5)
Subject: Question
Date: 22 Dec 2006 14:45:00
Message: <web.458c35984f812b1842494bfa0@news.povray.org>
I have one small question.
Does Pov-ray 64 bit works with two core processors ?
I know that it is not place for this type of question but I didn't know
where put question about hardware.
Thanks.
Subject: Re: Question
Date: 22 Dec 2006 14:55:00
Message: <web.458c37a05d955ca542494bfa0@news.povray.org>
And one more thing.
Is it possible to make calculations at joined into cluster ?
I want to know because my calculations of isosurfaces with radiosty are
horrible :(:(:( long. I want to start making photorealistic scenes, but it
needs isosurfaces which containing several funcions (including sclaed noise
and fractals), and multi layered textures. When I'm adding rodiosty to this
i can forget about doing any other things at computer by next few weeks
Date: 22 Dec 2006 15:48:13
Message: <458c448d$1@news.povray.org>
It works, but uses only one core. 3.7 is promised to be threaded so
it'll utilize both cores.
Eero "Aero" Ahonen
   http://www.zbxt.net
Date: 23 Dec 2006 02:55:59
Message: <458ce10f$1@news.povray.org>
In the meantime, there are other methods.  For instance, I believe
there's a system called SMP-Pov, which will distribute the render
throughout a cluster (however, I believe it has issues with radiosity).
If you're doing an animation, you can submit it to the IMP
(www.imp.org), and it will be farmed out to several machines.
...Chambers
Date: 23 Dec 2006 07:05:10
Message: <458d1b76$1@news.povray.org>
Then please don not post it here. A proper place for your question would
have been povray.general .
	Thorsten, POV-Team
