POV-Ray : Newsgroups : povray.programming : media emission value Server Time
26 Jun 2024 06:26:33 EDT (-0400)
  media emission value (Message 1 to 6 of 6)
Subject: media emission value
Date: 13 Jul 2005 15:25:01
Message: <web.42d5698252c58b6d2b4e50870@news.povray.org>
I was looking for the part in media.cpp where emission of the media is
applied to the radiosity values. When media is in the radiosity statement
then the emission of the media adds to the radiosity. Knowing this I was
going to tinker and see if I can increase the emission effect on the
radiosity value. To make the radiosity value think there is more emission
than there is.
This the first time I have taken a serious look at the source. :) But to
learn I must start some place.
Thanks in advance.
Subject: Re: media emission value
Date: 14 Jul 2005 02:15:01
Message: <db4vmr$9te$1@chho.imagico.de>
> than there is.
Radiosity is calculated by tracing rays in the scene, just like normal
camera rays, there is no special handling of media for radiosity.  To do
what you describe you would need the media sampling code to selectively
increase the media intensity if a radiosity evaluation is detected.
Doing this does not make a lot of sense.  You can already achieve what
you want using the no_radiosity flag in MegaPOV - create one instance of
your media object with stronger media and no_image, no_reflection and
no_shadow and the normal one with no_radiosity.
http://www.tu-bs.de/~y0013390/ (Last updated 01 Jul. 2005)
Date: 14 Jul 2005 16:00:04
Message: <42d6c444$1@news.povray.org>
Despite the fact that this effect can be achieved without modifying the
source code, I was wondering: there *is* some special handling of media for
radiosity, since by default it doesn't affect radiosity, right? So there
must be some way that radiosity rays are flagged to ignore media unless
"media on" is specified.
Of course, that doesn't mean it would be easy to modify that bit of code to
change the effect of media.
 - Slime
 [ http://www.slimeland.com/ ]
Date: 14 Jul 2005 16:30:02
Message: <db6hrj$3v2$1@chho.imagico.de>
This is done by setting the quality flags accordingly.
Date: 15 Jul 2005 11:35:00
Message: <web.42d7d773c3eedf722b4e50870@news.povray.org>
> > than there is.
> Christoph
It seems to me that this duplicated manner would be quite slow. I was
looking for a way to force the radiosity calculation to gather a high and
thus brighter value from the media. A media multiplier value. I was looking
for the location in the code that this value could be placed. I speculated
that it could be one location or many. I just did not know where to look.
Date: 15 Jul 2005 11:55:02
Message: <db8m7s$m50$1@chho.imagico.de>
The slowdown depends on how expensive the intersection test for the
container is - but unless you use an extremely slow isosurface or
similar it is unlikely that this is considerable compared to the media
evaluation - there are no additional media calculations necessary with
this technique.
The place is sample_media() in media.cpp.  As it is you don't have a way
to determine if the evaluation is in a radiosity ray or not (the
NO_RADIOSITY_PATCH in MegaPOV provides one though).
