POV-Ray : Newsgroups : povray.programming : Strange piece of code Server Time
29 Jun 2024 00:31:24 EDT (-0400)
  Strange piece of code (Message 1 to 2 of 2)
Subject: Strange piece of code
Date: 15 Jun 2005 12:25:01
Message: <web.42b05583856a31da367138710@news.povray.org>
Hello.
in lighting.cpp line 2772:
if (Cos_Shadow_Angle < EPSILON)
   return;
What's the role of this code ?
It disturbs me. It avoids lauching a new ray to the light source and put the
object into dark at that pixel even if the object is no under the shadow...
When I remove it, it works better !
lmagnin *at* ens-lyon *dot* fr
Subject: Re: Strange piece of code
Date: 15 Jun 2005 14:12:36
Message: <42b06f94@news.povray.org>
>    return;
  If the cosine of the angle between the normal vector and the light
vector is negative it means that the normal vector is pointing away
from the light source. That is, the surface is pointing away from
the light source. It shouldn't thus be illuminated.
  I assume that if you remove that piece of code, all your surfaces
will be double-illuminated.
