POV-Ray : Newsgroups : povray.programming : Rendering CDs (diffraction) Server Time
15 Dec 2025 13:51:38 EST (-0500)
  Rendering CDs (diffraction) (Message 1 to 6 of 6)
Subject: Rendering CDs (diffraction)
Date: 12 Jan 2005 05:25:00
Message: <web.41e4fa17439a08055c365a340@news.povray.org>
Hi folks.
I'm trying to work out how to render some complex surfaces with a CD-like
diffractive finish. I can't visualise it, so I can't cheat as I would if I
only wanted a CD: I want the computer to calculate it for me.
I can't find any mention of diffraction in the POV-Ray keywords; can someone
confirm that it's not supported? Is anyone working on something like this?
If not, the 'irid' keyword changes colour based on light/surface angle, and
I know diffraction is related to the incident angle (and wavelength, path
difference, etc), so I'm guessing I could start hacking things there and
mess about with photons?
Cheers,
Tim
Subject: Re: Rendering CDs (diffraction)
Date: 12 Jan 2005 05:40:06
Message: <evu9u0dppbtdct1t6rrr8luedfftr0osjd@4ax.com>
On Wed, 12 Jan 2005 05:22:26 EST, "Warwick" <nomail@nomail> wrote:
> Hi folks.
Hi.
That's fine but please note that this is wrong group for discutting this. Your
question is about scene source code technic _for_ POV-Ray at run-time while
this group is about issues related to source code _of_ POV-Ray and building of
this application. This is a common misconception which could be avoided by
reading http://news.povray.org/%3C3D4C20DA.40C33E49%40pacbell.net%3E
http://www.google.com/search?q=diffraction+site:povray.org
> can someone confirm that it's not supported? Is anyone working on something like
this?
http://runevision.com/show.asp?id=95
One can argue whether using photons is a hack or not ;-)
ABX
Date: 12 Jan 2005 20:00:01
Message: <web.41e5c677f6fe36175c365a340@news.povray.org>
No, I intended to ask in the source-code programming group: I expected to
have to flex my C programming muscles to achieve this. Sorry I didn't
make that clear.
My question about there being no POV-Ray keyword (primitive) to support
diffraction was just to make sure I'd not missed something - like 'irid'
for 'iridescence'. I had looked pretty carefully before posting, but one
can always miss something.
Mm. I did this before I posted. There were a couple of 'It's too
difficult/slow', but I think I'm actually trying for one of the particular
effects of diffraction, rather than real diffraction, so I may be
successful.
this?
This is interesting, and it'll be instructive to understand how it works,
but it's too impressionistic for my purposes.
Heh.
I'm going to fiddle around and see how far I get - iridescence uses
light/surface angle, and I believe I should be able to make some progress
combining that with camera/surface angle. I will need to work out how to
'brush' the CD tracks eventually though - I don't plan to keep them
circular - so I'll hopefully be back for suggestions before terribly long.
Cheers,
Tim
Date: 16 Feb 2005 19:50:00
Message: <web.4213e831f6fe3617ec12ceb00@news.povray.org>
So I've had a fiddle, and managed this - no photons involved, very fast
render.
http://www.baverstock.org.uk/tim/images/povdemo5.jpg
Kinda pretty.
Here's most of the hack - the rest is just trivially changing all the
do_irid()
function calls so they supply REye as the third parameter.
http://www.baverstock.org.uk/tim/images/lighting.cpp
Any good? I haven't a clue what the Travel_Diff *1000 scaling factor's
doing - what are POVRay's native units anyway?
I need to work out how to make Track_Field represent CD tracks on a flat
surface - it's currently just a constant vector.
Cheers,
Tim.
Date: 2 Aug 2005 16:35:00
Message: <web.42efd7d8f6fe36173abed3590@news.povray.org>
If memeory serves me right, there are none -- if I use a box from <0,0,0> to
<1,1,1> in the SDL file, it could end up being a square centimetre, a
square inch, or a square hectare.
Date: 24 Nov 2005 01:45:00
Message: <web.4385604cf6fe361774f3166b0@news.povray.org>
I dunno...  what with it being from <0,0,0> to <1,1,1>, I think it's more
likely a cubic whatever than a square whatever.  (Heh.)
But yeah - there are no innate units to the coordinates.  Just make sure
that 1u is consistent between all objects, or you run into six-inch-tall
streetlights, a donut the size of a VW Beetle, etc.
(Also...  if memory serves, isn't a hectare a unit of area already?  So a
square hectare is...  um...  10^8 quartic [tesseractic?  There's no really
GOOD term for it, y'know] meters.  Dunno about you, but I prefer keeping my
measurements in 3-space at most...  saves headaches for the readers.  :->)
