POV-Ray : Newsgroups : povray.programming : Interior in Mesh/Mesh2 or Polygonal-Objects Server Time
28 Sep 2024 18:43:21 EDT (-0400)
  Interior in Mesh/Mesh2 or Polygonal-Objects (Message 1 to 5 of 5)
Subject: Interior in Mesh/Mesh2 or Polygonal-Objects
Date: 10 Jan 2005 09:10:00
Message: <web.41e28b1b78c5ef127d362a450@news.povray.org>
Hi...
I was thinking about a way to specify an interior for mesh/mesh2 or
polygonal objects. My incoming data will be a closed polygonal model or a
triangle mesh (I don't know for sure yet) - it shall resemble a solid
object. I will need refraction, attenuation and I guess dispersion to work
properly in it, so that the rays behaves like in a real solid object.
Is the only way to do it to change the mesh/meh2 or polygon - code in a way
that there can be a interior defined for it? - This would include a test if
the ray is inside entering or leaving the object, right? I hope for an
easier way, but I don't know where to start looking...
Can anybody give me a hint?
Subject: Re: Interior in Mesh/Mesh2 or Polygonal-Objects
Date: 10 Jan 2005 09:16:13
Message: <mf35u0lktlo35u4tv9ipnpst4gkrpi1n0f@4ax.com>
> polygonal objects. (...) Can anybody give me a hint?
Hint: http://www.google.com/search?q=inside_vector+POV
ABX
Date: 10 Jan 2005 11:13:50
Message: <41e2a9be@news.povray.org>
  Refraction, attenuation and dispersion work just ok regardless of
whether you are using a mesh or a sphere. They are in no way affected
by the "solidness" of the object.
  Have you actually *tried* what happens if you use refraction, etc.
with a mesh?
Date: 10 Jan 2005 11:14:40
Message: <41e2a9f0@news.povray.org>
  It's useless to use inside_vector for refraction, attenuation and
dispersion because these features don't care about the "solidness" of
the object.
  The only place where you need inside_vector is in CSG.
Date: 22 Jan 2005 08:07:21
Message: <h0k4v0lptae788uu06nuh49okmdu1sha9s@4ax.com>
wrote:
to my knowledge you can use "interior" with mesh2 objects.
Just try it play with ior and other parameters.
-tb
>Hi...
