POV-Ray : Newsgroups : povray.programming : Another high dynamic range format: FNG Server Time
15 Dec 2025 20:50:17 EST (-0500)
  Another high dynamic range format: FNG (Message 1 to 10 of 12)
Subject: Another high dynamic range format: FNG
Date: 25 Apr 2004 15:18:58
Message: <cjameshuff-D83196.15175325042004@news.povray.org>
I've created a new image format for storing high dynamic range images.
The new format is quite simple to implement: it is basically a 16-bit
PNG with a gamma of 1, using half-precision floating point numbers
instead of 16 bit integers. It's a bit of a hack, but it seems to work
quite well.
The floating point format I use is 5 exponent bits, giving an exponent
range from -16 to 15, and 11 mantissa bits, for a range of 0 to 2047. I
did not include a sign bit, thus the format can only contain positive
values...I do not think negative values are useful enough to warrant the
loss in precision. I might add a second 1-5-10 format if it turns out to
be useful.
Benefits: you get basically all the benefits of the PNG format, such as
compression. The other HDRI formats I've seen are uncompressed or use
relatively crude forms of compression, and tend to result in huge files.
Implementation is quite easy. Once you have PNG reading/writing, FNG is
just a few extra lines. The resulting files are actually readable by PNG
viewers...the colors are dimmed in the resulting display, but the image
is recognizable.
http://tag.povray.org/
Subject: Re: Another high dynamic range format: FNG
Date: 26 Apr 2004 06:45:49
Message: <408ce85d$1@news.povray.org>
> quite well.
	Cool !
	The question now is: are you going to patent your idea, or will
you release it shortly in the form of an OpenSource project ?  ;-)
	- NC
Date: 26 Apr 2004 07:44:09
Message: <cjameshuff-BB3A15.07430626042004@news.povray.org>
In article <408ce85d$1@news.povray.org>,
> > quite well.
> 	Cool !
Heh, the way things are going these days, I might need to patent it in
self-defense...
I'm going to release it after I have a few more tools...currently, I
have a viewer and converters to/from PNG, I plan to write converters
to/from some other HDRI formats. At the very least, I need to implement
grayscale and some kind of PNG meta-data tag to identify the FNG files
as such.
Date: 26 Apr 2004 08:20:02
Message: <c6iui9$54s$1@chho.imagico.de>
> quite well.
> be useful.
This is an interesting idea although as long as there isn't support for
such files at least in some applications it will not be so useful.  You
might consider proposing this to the libpng guys so it might get added
to libpng.
Signed values might be useful for non-Image applications but in most
cases you would want at least 32bit floating point values for this.
Last updated 21 Mar. 2004 _____./\/^>_*_<^\/\.______
Date: 26 Apr 2004 09:16:04
Message: <408d0b94@news.povray.org>
> You
> to libpng.
	But using floating point in this format as Christopher describes
is not "portable" (the P in PNG) anymore, or am I wrong somewhere ?
	- NC
Date: 26 Apr 2004 09:18:32
Message: <408d0c28$1@news.povray.org>
[answering to myself]
	Yes, most likely.
	- NC
Date: 26 Apr 2004 10:48:20
Message: <cjameshuff-9B3744.10471726042004@news.povray.org>
In article <408d0b94@news.povray.org>,
> > You
> > to libpng.
It is portable.
The portability problem with binary data comes from the fact that the
native format may have a different layout on different platforms. The
FNG code encodes and decodes the actual bit pattern, and will read and
write it the same way on all platforms.
Date: 26 Apr 2004 11:06:17
Message: <cjameshuff-C83AD1.11051426042004@news.povray.org>
In article <c6iui9$54s$1@chho.imagico.de>,
That's why I'm working on converters to/from other HDRI formats. ;-)
> You might consider proposing this to the libpng guys so it might get
> added to libpng.
That is a good idea...it obviously wouldn't take much to add, basically
just define another couple color types. Optimal compression might be a
bit harder...
Hmm...sFNG? (signed FNG)
FNG32? (How to fit the extra bits in?  Probably a custom data "chunk".)
Date: 26 Apr 2004 11:15:02
Message: <c6j8q1$6rh$1@chho.imagico.de>
> It is portable.
And actually the same would be possible for 32bit floating point values,
you just would need to have a convention for the distribution of bits
for mantissa/exponent and a file format storing 32bit values (which png
IIRC does not).  And of course reading such files would be slower than
reading the native binary format of that particular platform.
Date: 26 Apr 2004 12:04:50
Message: <408d3322$1@news.povray.org>
> It is portable.
	Indeed, and this is why I answered to myself that I was wrong.
It's just that I'm so used to softwares writing raw floating-point data
by people who don't even know what is endianness that I was immediatly
suspicious of using floating point in PNG... until I re-read your
message and the bit distribution you proposed.
	As Christoph suggests, that would be quite nice to make it in
the official PNG format, instead of making it a derivative.  That could
go in e.g. libpng-1.3 -- the only drawback is: when would it appear ?
(png and zlib developpers are not particularly fast at releasing new
versions, and I don't know their policies in accepting contributions).
	- NC
