POV-Ray : Newsgroups : povray.programming : Alternative rendering algorithm Server Time
4 Jul 2025 11:05:11 EDT (-0400)
  Alternative rendering algorithm (Message 1 to 4 of 4)
Subject: Alternative rendering algorithm
Date: 9 Apr 2004 14:41:30
Message: <cjameshuff-1204FF.14421809042004@news.povray.org>
The main reason glass objects are so slow to render is the fact that
they require tracing two additional rays for each ray that hits a glass
surface, one for reflection, one for refraction. This means that the
number of rays increases with trace level as the nth power of 2: at a
trace level of 2, 4 additional rays are required. With a trace level of
5, 25 additional rays are required. If you have max_trace_level of 12 in
a scene with a lot of glass, you may need to trace as many as 144 extra
rays.
Some time ago, I heard about another method that follows rays through
the scene one path at a time instead of splitting the rays at each
surface. When a surface that both reflects and refracts is hit, one of
the two is chosen at random. This is done many times for each pixel,
sampling the possible light paths without taking the time to compute all
of the deepest, least important paths and taking care of antialiasing at
the same time.
I did some tests using my own raytracer, and it is possible to get good
results with a very good increase in rendering speed. I've come up with
two different algorithms based on this technique. The first chooses
randomly between refraction and reflection for each material evaluation,
which gives grainy results unless a lot of samples are used. The second
makes these choices for an entire pass of the image. That is, it renders
the image in multiple passes, deciding whether to do reflection or
refraction for each trace level and using the same choices for the
entire image pass. 64 passes with this technique took 5 minutes, where
the traditional technique required 9 minutes.
I've posted three images in povray.binaries.images demonstrating the
traditional method and the two new methods.
http://tag.povray.org/
Subject: Re: Alternative rendering algorithm
Date: 9 Apr 2004 15:35:02
Message: <c56tkq$mtt$1@chho.imagico.de>
That's how you do it with path tracing - noisy images are usually the
result unless you use really lot of samples.
You mean 64 passes together 5 minutes?  And how do you combine them?
The problem also is you usually don't have only reflection and
refraction but also a diffuse part.
Were not viewable here.
Last updated 21 Mar. 2004 _____./\/^>_*_<^\/\.______
Date: 9 Apr 2004 17:51:45
Message: <40771af1@news.povray.org>
  Perhaps posting in a way which is viewable by other people may be a
good idea.
  I only saw three posts with an attachment called "attachment" (and
nothing else). Absolutely no way of knowing what it is and how to
look at it. Not a very good idea if you really want people to see
them.
Date: 9 Apr 2004 20:17:12
Message: <cjameshuff-9FD7D7.20175909042004@news.povray.org>
In article <c56tkq$mtt$1@chho.imagico.de>,
The second path tracing method uses the same choices for every pixel of
a pass, removing the noisiness. However, that means the entire image is
equally inaccurate if you use too few samples. (or get really unlucky)
I've also had good results with using single-path tracing once the trace
level reaches a certain depth. Splitting for the first 3 levels and then
following single paths seems to give good results with few samples, and
trimming out enough of the deeper rays to give a good speedup.
Yes.
A simple average. Each pass is traced at a slight offset, with the
result of the ray origins covering the pixels.
That's always computed, no matter what. I could make it a third "path",
but I don't think the results would be very good.
Try the new posts.
