POV-Ray : Newsgroups : povray.programming : Switch off alpa usage with image_map Server Time
15 May 2026 12:24:06 EDT (-0400)
  Switch off alpa usage with image_map (Message 1 to 4 of 4)
Subject: Switch off alpa usage with image_map
Date: 27 Jan 2005 04:21:08
Message: <9gchv091plp06rudt9mlavvanlpfvhloq6@4ax.com>
Gents,
is there a way to switch off alpha channel usage with imape maps?
I knwo that you can enable/disable alpha with image_pattern, but image
map uses always alpha.
Thank you
-tb
Subject: Re: Switch off alpa usage with image_map
Date: 3 Feb 2005 19:00:15
Message: <4202bb0f$1@news.povray.org>
This is the wrong group for this question.  This group is for discussion of
the POV-Ray source code.  Questions about using the POV-Ray should be asked
in either povray.general or povray.newusers.
     Thorsten
Thorsten Froehlich
e-mail: mac### [at] povrayorg
I am a member of the POV-Ray Team.
Date: 5 Feb 2005 10:08:34
Message: <q5o9019eqmrf6f5r8vm0vuuf8oscqd4kgl@4ax.com>
On Thu, 03 Feb 2005 18:00:15 -0600, Thorsten Froehlich
<tho### [at] trfde> wrote:
Thorsten,
sorry for wrong group, but this question is not for general or newuser
because there is simply nothing to switch on/off for the user, so code
needs to be added.
if you look into the code then you will see that alpha channel is
always used if present.
So in order to make my question more clear:
Is there any intention to implement such switch?
If not can i do it?
Thank you
-tb
>     Thorsten
>Thorsten Froehlich
Date: 5 Feb 2005 10:25:02
Message: <cu2of8$r9$1@chho.imagico.de>
> If not can i do it?
I don't think there is a need for such a feature - what's wrong with
loading the image in a paint program, removing alpha channel and saving
again?  If you want this automatized you could use ImageMagick.
BTW even if this is about a feature suggestion this is the wrong group.
Follow-up set.
Last updated 23 Sep. 2004 _____./\/^>_*_<^\/\.______
