POV-Ray : Newsgroups : povray.programming : Scripting language for multiplatform distribution? Server Time
21 Jun 2026 01:20:59 EDT (-0400)
  Scripting language for multiplatform distribution? (Message 1 to 10 of 24)
Subject: Scripting language for multiplatform distribution?
Date: 13 Apr 2011 18:38:05
Message: <4da625cd$1@news.povray.org>
Hi All:
   At last, after some 8 months, I'm nearly finished with my
lightmap-baking demo/tutorial. The technique I developed works great
within the limitations of lightmapping, but I've a problem deciding
which scripting language to use for a little external tool that is
necessary to write some files.
   I tried at first to use only POV-Ray for that, but there was a little
obstacle which forced me to use some external programming: I need to
read the geometry file exported by Poseray, to find the objects and
materials names... so I cannot use POV-Ray file I/O.
   As I'm used to write and read text files with PHP, I just wrote a
little script for use with PHP_CLI from the command line. It works
great for me, but perhaps it isn't a great choice for multiplatform
distribution... The problem is I cannot find anything better, as I will
prefer to distribute just a configurable text file.
   Any recommendations? (or perhaps I overlooked a way to do it only with
POV-Ray?)
Jaime Vives Piqueres
http://www.ignorancia.org
Subject: Re: Scripting language for multiplatform distribution?
Date: 13 Apr 2011 22:21:27
Message: <4da65a27$1@news.povray.org>
> POV-Ray?)
Something you can write in a portable scripting language that you can wrap
up as a stand-alone executable for various common platforms is probably
best. I use Tcl for that, personally.
   "Coding without comments is like
    driving without turn signals."
Date: 13 Apr 2011 22:45:01
Message: <web.4da65ef8696194143f390d5d0@news.povray.org>
> > POV-Ray?)
it's a good choice, yes.  And even Tcl is a more sane language than PHP, aside
from the spaghetti-code like nature of being able to eval local variables in
"upper" environments... lol
Date: 13 Apr 2011 23:43:17
Message: <4da66d55$1@news.povray.org>
If you do that for writing anything except your own flow control statements,
you deserve what you get.
Date: 14 Apr 2011 06:59:39
Message: <4da6d39b@news.povray.org>
>> with POV-Ray?)
>  wrap up as a stand-alone executable for various common platforms is
>  probably best. I use Tcl for that, personally.
   Perhaps I didn't emphasize it enough, but I really hoped not to have
to distribute an executable... the script is very simplistic right now:
it just defines some configuration variables at the top, and uses them
to read a POV-Ray include file, extract objects and material names, and
write some resulting files.
   So, at the moment, the "user" needs to edit the script before using it
on his own scenes. The ideal situation would be to write this tool with
POV-Ray SDL, so I could be sure any POV-Ray user will have the means to
use it, but I think this is not possible.
   Being that lazy, I didn't want to implement proper command-line
arguments or input dialogs, as the whole thing it's just a "proof of
concept" demo. But I would like others to test it, so I guess I will
have to...
Date: 14 Apr 2011 08:22:57
Message: <4da6e721@news.povray.org>
> >> with POV-Ray?)
  Perhaps you could write several versions of the script for the scripting
languages that are most "native" to each of the three major operating
systems. IIRC there's some scripting language that Windows supports
out-of-the-box, and on the linux side you have plenty to choose from
(one to consider, if possible, is using shell scripting, if its features
are enough, as that's the most ubiquitous in unix/linux). On the Mac you
could look at AppleScript, which is supported natively (or if the shell
scripting works, it should work there as well, although Mac users are not
very accustomed to using the command line).
Date: 14 Apr 2011 09:45:01
Message: <web.4da6fa27696194149a1bcfb90@news.povray.org>
> > >> with POV-Ray?)
I fail to see the advantage of going bonkers providing multiple versions of the
same script to support multiple "native" scrpting environments when there are
multiple far better offerings than the native stuff that are both a fast and
free download and also multiplatform.
Jaime, being able to wrap your script in an executable together with the
interpreter is a bonus.  Tcl is just like any other scripting language and you
can just distribute the script and a link to where to obtain the interpreter.
I prefer python as a language, but Tcl is a good choice too.
Date: 14 Apr 2011 09:56:52
Message: <4da6fd23@news.povray.org>
  You fail to see the advantage? How about you take the script and just
run it, without having to figure out what else you need to download and
install before you can run it. The less steps one needs to run the script,
the better.
Date: 14 Apr 2011 11:16:02
Message: <4da70fb2$1@news.povray.org>
Am 14.04.2011 00:38, schrieb Jaime Vives Piqueres:
Any popular general-purpose scripting language will probably do: I guess
Perl, Python and Ruby all come with interpreters for most any platform
you might name.
I know none of these, so like Darren I'd personally go for Tcl; as
already mentioned, you don't need to use Tk (the most popular GUI
toolkit for Tcl), but I find it a nice-to-have. I know of free
interpreters for both Linux and Windows, and I guess there's something
for the Mac available as well.
One thing that should be noted is that not all people accept all
scripting languages equally well, and some may refuse to install
interpreters for whatever language you choose. I, for instance, would
hesitate to install a PHP interpreter on my machine, but would be ok
with Perl, Python or Ruby (and, as you probably guess, have Tcl
installed already); I must confess this is an only marginally
rationalized preference, but I may not be alone with such a preference.
Interestingly enough, I don't recall ever hearing anyone take a
categoric stance against Tcl, so it might raise the fewest resentments.
That said, when it comes to writing platform-independent scripts with
the intention to distribute them, I think the most commonly used
language for such a purpose might be Perl.
In case you should decide to split up the script into a kind of config
file and the actual code, Java would probably be the way to go.
Date: 14 Apr 2011 11:57:47
Message: <4da7197b@news.povray.org>
> the better.
Well, as nemesis says, my intention was to suggest a simple cross-platform
scripting language (like Tcl or Python) for the script, *plus* do the
up-front work of wrapping it in a native no-install executable for each of
the major platforms if you care to promote usage. Distribute both the short
script and the "use this if you don't want to install the scripting
environment" version.
My MakeDF3 code[*] is like that.  It's a Tcl script that I run through
freewrap, so you have MakeDF3.tcl if you want to edit it or you already have
Tcl installed, or MakeDF3.exe if you're on Windows and you just want to use
the tool and don't mind that it takes up another meg of disk space.
If you're just writing files and not using a whole bunch of utility
libraries, writing it in C and asking someone to compile it for each
platform for you can also work well. Once you start linking in things like
Windows or Linux packages, that becomes less feasible.
