POV-Ray : Newsgroups : povray.programming : function x=y=z Server Time
11 Nov 2025 05:05:18 EST (-0500)
  function x=y=z (Message 1 to 4 of 4)
Subject: function x=y=z
Date: 16 Jun 2004 03:24:57
Message: <40cff5c9@news.povray.org>
Completly newbe, i used that :
  background{White}
    angle 15
    location <0,2,-10>
    look_at <0,0,0>
  light_source { <10, 20, -10> color White }
cylinder {
<-1000,-1000,-1000>, // starting point
<1000,1000,1000>, // ending point
0.002 // radius
pigment { rgb 0.1 } // white
it is working, i have a line, but, in fact i am not satisfied, because i
need  the line x=y=z to show only certain points of it with and & function,
for exemple i need to see point of space where x=y=z and x is even and x
different of x * 10 ;o)
> Well, the cylinder that I described is:
> cylinder {
> <-100,-100,-100>, // starting point
> <100,100,100>, // ending point
> 0.1 // radius
> pigment {rgb 1} // white
> You'll also need a light source and a camera.
> If this is new to you, then I strongly suggest you read the tutorials that
> come with POV-Ray. Start by clicking on the button in POV-Ray that says
> "Scene", which will bring you to the help files.
>  - Slime
>  [ http://www.slimeland.com/ ]
Subject: Re: function x=y=z
Date: 16 Jun 2004 06:34:30
Message: <40d02236@news.povray.org>
  A point is infinitely small (and a line is infinitely thin as well)
so what you are asking is impossible.
  You can, however, *approximate* what you want by using eg. spheres or
cylinders.
  What you probably want is to create a loop where you create spheres
along the line in the places you want.
  The POV-Ray documentation has some tutorials on making loops and other
things. You should check it.
Date: 17 Jun 2004 14:00:43
Message: <40d1dc4b$1@news.povray.org>
"1ternaut" <ded### [at] sparkwirecom> wrote in message
news:40cff5c9@news.povray.org...
Look in povray.text.scene-files for an example scene with documentation
references
 -Shay
Date: 17 Jun 2004 18:10:50
Message: <40d216ea@news.povray.org>
Thank you all of you ;o) I have a pist ;o)
news:40d1dc4b$1@news.povray.org...
> references
>  -Shay
