POV-Ray : Newsgroups : povray.pov4.discussion.general : Real-micro-poly-displacement based on patterns and pictures Server Time
17 Dec 2025 22:41:55 EST (-0500)
  Real-micro-poly-displacement based on patterns and pictures (Message 1 to 10 of 10)
Subject: Real-micro-poly-displacement based on patterns and pictures
Date: 17 Nov 2009 22:30:00
Message: <web.4b03699294dd874dda6353d60@news.povray.org>
When like to have displacement instead of bump-mapping, you need to use
iso-surfaces.
Having real-micro-poly-displacement like having a normal{}, or a finish{} for
every object would be cool.
BTW.: The PixarRenderman uses real-micro-poly-displacement to generate
motion blur instead of multisampling of objects like MegaPov does. Its extreme
fast and the quality is *much* better. First and foremost, if you compare the
render times of these options, having the same quality.
Holger
Subject: Re: Real-micro-poly-displacement based on patterns and pictures
Date: 17 Nov 2009 22:44:30
Message: <4b036d9e$1@news.povray.org>
> for every object would be cool.
That's not possible. "poly-displacement" only works if you have polygons to
begin with. POV-Ray doesn't use polygons for most of its objects.
Date: 17 Nov 2009 23:40:01
Message: <web.4b0379a1886514d6da6353d60@news.povray.org>
I know, that the PixarRenderman can real displace also objects, that are
defined, using the RIB-Language, such as spheres or boxes.
A micropolygon is that part of an surface, that appears in the very pixel of the
image. (Every pixel builds a polygon) I don't know, if its based on normal
polygons. In the Renderman, you can displace *everything* except media. And a
lot of object are definitely _not_ polygon-based, like NURBS or patches. The
surface appears of other formulas (see posting before) +the
displacement-algorithm.
Maybe, its just the name of 'micropolygon' the may confuse.
Holger
Date: 18 Nov 2009 11:49:27
Message: <4b042597@news.povray.org>
  You are free to offer an implementation of this.
Date: 18 Nov 2009 13:20:01
Message: <web.4b043a10886514d6da6353d60@news.povray.org>
> - Warp
Until now, I'm not able to compile PovRay without an error message ;)
OK, one time it works. My C skill is on the level, making shader in PovMan...
Date: 18 Nov 2009 21:34:42
Message: <4b04aec2$1@news.povray.org>
C++ skills would be closer to the mark ;-)
Date: 18 Nov 2009 23:40:01
Message: <web.4b04cb76886514d6da6353d60@news.povray.org>
Well then it seams, that I'm ++ behind ;)
Date: 21 Nov 2009 11:45:11
Message: <4b081917$1@news.povray.org>
Actually, everything in Renderman is a polygon.  Even if you use curve
based objects like spheres, they first get tessellated as polygons
before being rendered.
I believe Pixar uses a dynamic tessellation which yields polygons
roughly half the size of individual pixels, so the end quality is still
quite good, but that doesn't change the fact that the way POV-Ray works
is very, very different.
...Chambers
Date: 25 Nov 2009 01:06:28
Message: <4b0cc964@news.povray.org>
Yes, REYES is basically scanline.  It wasn't until quite a few years ago
  that Renderman integrated raytracing into its pipeline.
Date: 25 Nov 2009 01:07:51
Message: <4b0cc9b7$1@news.povray.org>
>> PovMan...
Advanced math/geometry skills more likely.
