POV-Ray : Newsgroups : povray.pov4.discussion.general : Scale Postfixes Server Time
3 Jul 2025 03:12:03 EDT (-0400)
  Scale Postfixes (Message 11 to 15 of 15)
Subject: Re: Scale Postfixes
Date: 5 Aug 2009 10:15:01
Message: <4a7993e5@news.povray.org>
Chambers schrieb:
> clipka wrote:
>> They're perfectly counter-intuitive for use in "rotate" though:
> True, they're meant for conversion rather than designation.
... which makes my point, because I'd love to have some means of
designation ;-)
Date: 5 Aug 2009 10:27:22
Message: <4a7996ca$1@news.povray.org>
Chambers wrote:
> David H. Burns wrote:
>> "Rad" and "deg" for angles and rotation *would* be useful.
> They're already implemented.
> // Declares the variable rad to be 45 degrees converted into radians.
> #declare rad = radians(45);
> // Declares the variable deg to be 0.3 radians converted into degrees.
> #declare deg = degrees(0.3);
I had forgotten that.
Date: 5 Aug 2009 10:30:36
Message: <4a79978c$1@news.povray.org>
>    // trying to express that I intend to rotate by 45 degrees,
>    // with the effect of rotating by 45 radians instead
>    rotate x * degrees(45)
>    // trying to express that I intend to rotate by 0.3 radians,
>    // with the effect of rotating by something particularly useless
>    rotate y * radians(0.3)
True too. "Built in" unit definitions would be useful, maybe with a
default that could
be set as in calculators?
Date: 6 Aug 2009 12:49:11
Message: <4a7b0986@news.povray.org>
#declare deg = 1;
#declare rad = radians(1);
rotate x * 45*deg
rotate y * 0.3*rad
Date: 6 Aug 2009 13:14:15
Message: <4a7b0f67$1@news.povray.org>
> #declare deg = 1;
> rotate x * 45*deg
> rotate y * 0.3*rad
#declare Foo = sin(45*deg);
#declare Bar = cos(0.3*rad);
FAIL.
Which is to say: POV-Ray's current system for representing angles is
inconsistent, and a genuine built-in mechanism for specifying values as
either degree or radians would be helpful to mend this.
Note that this isn't about "how powerful is the language", but "how easy
is it to learn and use". Otherwise, we could simply refer to the
Turing-completeness of the language and be done with it.
