Subject: Re: POV-Ray 4 SDL: Some concrete proposal
Date: 14 Apr 2009 08:19:02
Message: <49e47f36@news.povray.org>
Am Mon, 13 Apr 2009 18:55:22 -0400 schrieb clipka:
> I think however that the function-based approach is better, because it
> would define transformations as basically property-less. So nobody tries
> to do things like:
> sphere {
> rotate { axis: <1,0,0>; angle: 30 deg; } as myRotate; translate {
> vector: <1,2,3>; };
> myRotate.angle = 60 deg;
> Otherwise, POV-Ray would need to keep track of a stack of
> transformations applied to the object (and similarly all the texture
> patterns and such as well), just in case someone would want to modify
> one of the steps later.
Well, I think the point here is: Do we store references in variables or
actual copies of the data? If we store references, then yes, POV-Ray
would need to keep track of them in its internal state. If we don't then
"myRotate.angle = 60 deg" would do nothing until we use myRotate in an
object modification block. Thats the same problem as cloning vs.
modifying objects in the scene.
> This is definitely something we would want - but isn't lazy evaluation
> the domain of functions?
> Maybe we could get a consensus by allowing for named parameters in
> functions.
Yeah, I thought of blurring the distinction between functions and
prototypes. Sometimes named parametres are useful, sometimes they are not
needed. We could allow both, we just need a syntax for it.
Let's sum up the classic differences between a function and an object:
A function has the type of its return value as soon as parametres are
bound to it. As long as no parameters are bound to it it has a type
determined by the number (and type) of its arguments. An object always
has the type it was given when it was created.
A function has parameters which are distinguished by their order. An
object has members or properties with names.
If we add input properties which delay calculation of other properties to
our language then functions and prototypes can perform the same task with
a different syntax. I'm not to happy with that, _one_ way to do things
should be enough.
> There should be, however, *some* distinction between the two in syntax
> (not only in defining them, but also in using them), so it is clear to
> the user that it makes no sense to try to manipulate the parameters of
> the function.
>> I chose = instead
>> of : because of consistency
>> and *= means composition of two
>> transformation and writing the result back to the lhs. Simply putting a
>> transformation inside a modification block does not work for me (it
>> works in POV 3 because it does not use object properties). There should
>> be something to signify that you are _applying_ this transformation.
> In the language concept I have in mind, it would simply be (taking the
> freedom to make this a function again, albeit with named parameters):
> sphere
> radius = 20;
> center = <100, 0, 0>;
> rotate_around_axis
> axis = <.5, .5, .5>;
> amount = 30;
> because, as already mentioned in the original post, expressions by
> themselves (whether they be from prototype-cloning or function-calling)
> are always *applied*. Note that a sphere would "know what to do" with a
> transformation being applied to it. Most importantly, it would know that
> it would have to update its children accordingly, too. Which a simple
> tampering with the spere's *own* transformation matrix wouldn't do.
> (Granted, we'd probably want a way to allow for getter/setter methods
> anyway...)
Hm, now I'm getting a understanding of what you are aiming for. Then an
operator meaning "apply" would also be nice, wouldn't it?
perhaps
MyTransformedSphere = MySphere ~ MyTransform;
> Duh. I've just started laying out the basics of the language, and people
> already start exploiting its details :P
Exploitation of details makes a programming language powerful ;)
Unfortunately that means paying attention to details when designing a
language is very important.
> Note however that this might be slower on a non-optimizing interpreter:
> It would have to copy the object first, then discard the original one.
It should be trivial to recognize a pattern like
<something> = <somthing>
/*something*/
> It would also make a difference in case of:
> MySphere = sphere {...};
> MySphereAlias = MySphere; // no prototype instantiation here, just an
> alias! modify MySphere {...};
> (Then again, disallowing "modify" would prevent any misconception about
> how this case would work out.)
Again, reference vs copy.
> So how would you express such an "on-the-fly assignment" then?
I don't. If I want to I assign first and then reuse the assigned variable.
> The thing is, I don't like those interpunctuation prefixes: When you
> start lots of statements with these, it messes up the indentation,
> optically speaking.
I'm not sure what you mean with "messing up the indentation", but people
are used to such prefixes. Just think of directory structures:
. is the current working directory
.. is the parent directory
/ is the top level directory
and so on.
> I'd prefer to avoid this "scene +=" - I think it's unnecessary bulk.
> Similarly with the "texture = texture" above.
I see what you mean. So objects apply themselves to the global object
which is the scene itself?
> You mean the "for" loop? I find nothing wrong with it. The remainder of
> the syntax, that's what you came up with yourself :P
I mean for ... end. I always find using words to open and close blocks
hard to read.
> Hm, yeah - you're making the point why I originally added the "modify"
> statement in the first place, but I forgot about it :}
>> If we don't, we can't change objects that are already in the scene!
>> Note that the "modify" keyword is no solution to that problem.*/
> Why isn't it? If the POV-Ray internals can cope with an object being
> modified, then this shouldn't be an issue.
Then "as" creates a reference, "modify" modifies the target of a
reference, "=" creates a copy, and what does "modify" do if the variable
it should modify is not a reference...
> Yeah, basically. I'm quite sure about the underlying idea. I'm still
> struggling with the details, like how to get a syntax that is both
> perfectly consistent *and* looks good. Mostly the "center:..." vs.
> alternatives like "center=...", ".center=..." or some such doesn't yet
> satisfy me.
> That, and your and Warp's objection against the "as" statement. I
> actually like it, but your complaint regarding inconsistency has some
> justification, too.
I just want to prevent SDL 4 becoming cluttered with keywords like "as"
and "modify" when there is a way to express the same thing in a concise
manner without them. This may seem pedantic but SDL 3 is such a mess with
keywords. When I started writing #macros I just wanted to call a variable
"x"... guess what happened ;)
> > to do things like:
> > sphere {
> > vector: <1,2,3>; };
You'd want a transformation for each container, which doesn't prevent references
being used. Those that seem to be a list of transformations interleaved with
effects would be processed into a nested structure, each having the
transformations and effects before the container is closed.
I think we can use the usual (simple) language constructs to create references,
and new declarations for copies.
Generally, we could go for partial OO implementation for the scene objects,
which means that we don't carry per-instance methods, but instead just have the
instances (with a single pointer) locate the methods for the class, along with
the enumerated properties. The parser would be version-matched to the engine,
which removes any opaque enumeration from the SDL source scripts.
I think we'll want to store references: Animation scripting might greatly
benefit of that I guess. Instead of individually describing individual frames,
an animation script could set up all its objects and then just push them around
the scene as the animation progresses.
> > functions.
How about:
MyFunction = function(positional x, y; named a, b, c) { ... }
// shorthand: function(x, y; named a, b, c) { ... }
Foo = MyFunction(2,3; b:42; a:11);
So far I can follow you... I think. Note however that with a dynamically typed
language, even when parameters are bound to it, it has "the type of its return
value" no earlier than it is actually executed and the actual return value
determined.
> An object always
I'd say that the parameter naming / ordering thing is rather independent of
objects vs. functions: It's just a common convention of most programming
languages that function parameters are passed by position instead of by name.
> should be enough.
I agree with that. But I guess the concept of individual properties delaying the
calculation of a whole entity would be hard to grasp for the average user, or
even for the average programmer (it is for me, at any rate ;)).
> perhaps
Hm... there is something to this indeed.
However, some things need to be clarified:
Using bare expressions within a curly brace doesn't strictly create a copy, but
modifies the copy of the prototype. Would the tilde operator force creation of
a new copy?
In that case, it would be equivalent to:
MyTransformedSphere = MySphere { MyTransform };
which is just about as easy to type. It would also then raise the question
whether the following would be possible, too:
MyColoredSphere = MySphere ~ color: #<1,0,0>;
In that sense, the tilde operator would actually be the single-statement
equivalent for curly braces (which would happen to nicely fit with the shapes
of the symbols :))
So are you saying that the concept I've presented is powerful? Thanks ;)
Yup. Sure thing.
Hm... occasionally I do statements like:
FooBar( This + Is(A * rand() - 0.4) / Stupid + Example );
only to find that I want to base something else on that very same random number
- or some other sub-statement, for that matter. So sometimes I'd like to be
able to write:
FooBar( This + Is(A * rand() as MyRand - 0.4) / Stupid + Example );
Fnord = <1,2,3> * MyRand;
This is partially a thing of "how can that rand() dare to require me to give it
a line of its own?!", partially "duh, now I have to cut and paste that
sub-expression to its own line" laziness, and partially avoiding to type one
instance of the variable name, as in:
MyRand = rand();
FooBar( This + Is(A * MyRand - 0.4) / Stupid + Example );
Of course there are cases where using a full-fledged assignment statement is
much cleaner. But sometimes, to me a value has the quality of no more than a
"spin-off" of some other computation. So I'd love to have a statement saying
"oh, by the way, just remember this one for later".
Or, think of debugging a large formula. With this "on-the-fly assignment", it is
a piece of cake; no need stripping it down to individual terms (and risking to
break it again as soon as you re-assemble it because you don't want 20 lines of
assignments where a two-liner would do).
> > optically speaking.
Think of this syntax I had pondered:
sphere {
.center = <0,0,0>;
.radius = 1;
temp = rand();
test = temp + 1;
.answer = 42;
.foo = bar;
I think this syntax would make it perfectly plain to most developers accustomed
to the "foo.bar" field/member notation that .center is a property of the
sphere, while for instance temp is not, and texture is defined in some other
scope as well.
Alas, it really "uglifies" the indentation!
> but people
No problem with the prefixes, but I want the code to have a certain "beauty" as
well - because with code, somehow beauty is almost always related to
readability (unless of course you're going for the "exotic" beauty of some
artificial languages like whitespace, c00l or such :P).
Yep. Well, *anything* that is a standalone expression theoretically does. But
only for some types of values the concept of "applying it to the scene" makes
sense.
> hard to read.
That's where indentation was invented for. (There are even languages that
actually use indentation levels to open and close blocks.)
And in a language such as this, I think there should be a clear distinction
between the "modification blocks" - which open up a new context for "applying"
things to - and control blocks.
No - it's not "=" that creates a copy: This is just an alternative way of
creating a reference.
The thing that causes creation of a copy is the curly-braces modifier block,
unless explicitly used with "modify":
MySphere = sphere;
actually creates a reference to the very basic "prototype of prototypes" sphere.
And why not? There's no reason to create a copy if you're not applying any
modifications to it anyway.
To create a copy of that prototype, one would have to write:
MySphere = sphere {};
Note that this concept also allows creating an anonymous modified object "on the
fly", as in:
(MyIntersect,MyNormal) = trace( MySphere { translate <2,3,4> } );
Yeah, that's a hassle indeed.
One simple way out of this, however, is to develop a habit of always starting
your variable names with uppercase letters. (I must confess I don't have such a
habit myself ;))
Also note that the whole smash like "blob", "sphere", "triangle", "sqr" (yeah!
my personal friend in POV 3.x!) would be made available at least for local
variables if desired.
If variable names should really be deemed an issue, how about carrying over
POV-Ray 3.x convention for control keywords to start with "#"?
So we'd have:
#for i = 1 #to 21 #step 2 #do
though I wouldn't consider this pretty. Or using all uppercase, which seems to
be more seldom used for variable names (possibly because it requires one more
key to be pressed):
FOR i = 1 TO 21 STEP 2 DO
sphere { center = <i,0,0>; radius = 1; }
END
Looks a bit antiquated, but that doesn't necessarily make it a bad idea.
I'd even go as far as to move the whole scene object handling into a separate
layer, with the SDL code only checking whether the object is *any* type of
scene object, and then deferring the handling to that "scene object wrapper"
layer.
That one could in turn be comprised of nothing more than a dynamic table with
objects and their respective actual types (with the core SDL implementation
handling only indices into that table; could be pointers though of course), and
a hard-coded lookup table for each type, mapping keywords to
pointers-to-members. Plus some wrap/unwrap code for some data types, if needs
be.
Thus, a statement like
MySphere.translate(<2,3,4>)
would be resolved to (roughly):
value = LookupName("MySphere");
if (value->type == SCENE_OBJECT)
SceneObjectLayer->Invoke(value->handle, "translate", Vector3d(2,3,4));
while SceneObjectLayer::Invoke(handle, name, param) would be implemented as
something like:
obj = (SceneObject*)handle;
objClass = obj->class();
member = LookupMember(objClass, name);
obj->member(Unwrap(param));
which would ultimately resolve to - in this case - a call to
Sphere::Translate(Vector3d v).
Date: 16 Apr 2009 06:08:32
Message: <49e703a0@news.povray.org>
Am Tue, 14 Apr 2009 10:35:11 -0400 schrieb clipka:
> greatly benefit of that I guess. Instead of individually describing
> individual frames, an animation script could set up all its objects and
> then just push them around the scene as the animation progresses.
Right. Then frames are just modification blocks of the scene object.
> How about:
> MyFunction = function(positional x, y; named a, b, c) { ... } //
Or even:
MySphereProducingFunction = function(named pos)
{ sphere { midpoint = pos; /*...*/ } };
Any object applied to a function block would be its return value.
> typed language, even when parameters are bound to it, it has "the type
> of its return value" no earlier than it is actually executed and the
> actual return value determined.
Yes, from the syntactical point of view "func(/*...*/)" and "func" have
different types in most languages. I don't like this, because what type
has func(some_parameter /*but not the other*/) then? In most languages
you have to specify all arguments or none... Seems to be a personal
dislike, though ;)
> of objects vs. functions: It's just a common convention of most
> programming languages that function parameters are passed by position
> instead of by name.
Right. Perl has named parameters but how they work seems rather obscure
to me. Just what you'd expect from Perl ;)
>> to our language then functions and prototypes can perform the same task
>> with a different syntax. I'm not to happy with that, _one_ way to do
>> things should be enough.
> delaying the calculation of a whole entity would be hard to grasp for
> the average user, or even for the average programmer (it is for me, at
> any rate ;)).
It's just the other way round: The program doesn't follow a sequence of
instructions but has a number of goals it has to achieve. Each time a
resource needed to achieve the current goal is missing, the program goes
to the next. Hopefully the resource will become available later, perhaps
as the result of another calculation.
>> perhaps
> copy, but modifies the copy of the prototype. Would the tilde operator
> force creation of a new copy?
> question whether the following would be possible, too:
> shapes of the symbols :))
Supplying your own rules for applying a object to some other object would
just be an act of overloading the ~ operator. Something like
PaintInHappyColors = basic {}; //clone the most fundamental prototype
operator(object ~ PaintInHappyColors)
pigment { color = <rand(), rand(), rand()>; };
>> variable.
> number - or some other sub-statement, for that matter. So sometimes I'd
> like to be able to write:
> give it a line of its own?!", partially "duh, now I have to cut and
> paste that sub-expression to its own line" laziness, and partially
> avoiding to type one instance of the variable name, as in:
> MyRand = rand();
> FooBar( This + Is(A * MyRand - 0.4) / Stupid + Example ); Fnord =
> <1,2,3> * MyRand;
> statement is much cleaner. But sometimes, to me a value has the quality
> of no more than a "spin-off" of some other computation. So I'd love to
> have a statement saying "oh, by the way, just remember this one for
> later".
> assignment", it is a piece of cake; no need stripping it down to
> individual terms (and risking to break it again as soon as you
> re-assemble it because you don't want 20 lines of assignments where a
The C way to do that:
while((error_code = function_returning_error_code()) == 0)
/*do something*/
Easy, because = returns the assigned variable. That does definitely
confuse a non-programmer who doesn't know the difference between = and ==.
So your example would become
FooBar( This + Is(A * (MyRand = rand()) - 0.4) / Stupid + Example );
> sphere {
> .center = <0,0,0>;
> .radius = 1;
> temp = rand();
> texture {
> test = temp + 1;
> .answer = 42;
> .foo = bar;
> accustomed to the "foo.bar" field/member notation that .center is a
> property of the sphere, while for instance temp is not, and texture is
> defined in some other scope as well.
Would it? I never write "this->member" in C++, just member. Some people
prefix their members with "m_", I don't. It's a matter of personal
taste...
Every reference to a variable outside the current scope necessarily does
this, if I understand you correctly.
> "beauty" as well - because with code, somehow beauty is almost always
> related to readability (unless of course you're going for the "exotic"
> beauty of some artificial languages like whitespace, c00l or such :P).
>> hard to read.
> that actually use indentation levels to open and close blocks.)
> distinction between the "modification blocks" - which open up a new
> context for "applying" things to - and control blocks.
Another matter of taste, I suppose. It's just that when I want my code to
be verbose, then _I_ want to introduce the verbosity, not the designer of
the programming language I happen to code in.
>> variable it should modify is not a reference...
> of creating a reference.
> block, unless explicitly used with "modify":
> MySphere = sphere;
> sphere.
> any modifications to it anyway.
Sounds good :)
>> with keywords. When I started writing #macros I just wanted to call a
>> variable "x"... guess what happened ;)
> starting your variable names with uppercase letters. (I must confess I
> don't have such a habit myself ;))
> (yeah! my personal friend in POV 3.x!) would be made available at least
> for local variables if desired.
As all objects will be prototypes I don't think any special treatment
will be required. These prototypes could even come from special internal
includes. Most of the time I won't need a poly and if I want to create
one I just write
include "internal:poly"
poly
{ /*blahblah*/
Of course cameras and basic modifiers should be included by default.
Namespaceing on the other hand is just too much typing for a lazy person
like me :P
> over POV-Ray 3.x convention for control keywords to start with "#"?
> So we'd have:
> #end
> seems to be more seldom used for variable names (possibly because it
> requires one more key to be pressed):
> END
There should really be opinion polls among POV-Ray users to decide on
prettyness ;)
> Or even:
Yes, that makes a lot of sense.
> dislike, though ;)
I think functions should be just functions, and some rule would have to be
established how to handle missing or surplus parameters. Easiest would be to
discard surplus ones, and have missing ones set to "undefined".
> > instead of by name.
I'd expect some specific prefix symbol reserved for them :P
> > any rate ;)).
Either way it messes with the imperative paradigm most mainstream languages
still follow today - if not on large scale, then at "molecular" level (e.g.
individual functions/methods/whathaveyou): "Do this; next do that; next do foo;
next do bar; ..."
Unless of course it's done in a totally transparent way. But then again I'd not
consider that a language trait, but some particular implementation's way of
optimizing things.
I'm not sure how that answers my question. I think we're getting a bit fuzzy
here.
Please not! Because, as you say yourself:
It would also raise a conceptual problem, becuase then
MySphere = sphere { ... };
would not only be an assignment, but *also* an expression - which would evaluate
to a sphere instead. If we want "bare" expressions to be read as "attach this to
the current object", the logical consequence would be that this assignment would
*also* attach the sphere to the scene.
I don't think that is what we want.
So we do need different syntax for assigment statements and "on-the-fly
assignments".
> > sphere {
> > .center = <0,0,0>;
> > .radius = 1;
> > temp = rand();
> > texture {
> > test = temp + 1;
> > .answer = 42;
> > .foo = bar;
> taste...
I don't think you got my point.
My basic point was: Syntax should not only be concise and consistent, but also
pretty as well.
My example was the above, which was indeed a syntax I pondered a while to
distinguish members from variables, by simply prepending a dot before member
names, to allude to the "myInstance.myMember" notation common in mainstream OO
languages - making the empty name shorthand for "this", so to speak.
My argument was that in this particular syntax, the many leading dots on a line
would tend to visually "distort" the indentation, and that this would make the
code ugly.
So with an example for an ugly syntax, my conclusion was that I want the new
POV-SDL syntax to be pretty, and my appeal was to take beauty into
consideration besides conciseness, consistency and other traits.
How would you do that as a user in a language that - as an extreme example -
would go
@ i [1,10] {
? i < 5 {
<<i
<<"many"
instead of
for i in 1 to 10 do
if i < 5 then
print i
else
print "many"
end
end
Fact is that every language carries its own inherent level of verbosity, which
you as a user typically cannot really influence much.
> like me :P
Agree; something like
pov:sphere { ... }
wouldn't really go well.
But how about
include "sphere" as pov;
include "box";
in case you *do* want a namespace - which could give you
pov.sphere { ... }
or straigtforward
box { ... }
"al gusto".
> prettyness ;)
Maybe. But I think everything is an improvement over the current "#while...#end"
anyway :P
Date: 16 Apr 2009 10:03:22
Message: <49e73aaa@news.povray.org>
Am Thu, 16 Apr 2009 08:31:31 -0400 schrieb clipka:
> be established how to handle missing or surplus parameters. Easiest
> would be to discard surplus ones, and have missing ones set to
> "undefined".
Please don't do that, hunting down bugs caused by uninitialized or
undefined values can be tedious. In my opinion just signaling an error is
better.
In my own perfect little language, functions with incomplete argument
list would return functions that take the missing parameters. Return
values would be written to properties of the function.
No, in fact I think it's an extra hash as a parameter.
>> >> properties to our language then functions and prototypes can perform
>> >> the same task with a different syntax. I'm not to happy with that,
>> >> _one_ way to do things should be enough.
>> > at any rate ;)).
>> goes to the next. Hopefully the resource will become available later,
>> perhaps as the result of another calculation.
> languages still follow today - if not on large scale, then at
> "molecular" level (e.g. individual functions/methods/whathaveyou): "Do
> this; next do that; next do foo; next do bar; ..."
As long as you disallow side-effects like output or time dependent
values, not at all. Then it's just "Do this; oh, you can't do that, you
have to do that first; to do that, you have to do foo; now you can do
this; next do bar; ..." Of course if you do allow output as side effects
then it would be all messed up.
> I'd not consider that a language trait, but some particular
> implementation's way of optimizing things.
Actually, I'm tired of implementing lazy evaluation in strictly evaluated
frameworks...
>> > operator force creation of a new copy?
Sorry I didn't answer that. If I think about it, no, but I'm not sure...
> fuzzy here.
> evaluate to a sphere instead. If we want "bare" expressions to be read
> as "attach this to the current object", the logical consequence would be
> that this assignment would *also* attach the sphere to the scene.
Haven't thought about that, you're right. Then, perhaps we do want "as"
after all. But it still seems to me like a duplicate of "=" where the lhs
and rhs are swapped ;)
> assignments".
>> does this, if I understand you correctly.
> but also pretty as well.
> to distinguish members from variables, by simply prepending a dot before
> member names, to allude to the "myInstance.myMember" notation common in
> mainstream OO languages - making the empty name shorthand for "this", so
> to speak.
> a line would tend to visually "distort" the indentation, and that this
> would make the code ugly.
> new POV-SDL syntax to be pretty, and my appeal was to take beauty into
I see the dots as reminders, that a variable resides in the current
scope, and think it's good that they stand out a bit. Maybe we'll want
properties and other variables to be clearly distinguished by such
prefixes, then again I think the approach "everything is a property" is
very elegant.
I still believe that if no prefix is specified, the variable/property to
be accessed should be the most local one that's defined.
>> to be verbose, then _I_ want to introduce the verbosity, not the
>> designer of the programming language I happen to code in.
> example - would go
> @ i [1,10] {
> ? i < 5 {
> <<i
> <<"many"
If this language allows me to define a construction that does the same as
@ or ?, then it's fine. Maybe with
#for([int] list, #func(int)) = {@ i list { func(i) }}
for([1,10], #(i) {
? i < 5 {
<<i
<<"many"
Then the langauge is powerful enough for me to create my own verbosity. I
must admit that nobody would want to do things like that all the time,
but then again this fictional language is an extreme example.
>> person like me :P
> But how about
> include "box";
> pov.sphere { ... }
> or straigtforward
> box { ... }
> "al gusto".
Just as long nobody forces me to use namespaces, that's fine by me.
>> prettyness ;)
> "#while...#end" anyway :P
right... no wait, that's a reserved word *g*
> very elegant.
Yes, I also think that would make for a clean thing, and in any other language
I'd quickly agree.
There is one thing here, however, that worries me:
In other languages, whenever a "more local" variable enters the scene, it is
clearly visible, because it is either declared, assigned to, or appears in a
formal parameter list.
In our language, a block like
MySphere = sphere {
center = <1,2,3>;
radius = 4.2;
would introduce "more local" variables only *implicitly*, by them being
properties of "sphere".
Now if in a later version of POV, "sphere" would ever happen to get an
additional property named "i" or "temp", it would break a whole lot of scripts,
like:
i = 0;
MySphere = sphere {
center = x*i;
radius = temp;
Granted, these variable names are an extreme example, and nobody in his sane
mind would probably introduce them as new object properties. But the same could
basically happen with *every* name.
> for([1,10], #(i) {
> ? i < 5 {
> <<i
> <<"many"
I think you're quite an exception regarding this practice. Let alone that I
think it is bad style, because it makes the code hard to read for other users
of the language, who are accustomed to the standard syntax.
(In the trade I work in, for instance, such things as "rolling your own
language" would typically be a complete no-go.)
> like:
> i = 0;
> MySphere = sphere {
> center = x*i;
> radius = temp;
You'd probably want new object properties to be write-only, so that names to the
right of assignments in the "sphere { }" block can then refer to the outer scope
(which makes the above code work as expected).
I'm not sure if any languages or parsers do this by default, but if your need is
great enough, then of course it could be programmed :o)
> > i = 0;
> > MySphere = sphere {
> > center = x*i;
> > radius = temp;
Then what if I want to do
modify MySphere {
center = x*i;
temp = temp*2;
Aside from that, consistency would suffer from using different name resolution
rules for lvalues (i.e. the left side of an assignment) and rvalues (i.e. the
right side).
