POV-Ray : Newsgroups : povray.pov4.discussion.general : Request for *.df4 format (ASCII text based) Server Time
16 May 2024 14:56:27 EDT (-0400)
  Request for *.df4 format (ASCII text based) (Message 11 to 20 of 34)
Subject: Re: Request for *.df4 format (ASCII text based)
Date: 26 Feb 2008 18:31:05
Message: <47c4a139@news.povray.org>
Tor Olav Kristensen <tor### [at] toberemovedgmailcom> wrote:
> But some might want to use POV-Ray SDL to write them...
  Then it would be better to enhance the SDL (or better yet, redesign it
from scratch) so that you can create DF3's with it, rather than change
the DF3 so that you can create them with the current SDL...
  The latter only helps creating DF3 files. The former helps creating
tons of other files too.
Date: 26 Feb 2008 19:36:32
Message: <47c4b090@news.povray.org>
Yes, I agree.
Tor Olav
http://subcube.com
Date: 27 Feb 2008 15:16:13
Message: <Xns9A51D85816D16seed7@news.povray.org>
in news:web.47b586279e245a8f94e61a50@news.povray.org Woody wrote:
> Would it be possible to include a *.df4 format where instead of
> dimension and voxel data being in byte code, it was in some type of
> standard *.txt format? Possibly ASCII?
Have a look at the PGM file format
http://netpbm.sourceforge.net/doc/pgm.html it supports multiple layers. I
don't know how much of the spec is supported by POV-Ray, I doubt it deals
with multiple images.
Ingo
Date: 4 Mar 2008 11:25:00
Message: <web.47cd7729f13a83cf29aed21e0@news.povray.org>
Yes. Sometimes ago I needed to write df3 files from SDL, but that's impossible.
On the other side, Povray read only df files in binary format. I think that one
would want to create df3 files in his macros...
Date: 4 Mar 2008 12:51:33
Message: <47cd8c25$1@news.povray.org>
Yep, so let's add binary-file-writing capabilities to POV SDL, like Warp
said. Not make an ASCII-based df3.
Date: 8 Dec 2008 08:20:00
Message: <web.493d1e87f13a83cf3182ed980@news.povray.org>
that sounds like a fine idea. my main objection with the binary versuses the
ascii formats was that all the tutirials on the df3 binary format made things
alot more complicated with stuff like big indian and little indian. but im
assuming that if the ability to write binaries would make this trival, at the
very least there would be documentation as it applies to pov as opposed to
general computing
Date: 26 Aug 2010 17:45:01
Message: <web.4c76df5af13a83cfa3b8d9490@news.povray.org>
Hi list,
I'm trying to use a density file in povray for the first time and the page is
always blank.
I use an external program to generate a file data.dat which looks like this,
10 10 10
0 0 0 240
1 0 0 240
2 0 0 240
3 0 0 240
4 0 0 240
5 0 0 240
6 0 0 240
7 0 0 240
8 0 0 240
etc ...
where the first line gives the dimensions, the first three columns are xyz
coordinates and last column the density value.
I use the c++ code posted here to create a df3 file. OK so far, I think.
Unfortunately, my basic example shows a blank page with nothing in it. I don't
know if the df3 file is incorrect or if it's a problem with the povray file
below,
background { color rgb <1.0,1.0,1.0> }
global_settings {
ambient_light <0.3,0.3,0.3>
#include "textures.inc"
light_source{<10,10,-10> color White}
#declare dist = 1.5;
camera {location <dist , dist ,dist>
right <0, 4/3, 0>
 up    <0,0,1>
 look_at  <0.0 , 0.0 , 0.0>}
#declare theinterior = interior {
   media {
      density {
         density_file df3 "data.df3"
         interpolate 1
         color_map {
            [0.00 rgb <0,0,0>]
            [0.2 rgb <0,0,1>]
            [0.4 rgb <0,1,0>]
            [1.00 rgb <1,0,0>]
box {
   <0,0,0>, <1,1,1>
   pigment { rgbf 1 }
   interior { theinterior }
   hollow
I'll appreciate any advice.
baptiste
> Woody <nomail@nomail> wrote:
> > If you every have a few moments do you think you could modify the source code
> > you posted at http://news.povray.org/4799ff49%40news.povray.org, so that it can
> > take one or more *.txt files specified in the command line (instead of the
> > testdata.txt) and output them into df3 format with the same name (except for
> > the txt extension).
>   You mean with the same input file format?
>   How about this:
> #include <iostream>
> #include <fstream>
> #include <vector>
> #include <string>
> #include <cstdio>
> int main(int argc, char* argv[])
>     // Limit the size of the df3 dimensions (safeguard against invalid input).
>     // Maximum df3 size will be SIZE_LIMIT*SIZE_LIMIT*SIZE_LIMIT.
>     const size_t SIZE_LIMIT = 256;
>     if(argc < 2)
>         std::cout << "Usage: " << argv[0] << " <files>\n";
>         return 0;
>     for(int i = 1; i < argc; ++i) // for each input file
>         std::ifstream is(argv[i]);
>         if(!is.good())
>             std::cerr << "Couldn't open ";
>             std::perror(argv[i]);
>             continue;
>         size_t xSize, ySize, zSize;
>         is >> xSize >> ySize >> zSize;
>         if(xSize > SIZE_LIMIT || ySize > SIZE_LIMIT || zSize > SIZE_LIMIT)
>             std::cout << "Skipping " << argv[i] << " (invalid input)\n";
>             continue;
>         std::vector<char> data(xSize*ySize*zSize + 6, 0);
>         // Setup df3 header:
>         data[0] = xSize/256; data[1] = xSize%256;
>         data[2] = ySize/256; data[3] = ySize%256;
>         data[4] = zSize/256; data[5] = zSize%256;
>         // Read input data and create df3 data:
>         while(true)
>             size_t x, y, z, value;
>             is >> x >> y >> z >> value;
>             if(!is.good()) break;
>             const size_t ind = x + y*xSize + z*xSize*ySize + 6;
>             if(ind < data.size())
>                 data[ind] = char(value);
>         // Write df3 file:
>         std::string filename = argv[i];
>         size_t ind = filename.find_last_of('.');
>         if(ind != filename.npos) filename.resize(ind);
>         filename += ".df3";
>         std::ofstream os(filename.c_str(), std::ios::binary);
>         os.write(&data[0], data.size());
>         std::cout << argv[i] << " -> " << filename << std::endl;
Date: 26 Aug 2010 18:38:24
Message: <4c76ece0$1@news.povray.org>
Am 26.08.2010 23:40, schrieb bapt:
>     media {
>        density {
>           interpolate 1
>           color_map {
>              [0.00 rgb<0,0,0>]
>              [0.2 rgb<0,0,1>]
>              [0.4 rgb<0,1,0>]
>              [1.00 rgb<1,0,0>]
You might consider this a case of "POV-Ray fails to help you with a
useful error message": Your media has a density, but no type. Is it
supposed to be absorbing, emitting or scattering?
Date: 27 Aug 2010 01:40:00
Message: <web.4c774f79f13a83cfa3b8d9490@news.povray.org>
> >     media {
> >        density {
> >           interpolate 1
> >           color_map {
> >              [0.00 rgb<0,0,0>]
> >              [0.2 rgb<0,0,1>]
> >              [0.4 rgb<0,1,0>]
> >              [1.00 rgb<1,0,0>]
I see, I added the following but still get a blank page,
   media {
    emission <1,1,1> / 10
     absorption <1,1,1> / 30
     scattering { 1, <0,0,0> }
      density {
         interpolate 1
         color_map {
            [0.00 rgb <0,0,0>]
            [0.2 rgb <0,0,1>]
            [0.4 rgb <0,1,0>]
            [1.00 rgb <1,0,0>]
Thanks for helping,
baptiste
Date: 27 Aug 2010 06:16:21
Message: <4c779075$1@news.povray.org>
Am 27.08.2010 07:39, schrieb bapt:
>     media {
>      emission<1,1,1>  / 10
>       absorption<1,1,1>  / 30
>       scattering { 1,<0,0,0>  }
>        density {
>           interpolate 1
>           color_map {
>              [0.00 rgb<0,0,0>]
>              [0.2 rgb<0,0,1>]
>              [0.4 rgb<0,1,0>]
>              [1.00 rgb<1,0,0>]
- Emission will be invisible, as your background is plain white.
- You can leave out scattering, as with a value of <0,0,0> it does
nothing (the scattering color specifies how much the red, green and blue
components of the light will be affected).
- Your absorption is simply too weak. Try absorption <1,1,1>*30 instead.
Depends on how dense your density map actually is, though. Note that the
smaller the distances in your scene are, the higher your media
parameters have to be for the same effect.
