POV-Ray : Newsgroups : povray.pov4.discussion.general : Tree Fractals Server Time
1 Jun 2024 04:33:20 EDT (-0400)
  Tree Fractals (Message 1 to 10 of 11)
Subject: Tree Fractals
Date: 19 Nov 2009 15:45:44
Message: <op.u3ntabmvb7tbxo@xena>
It would be nice to have a fractal object for trees and lightning.
Tree-like fractal textures would also be nice for veins and leaves.
-Nekar Xenos-
Using Opera's revolutionary e-mail client: http://www.opera.com/mail/
Subject: Re: Tree Fractals
Date: 19 Nov 2009 20:19:33
Message: <4b05eea5$1@news.povray.org>
I guess you're talking about fractals of the recursive kind, as in:
     #declare MyTree {
       cylinder { <0,0,0>, <0,1,0> }
       object { MyTree scale 0.5 rotate  z*30 translate y*1 }
       object { MyTree scale 0.7 rotate -z*20 translate y*1 }
(which of course doesn't work in POV-Ray 3.6 or 3.7)
Unfortunately, such recursive definitions are perfectly unsuited for
raytracing, and would have to be "resolved" prior to rendering anyway
(same goes for textures). I think the best way to go about this is to
make the macro mechanism (or whatever exactly might come to replace it)
more elegant and better suited to define "custom primitives", and leave
definition of such trees to libraries.
Date: 21 Nov 2009 11:47:53
Message: <4b0819b9@news.povray.org>
>     #declare MyTree {
Aren't these termed L-Systems?  The POV-Ray SDL is quite well suited to
writing them (in a slightly different manner from what's posted above,
of course :) ).
Additionally, there's always the POV-Tree utility :)  I don't think
anyone's done lightning yet... hmm, I smell a weekend project coming on...
...Chambers
Date: 21 Nov 2009 12:24:03
Message: <4b082233$1@news.povray.org>
>>     #declare MyTree {
> of course :) ).
The SDL is indeed well-suited to this task - but the POV-Ray rendering
engine isn't; the SDL needs to take care of generating all those "limbs"
and leaves.
Date: 22 Nov 2009 15:32:19
Message: <4b099fd3$1@news.povray.org>
>     #declare MyTree {
Not necessarily, if the bounding scheme is right.
In the case above, tracing tests for the bound around the whole fractal
object; if the ray intersects the bound, then test for the cylinder and
each of the child objects.  Ray tracing recurses well (or else
reflection and refraction would not be something that ray tracing excels
at).
Going into each level, the camera would have to be transformed so that
the sub-objects are scaled, rotated, and transformed correctly.
Additional parameters would be helpful here:
* A bound for the whole fractal, allowing the renderer to move on to
other objects in the scene as soon as possible;
* A recursion_level setting, declaring a maximum depth for recursion;
* A minimum_size setting, telling the renderer the smallest amount of
scaling allowed for any further recursion;
* a leaf_object { }, which allows the user to specify an object that is
used in place of recursion when either the recursion_level or the
minimum_size is reached.
The only real problem I can see with such an object is that while it's
probably very good for making trees and plants of a certain quality,
most of its uses are fairly abstract.  Most of the things that we want
to model aren't fractal in overall shape.
So barring a compelling reason, other than trees, to have fractals in
the renderer, it seems that the usefulness of the feature does not
justify the effort needed to implement it.
John
Date: 3 Dec 2009 14:28:46
Message: <op.u4dm15xtufxv4h@xena>
On Sun, 22 Nov 2009 22:32:02 +0200, John VanSickle
>>      #declare MyTree {
Woo-hoo! =D
> at).
I thought most fractals are recursive. I'm sure Mandelbrot is recursive
(though there might be a non-recursive method that I don't know about)
I like your ideas.
I wouldn't say that's not enough reason not to implement it. Pov artist
have found weird and wonderful uses of some seemingly useless features :)
-Nekar Xenos-
"The spoon is not real"
Date: 3 Dec 2009 22:00:01
Message: <web.4b187b0bc3dd15e7f99d05c80@news.povray.org>
If you don't mind breaking the rule against recursive functions, it isn't too
difficult to make a fractal pattern.  The following scene uses a function
derived from the bifurcation diagram of the logistic map[1] as a pattern.
Although this example only shows it used as a planar pattern, it could also be
mapped to three dimensions in various other ways.  With a little turbulence it
might make a decent lightning.  With some more tweaking, you could likely get a
tree or at least a scrubby bush out of it.
Since I read the POV-Ray docs about how turbulence works[2], I have thought it
should be possible to make a fractal_warp that could be applied to existing
patterns...
Cheers!
[1] http://en.wikipedia.org/wiki/File:LogisticMap_BifurcationDiagram.png
[2] http://www.povray.org/documentation/view/3.6.1/407/#s02_05_12_06_04
// Persistence of Vision Ray Tracer Scene Description File
// File: logistic_map_pattern.pov
// Vers: 3.6, 3.7
// Desc: Logistic Map Pattern Example
// Date: 12/03/09
// Auth: David Wagner
// Cite: http://en.wikipedia.org/wiki/Logistic_map
// Render at 16:9 with +A0.5 +AM2 +R2 -J
// Returns the distance to the nearest logistic value after lm_imin iterations.
#declare lm_i_distance_min = function( lm_r, lm_pop, lm_val, lm_nearestpop,
lm_i, lm_istart, lm_iend ) {
   select(lm_i > lm_iend, 0,
     lm_i_distance_min(
       lm_r,
       lm_r*lm_pop*(1-lm_pop),
       lm_val,
       select(lm_i > lm_istart & ( (abs(lm_pop-lm_val) <
abs(lm_nearestpop-lm_val)) ),0,
         lm_nearestpop,
         lm_pop),
       lm_i+1, lm_istart, lm_iend ),
     abs(lm_val-lm_nearestpop) )//end select
// Calls the recursive iterating function.
#declare lm_fn_distance_min = function( lm_r, lm_val, lm_istart, lm_iend ) {
  lm_i_distance_min(lm_r,0.5, lm_val, 1, 0, lm_istart, lm_iend)
plane {
  y, -1
  texture{
    pigment { function { lm_fn_distance_min(abs(mod(z,4)), abs(mod(x,1)), 20,
100)}
    poly_wave 0.25
      color_map{[0 Yellow][0.2 1.2*Goldenrod][0.2 White][0.5 Black][1 Blue]}
      translate z*1.04
      }//end pigment
  }//end texture
sphere {
  0.0, 1
    function { lm_fn_distance_min(mod(abs(z),4), abs(mod(x,1)), 20, 100)}
    poly_wave 0.25
      color_map {
        [0.00 color rgb <1.0,0.4,0.2> ]
        [0.33 color rgb <0.2,0.4,1.0> ]
        [0.66 color rgb <0.4,1.0,0.2> ]
        [1.00 color rgb <1.0,0.4,0.2> ]
    }//end pigment
    normal{function{-lm_fn_distance_min(mod(abs(z),4), abs(mod(x,1)), 20, 100) }
    poly_wave 2
    finish{
      specular 0.3//0.6
    translate z*3
  }//end texture
  location  <0.0, 0.5-1., -4.0>
  direction 1.5*z
  look_at   <0.0, 0.0-1,  0.0>
sky_sphere {
    gradient y
    color_map {
      [0.0 rgb <0.6,0.7,1.0>]
      [0.7 rgb <0.0,0.1,0.8>]
light_source {
  <0, 0, 0>            // light's position (translated below)
  color rgb <1, 1, 1>  // light's color
  translate <-30, 30, -30>
Download 'logistic_map_pattern.png' (215 KB)
Preview of image 'logistic_map_pattern.png'
Date: 4 Dec 2009 12:00:01
Message: <web.4b193f8dc3dd15e786ff1d480@news.povray.org>
Nice one Waggy, and fast too :)
Date: 4 Dec 2009 12:44:32
Message: <4b194a80@news.povray.org>
  It's perfectly possible to eg. replicate the 'mandel' pattern with a
user-defined function. I have done that in the past.
Date: 8 Dec 2009 00:40:51
Message: <op.u4lt15e6ufxv4h@xena>
Great stuff!
Thanks
-Nekar Xenos-
