POV-Ray : Newsgroups : povray.pov4.discussion.general : On the #version scene language directive. Server Time
16 Nov 2025 06:26:38 EST (-0500)
  On the #version scene language directive. (Message 1 to 2 of 2)
Subject: On the #version scene language directive.
Date: 29 Jan 2024 07:00:26
Message: <65b7935a$1@news.povray.org>
While running down this bug:
https://news.povray.org/povray.beta-test/thread/%3C65b6ba93%241%40news.povray.org%3E/
I ended up reviewing a lot of the version setting code.
For a long time code development was on a path to require #version as
the very first line of a scene. If you coded:
#declare One = 1.0;
#version 3.7;
you'd get warnings or errors saying something like:
"Parse Error: As of POV-Ray v3.7, the '#version' directive must be the
first non-comment statement in the scene file. ..."
After the v3.8 release parser code was backed up to an earlier form of
the parser, this checking coded ended up excluded in, v3.8 beta 2, via
some hard coding in the source (#if 0 .... #endif). Comments were added
about the check was a problem because of the +hi include header feature
for as one issue. Yuqk still issues an error, within the context of the
newer parser.
In the overall code, it looks like to me, the original intent was the
default-version / optional-version override when running of 'povray' was
to be accomplished with 'version=' ini / +mv flag options - which makes
a lot of sense.
The #version directive in the scene description language being needed
only when, locally specific, scene language handling was needed. A
little of this original intent can be seen by running the code above
with a (v3.8 beta 2) executable and looking at the 'input:' line just
below the 'Parser Options' header in the output.
povray above.pov version=3.7
<Input file: hmm2.pov (compatible to version 3.70)>
povray above.pov +mv3.8
<Input file: hmm2.pov (compatible to version 3.80)>
povray above.pov
<Input file: hmm2.pov>
Always handling the initial rendering version via ini / flag settings
solves the 'must be first' problem and the '+hi include file first on
the fly' problem.
Unfortunately, it looks like the ini / flag defaulting isn't completely
there today code wise (the default isn't set correctly(a)). However, I
think the ini / flag solution should be the path going forward for v4.0.
I intend to adopt the approach for future releases of the yuqk fork.
Putting the #version first still good form. Further, for those already
doing it, the ini / flag approach will result in no changes at all in
behavior(b).
Bill P.
(a) - I think things ended up this way for backward compatibility. No
#version and defaulting going all the way back to 3.6.2.
(b) - Excepting where users making use of +hi.
Subject: Re: On the #version scene language directive.
Date: 7 Feb 2024 08:38:07
Message: <65c387bf$1@news.povray.org>
See related discussion about assumed_gamma and version settings at:
https://news.povray.org/povray.beta-test/thread/%3C65bebb56%241%40news.povray.org%3E/
Status update. In the yuqk fork the default version is now v3.8 and it
gets set ahead of the parsing with ini version=, flag +mv or v3.8 gets
defaulted as the version at that pre-parsing stage.
I opted not to drastically modify how the scene description language
(SDL) #version / version works. While parsing a scene, #version is
mostly about switching the version defaults(a) and parsing behavior.
(a) - Unless the default{} block has been used in which the version
default switching part stops working. (The yuqk fork still plans to
remove the default{} block)
The exception is the very last #version seen will still sometimes affect
output gamma handling too where assumed_gamma is not set anywhere in the
file. However, unlike recent, official releases, yuqk requires the ini /
flag stage, version align even where no ini / flag setting used. In
other words, now in yuqk, a scene where the last #version was v3.5 will
not turn off output gamma handling unless the executable is run with
+mv3.5. The ini / flag version becomes the arbiter of what output gamma
handling gets done.
For v4.0 the approach is not the cleanest possible. With v4.0 maybe two
version settings - or just drop the backward compatibility and fix
assumed_gamma and output gamma handling so 'version' isn't tangled in
that bit.
Bill P.
