POV-Ray : Newsgroups : povray.off-topic : Solar cooling? Server Time
21 Apr 2026 00:11:59 EDT (-0400)
  Solar cooling? (Message 51 to 60 of 71)
Subject: Re: Solar cooling?
Date: 18 May 2010 11:16:49
Message: <4bf2af61$1@news.povray.org>
On Tue, 18 May 2010 10:34:28 +0100, Stephen wrote:
> It is not unknown, you know. Especially in the field.
When things get crazy, it's not surprising that mistakes can happen.  A
very high pressure job, to be sure.
Jim
Date: 18 May 2010 11:30:35
Message: <4bf2b29b$1@news.povray.org>
I’m thinking more of first aiders who only get refresher training every
couple of years.
Best Regards,
Date: 18 May 2010 11:47:06
Message: <4bf2b67a$1@news.povray.org>
> couple of years.
That too, and probably more likely at that.
Jim
Date: 18 May 2010 12:16:30
Message: <4bf2bd5e$1@news.povray.org>
Warp wrote:
> Darren New <dne### [at] sanrrcom> wrote:
>>>> Warp wrote:
>>>>> clipka <ano### [at] anonymousorg> wrote:
>>>>>> Note that the probability that you're making contact with the cattle
>>>>>> wire at the very moment that a pulse has just started is /very/ low.
>>>>>   You make it sound like touching the fence is about the same as touching
>>>>> a 1.5-volt battery poles. Wouldn't that kind of defeat the whole purpose?
>>>> The farmer doesn't want to kill the cow. He wants to tingle the cow enough
>>>> that the cow learns not to lean against the fence.
>>>   Hence 1.5 volts isn't going to do it.
>> Yes, but a very brief high spike, which is what you were responding to,
>> *will* do it if the cow is pressing against the fence for several seconds.
>> He didn't say 1.5 volts. *You* said 1. volts. He said very short pulses.
>   I didn't say he said 1.5 volts. I said that "you make it sound like it was
> like 1.5 volts or something" (instead of a huge shock).
I see what you mean now.
    Ada - the programming language trying to avoid
    you literally shooting yourself in the foot.
Date: 18 May 2010 12:17:08
Message: <4bf2bd84$1@news.povray.org>
> though) was that a burn could happen only if the defibrillator was used
> incorrectly.
Isn't that pretty much definitional? If you're burning someone with it,
you're probably doing it wrong?
Date: 18 May 2010 12:18:15
Message: <4bf2bdc7$1@news.povray.org>
Warp wrote:
> Phil Cook v2 <phi### [at] nospamrocainfreeservecouk> wrote:
>> Just to act on the dumb side. If you use a graduated beaker with a candle
>> in it, add the water, and the second beaker, and then measure the water
>> height. Shouldn't the increase in temperature in the up-turned beaker
>> create a high-pressure that forces the water out from under it and thus an
>> increase in the water height as measured in the graduated beaker? So why
>> is the level of water forced out by the high-pressure less than the amount
>> 'sucked' in by the low-pressure?
>   I didn't understand the question.
Put two beakers on of different sizes. Shouldn't the cooling on the inside
beaker be offset by the heating of the outside beaker?  (Something like that.)
Date: 18 May 2010 12:29:49
Message: <4bf2c07d@news.povray.org>
  Sorry, I still can't understand. Maybe a picture and an explanation could
help?
Date: 18 May 2010 12:33:16
Message: <4bf2c14c$1@news.povray.org>
>> incorrectly.
Maybe, I don't know a lot about them.
Jim
Date: 18 May 2010 15:56:42
Message: <4bf2f0fa@news.povray.org>
>> couple of years.
The last training I got, the machine did all the pre-tests before going
beep, beep, beep, BEEP. Bang! (No, Warp it did not actually go BANG,
that was symbolism.) :-P
Best Regards,
Date: 19 May 2010 04:16:26
Message: <4bf39e5a@news.povray.org>
Am 17.05.2010 20:21, schrieb Warp:
Note that when I write "you're making contact with...", I literally mean
"you /are making/ contact" - not "you /are staying/ in concact". Of
course there's a comparatively high probability that you're currently in
contact with the wire when the pulse goes off.
Aside from that, I have no idea what the comparison with an 1.5V battery
has to do with the sentence of mine you quoted. Somehow gives me the
feeling that you're trying to be right by all means.
