POV-Ray : Newsgroups : povray.off-topic : DVD (-ROM) image access speed question Server Time
14 Oct 2024 09:22:41 EDT (-0400)
  DVD (-ROM) image access speed question (Message 1 to 7 of 7)
Subject: DVD (-ROM) image access speed question
Date: 8 Jul 2009 07:55:00
Message: <web.4a548845848a538634d207310@news.povray.org>
Hi. I'm working on a project which will involve giving some people a DVD with
files that can be accessed by HTML. I'm presuming they'd have every processor
speed and OS under the sun.  I have a cover page on which I display thumbnails
of twenty different images from various directories across the DVD.
Understandably, it loads a little slowly.
Q: How can I speed this up?  What's the best approach:
i) put all of the images into one directory to reduce DVD access time (tried,
didn't help much)
ii) If I'm going to do < i m g s r c ""  h e i g h t = X,  then I should just
save a new, resized copy of the image with  that height instead of asking HTML
to resize images which are 5X that size.
iii) Make one composite image and then use that click-on-a-bitmap- thing in
HTML.
Q: Can anyone point me to an online tutorial, or better yet, to the exhaustively
correct terminology so that I may google it, of how to create autorun files?
thanks.
Subject: Re: DVD (-ROM) image access speed question
Date: 8 Jul 2009 08:19:36
Message: <4a548ed8$1@news.povray.org>
All optical disk formats that I'm aware of have very long seek times.
Reading lots of small files is very slow with such disks.
I'm no expert in this field, but I don't think any of them have a very
high maximum transfer rate either. For example, a 1x CD-ROM drive
transfers 10MB of data *per minute*. That's 1MB every 6 seconds. Of
course, newer CD-ROM drives are usually 48x or something, which takes
you closer to 10MB per second. And DVD is faster still. (But I don't
know exactly how fast off-hand.)
[Wolfram Alpha claims a DVD transfers 5 megabits per second, which would
be about 0.6 MB/second.]
> didn't help much)
This is unlikely to help at all. It might minutely reduce the amount of
seeking required to read the directory tree, but it won't help read the
files any faster or seek to them any quicker.
This may well help, since you have less data to transfer. (You still
have the seek times, however.)
> HTML.
This should also help, by putting all the image data into a single
contiguous block, thus eliminating seek time penalties.
http://en.wikipedia.org/wiki/AutoRun
You need to add a file named Autorun.inf to the root directory on the
DVD, containing something like
   [autorun]
   open=root.html
   icon=icon.ico
This works ONLY for Microsoft Windows; I'm not sure if any similar
functionality exists for other operating systems...
Date: 8 Jul 2009 09:18:19
Message: <4a549c9b@news.povray.org>
> just
> HTML
Yes, do this.
Date: 8 Jul 2009 12:28:22
Message: <4a54c926$1@news.povray.org>
If the problem is seek time, this won't help as much as you think it might.
Try it and see.
> HTML.
This is what I'm guessing will give you the best shot.
I don't know about that, but I created an autorun file for my vacation
photos on one DVD. Here's what I had to do:
AUTORUN.INF holds
[autorun]
open=showme.bat
italy.bmp is a 64x60 BMP image. I'm pretty sure white is transparent, but
play around with it.
showme.bat holds one line reading
start index.html
index.html is the top of the image tree.
Apparently, it needs to be ASCII and not UTF.
http://social.msdn.microsoft.com/Search/en-US/?query=autorun.inf%20format&ac=8
HTH!  It'll at least get you started. :-)
   Insanity is a small city on the western
   border of the State of Mind.
Date: 8 Jul 2009 12:56:18
Message: <4a54cfb2$1@news.povray.org>
"gregjohn" <pte### [at] yahoocom> wrote in message
news:web.4a548845848a538634d207310@news.povray.org...
just
HTML
Why would you NOT do that anyway, be it DVD or www?
Date: 8 Jul 2009 13:03:47
Message: <4a54d173$1@news.povray.org>
It's extra coding and it takes more space on the disk. :-)
Date: 8 Jul 2009 13:42:10
Message: <4a54da72$1@news.povray.org>
> display thumbnails of twenty different images from various directories
> across the DVD. Understandably, it loads a little slowly.
Quicker would be to generate the thumbnails and join them into a single
image and use an image map - then it's loading one image instead of a
bunch of small images.
Jim
